Overclock.net › Forums › Software, Programming and Coding › Operating Systems › Windows › 00000007x error
00000007x error
post #1 of 6
I need some help, my laptop on Windows 7, everytime I start it up it gives me a bluescreen with that 7x error. However, when I open up in safe mode, that doesn't happen. How do I fix this?
K Series
Intel i5 2500K @ 4.5GHZ ASUS P8P67 PRO Rev 3.1 GTX 970  GSkillz 8GB DDR3 1600
Hard DriveOSMonitorPower
M500 128GB Windows 8.1 64-Bit Samsung 23" EDGE 750W
Fractal R4
K Series
Fractal R4
post #2 of 6
Is the Win7 on your laptop the one that came with it? If so I would point my finger at a possible bad RAM module. Try pulling one stick and seeing if it still barfs.
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Core i5 4690K ASRock Z97 Extreme4 XFX Radeon 7950 32 GB DDR3-2133
Samsung 850 EVO SSD Samsung DVD/CD-writer Corsair Hydro H60 Windows 7
MonitorMonitorPowerCase
ASUS PA248Q Dell U2412M XFX 850W Black Edition XXX Fractal Design Arc Midi 2
Pentium Dual Core E6700 MSI G41M-P33 Combo ATI HD4350 Kingston ValueRAM DDR3-1333
RAMHard DriveOSMonitor
Kingston ValueRAM DDR3-1333 WD Caviar Blue Windows 7 64-bit Sony 32" TV set
Apex TX-381
CPUGraphicsRAMHard Drive
Core i5 430M GT230M (1 Gb dedicated) 8 GB DDR3-1066 640 GB
OSMonitor
Windows 7 Home Premium (64-bit) 15.6"
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Apex TX-381
OSMonitor
post #3 of 6
It sounds like you have a bad driver if you can start the laptop in safe-mode OK. Try installing the drivers one-by-one till you find the corrupted driver and reinstall.
post #4 of 6
If you were Overclocking & stress testing when this initially happened then you will need to run a (chkdsk /f) command on your drives from the Windows Recovery Console (insert Windows CD & Boot it)
I've had this same error and that's how I fixed it...
The Rock
(15 items)
The Rock
(15 items)
post #5 of 6
doc2142 has a laptop, though, so chances are unlikely that doc2142 was overclocking or otherwise trying to run the laptop beyond its specs (well, ok, you can but that's usually in software and when you reboot the changes go away unless the software starts up when you load Windows).
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Apex TX-381
OSMonitor
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Apex TX-381
OSMonitor
post #6 of 6
It got fixed I don't know how. Just ran malwarebytes in safe mode and when I rebooted I didn't get the bsod.
K Series
Fractal R4
K Series
Fractal R4
  Back to Forum: Windows
