Overclock.net › Forums › Intel › Intel CPUs › 860 @ 92°c
860 @ 92°c
post #1 of 24
Should I be concerned that it hits those temps under load? I've been running it like that for nearly a month and it seems to be working just fine.
Just want some professional input from you guys, longevity/life, etc. Thanks.
(Image from my other thread from a month ago.)
Edited by N3C14R - 8/18/11 at 2:03am
S Club i7
(18 items)
i7-4770k @ Stock Asrock Z87-Extreme4 Gigabyte GTX 980 Ti G1 Gaming 32GB G.Skill Ripjaws Z @ 2133MHz
Mushkin Chronos Deluxe 240GB Western Digital Red 4TB Western Digital Blue 4TB Liteon CD/DVD Burner
CoolingOSMonitorMonitor
Corsair H110 Windows 10 Pro x64 34" AOC U3477PQU 27" Wasabi Mango QHD277 Prime
Leopold FC660C Enermax Revolution87+ 1000W Corsair Obsidian 650D Logitech G9x
Mouse PadAudio
Generic XXL Pad Microlab SOLO 9C
S Club i7
(18 items)
Mouse PadAudio
post #2 of 24
I wouldn't be OK with it.
What is the TJmax for your chip?
ContrastFX
(14 items)
Phenom II X6 1100T GIGABYTE GA-990FXA-UD3 XFX Radeon HD 6870 Mushkin Blackline
Seagate Barracuda 500GB LG DVD±RW SuperMulti Drive Corsair H60 Windows 8 Developer Preview 64bit
ASUS MS246 1920x1080 iRocks RF-6570 Antec HCG-520 LIAN LI Lancool PC-K58W
ContrastFX
(14 items)
post #3 of 24
92c? Dude that's quite TOO HOT. I'd be concerned! What thermal are you using? Are you overclocking due to that heat? Also is your cable management and airflow regulated right? There are quite much to ask but in reality, yes 92c is TOO hot. Not so right. Especially if you're overclocking to 3ghz. Something is WAY off.
post #4 of 24
yes thats bad, IIRC 82*c is as hot as you should get a 860
Silent Dominator
(28 items)
Classy Lady
(26 items)
TUF Inside
(18 items)
Silent Dominator
(28 items)
Classy Lady
(26 items)
TUF Inside
(18 items)
post #5 of 24
Shouldn't it be at least 70c and lower though?
post #6 of 24
But it's working just fine? It was a lot worse when I first got in the middle of 09, ran it at 4.0ghz with a much higher vcore/imc.
S Club i7
(18 items)
Mouse PadAudio
S Club i7
(18 items)
Mouse PadAudio
post #7 of 24
What are your temps in normal usage?
Running at 92C for long periods is not healthy for the processor at all.
If you use CM Hyper 212+ these temps are quite high. you may have poor air flow... cooler not seated currently or you put too much TIM.
Desktop
(16 items)
Laptop
(10 items)
Intel Core i7-5820K @ 4.40 GHz Asus Rampage V Extreme/U3.1 MSI GTX 980 Ti Gaming 6GB  Corsair Vengeance LPX 16GB (4x4) DDR4-3000
Hard DriveHard DriveCoolingOS
Samsung 850 Pro 1TB Samsung 950 Pro NVMe 512GB NZXT Kraken X62 Windows 10 Pro
MonitorMonitorKeyboardPower
Asus VG236H 23" 120 Sony XBR43X800D 43" 4K TV CoolerMaster Octane Storm + Razer Turret EVGA SuperNOVA 1000 G3
CaseMouseMouse PadAudio
Corsair Graphite 760T Black Logitech G502 Proteus Spectrum + Razer Turret Razer Goliathus Asus Xonar Essence STX II
Intel Core i7-4720HQ @ 2.60 GHz Asus G751JY Asus GTX 980M 4GB SK hynix HMT41GS6BFR8A-PB 16GB (2x8) DDR3L-1600
Hard DriveHard DriveOptical DriveOS
SanDisk SD7SB3Q128G1002  HGST Travelstar 7K1000 1TB HL-DT-ST DVDRAM GUC0N Windows 10 Home 64-bit
MonitorAudio
LG Philips LP173WF4-SPD1 + G-SYNC @ 75 Hz Realtek ALC668
Desktop
(16 items)
Laptop
(10 items)
MonitorAudio
post #8 of 24
Idle is around 32 to 38°C depending on ambient temps. I do have a couple of 80mm exhaust fans around my case, 2 on the rear, one of the top of the case and one intake at the front.
I only used a small amount of TIM on the cpu and the cooler is definitely screwed down. (made sure of that by double checking.) the TIM I used is called Evercool-420.
S Club i7
(18 items)
Mouse PadAudio
S Club i7
(18 items)
Mouse PadAudio
post #9 of 24
Maybe the TIM quality is not good? I don't know about it seriously. And what is your CPU temps on average load? gaming? converting & editing videos... etc.
Desktop
(16 items)
Laptop
(10 items)
MonitorAudio
Desktop
(16 items)
Laptop
(10 items)
MonitorAudio
post #10 of 24
I would do a thorough cleaning of your case / fans and a re-apply of the heatsink with maybe a tad more TIM.
Also, I would put the chip at stock to see the max temp you get there.
ContrastFX
(14 items)
ContrastFX
(14 items)
  Back to Forum: Intel CPUs
