Overclock.net › Forums › AMD › AMD CPUs › 1035t OC
1035t OC
post #1 of 4
After struggling for a few days I got a stable OC to 3.77 GHz on GA-970A-UD3 with 16GB PC-12800 (1600 MHz) DRAM. Anything higher is proving to be darn impossible ... specially with the locked multi of 13. Wasn't it used to be somewhere like 15 when someone did the record 5 GHz using Asrock board?
One funny thing. Each time I tried to reduce the HT Link speed, it would break Prime95.
Thought it might be useful to someone. The Prime95 mixed test (tests lots of memory?) was canceled after 14 hours :-
GA-970A-UD3 BIOS Ver F1
CPU Clk Ratio: x13 3.77 GHz
NB Freq: x10 2.9 GHz
Core Pref Boost: Disabled
CPU Host Control: Manual
CPU Frequency(MHz): 290
PCIe Freq: 100
HT Link Width: 16
HT Link Frequency(MHz): x10 2.9 GHz
Mem Clock Control: Manual, x5.33 (=1545 MHz. Installed is 1600 MHz DDR3).
DRAM Config:
DCTs Mode: Unganged
1T/2T Cmd Rate: 1T <-- Needed to be changed from BIOS default
CAS# Latency: 9 <-- Needed to be changed from BIOS default
RAS to CAS delay: 9 <-- Needed to be changed from BIOS default
Row precharge time: 24 <-- Needed to be changed from BIOS default
TwTr Cmd Delay: 4T
Trfc0 (DIMM 1, 3): 160ns
Trfc1 (DIMM 2, 4): 160ns
Wrt recovery time: 8T
Precharge time: 4T
Row cycle time: 26T
RAS to RAS delay: 4T
DCTs Strength & Timing: Defaults from BIOS
Channel Interleaving: Enabled
Bank Interleaving: Enabled
DQS Training: Perform DQS
CKE Power Down Mode: Disabled
Mem Clock Tri-stating: Disabled
Voltages:
CPU PLL Voltage: 2.535 <-- Unchanged (BIOS default)
DRAM Voltage: 1.645
NB Voltage: 1.200
HT Link Voltage: 1.220
NB/PCIe/PLL: 1.810 <-- Unchanged (BIOS default)
CPU-NB Voltage: 1.400
CPU Voltage: 1.450
In Advanced BIOS:
AMD C1E Support: Disabled
Virtualization: Disabled
AMD K8 Cool-n-Quiet: Disabled
IOMMU: Enabled (IMO unrelated to OC)
In Power Mgmt Setup:
Unrelated to OC
In PC Health Status:
HW Thermal Control: Disabled
post #2 of 4
Well, trying again to attach the JPGs...
post #3 of 4
That is strange, as there is nothing gained by overclocking the HT Link - it's merely a pipeline. It will also degrade performance and increase instability (due to signal degrading) beyond 2350Mhz - and there's no guarantee that yours will go that far without degrading, which is why we say keep it at 2000Mhz +/- 100Mhz.
post #4 of 4
XD because of HT link he stays on 3.77ghz xD there are no gain in performance (or +/-5%) it's not enough...
AMD Phenom II x4 925 C2 2.8@3.7GHz NB 2.65GHz 1... Asrock 970 Extreme 4 UEFI Palit GTX 460 Sonic Platinum 840MHz Core/1055MH... 2x4GB Kingston HyperX 1600@1414MHz 7-7-7-21 1.65v
Seagate Barracuda 1TB 7200RPM 32MB Sata 3 6GB/s Sony Optiarc 5260s 24X DVD+/-RW Cooler Master Hyper TX3 / AMD Stock fan as VRM ... Windows 7 Ultimate x64
MonitorPowerCase
Samsung SyncMaster S24B300HL 1920x1080 Cooler Master GX 750W Cooler Master Elite 430 Black
MonitorPowerCase
  Back to Forum: AMD CPUs
