Overclock.net › Forums › Cooling › Water Cooling › 655-B Sufficient?
655-B Sufficient?
post #1 of 23
Hey all, just a few quick questions!
I'm getting annoyed with my MCP350 pump with my XSPC Bay reservoir. It makes a loud buzzing noise and it's driving me crazy, plus I fancy changing things up a little.
Now, I can get a 655-B cheap, but does losing the speed variability make a difference? I really want a quiet pump that will be sufficient for my loop. I have 6 45-degree fittings in the loop; will the 655 perform fine with the restrictions in mind?
Furthermore, in the future I am thinking of adding another GPU to the loop, will the 655-B be good enough to power a CPU + 2 GPU loop?
My main concern is noise, like I said. I don't want another bay res, so could anyone recommend a good top for the 655?
Any help and suggestions would be most appreciated and certainly won't go overlooked. Thanks.
Project 4
i5 750 Lynnfield @ 4.4 GHz, 1.41v EVGA P55 SLi (132-LF-E655-KR) - A72 BIOS EVGA GeForce GTX 680 4GB G.Skill Ripjaws @ 9-9-9-24, 1.51V
80GB Intel X25-M SSD + 500GB WD + 2TB Samsung F3 Samsung Super Writemaster DVD+-R Windows 7 Ultimate Edition Samsung SyncMaster 2433 24"
Logitech G15 Corsair TX750 750W Corsair Obsidian 800D + Scythe Kaze Master Ace Razer Deathadder Respawn - Black
Mouse Pad
Steelseries QcK Medium - Black
Project 4
Mouse Pad
post #2 of 23
You will be fine with that pump.
I used a variable speed one on my project overhaul loop. That loop went
Res-pump-rx480 rad-cpu-5970-5870-res
Case Labs th10
(21 items)
970 evga 4way 2 gtx590 6gigs muskin ram
Hard DriveOptical DriveCoolingCooling
2tb wd,128 ssd/crucial lg dvd koolance gtx590 block x 2 white heatkiller
CoolingCoolingCoolingCooling
RX480 rad x2 MCP35x (X2) gentle typhoons 1850 rpm (8) xigamtek fans
OSMonitorKeyboardPower
win pro 64bit samsung 2343 x3 6144x1152 logitech g19 silverstone 1500watt
CaseMouseMouse PadAudio
case labs th10 deathadder 3500dpi cheap one Creative Sound Blaster X-Fi Titanium Fatal1ty C...
Other
XSPC dual bay reservoir
Case Labs th10
(21 items)
Other
post #3 of 23
Could you elaborate? Are you saying that I'll be fine even with 2 GPU?
EDIT: Just read your reply. What were the temps like using the single 480? What speed were you using? I believe the B Is stuck on 4.
Furthermore, does anyone know if, I buy a pump from the US, if the electronics differ? What I mean is, does it matter where the pump is manufactured (different voltage in the US for example), or are PC components standard? I guess the PSU does all the converting to standardise the voltages etc?
I don't want to get a pump from the US only to find the voltage differs, or something, and have a loud pump or some other problem.
Edited by jNSK - 10/12/11 at 10:42pm
Project 4
Mouse Pad
Project 4
Mouse Pad
post #4 of 23
That sounds like you got one of the DDC 1-Ts of bmaveric. There is a PCB mod available for $10 which cuts down on the noise a lot if you fancy having a go at it.
The 655-B is the same thing as a vario at setting 4 (of 5). You don't loose all that much performance, it will not make a huge difference to temps.
Actually the 45° fittings don't provide much in the way of restriction. Martin did some testing on them a while ago, the results look like this:
Should cope without too much trouble. The DDC pumps are more suited to higher restriction loops than the D5, but it should be fine. - See Edit -
The different tops don't really affect performance all that much with the D5 according to Skinnee, it is more about looks and barb compatibility than anything else.
Edit:
Try plugging your blocks into Martin's pump / rad optimizer and see what you get in terms of flow rate. Keep in mind that this is an estimating tool only and your results may vary.
Edited by GingerJohn - 10/12/11 at 10:44pm
Main
(21 items)
HTPC
(10 items)
i5 2550k P8P67 Pro Sapphire HD 7950 G.Skill RipJaws X 1600 Cas 9
Hard DriveHard DriveHard DriveCooling
Corsair Force 120 WD Blue 500GB WD Caviar Green 1TB XSPC RayStorm
RX240 MCR 220 EK 7950 Copper Acetal  DDC-1T
OSMonitorMonitorKeyboard
Windows 7 64-bit Dell U2311H Oculus Rift DK2 Ducky Shine 3 MX Brown
PowerCaseMouseAudio
Corsair TX 750W CoolerMaster CM690 II G500 Klipsch ProMedia 2.1
Audio
Asus Xonar DX
CPUMotherboardRAMHard Drive
A10-6800K Gigabyte GA-F2A85XN-WIFI G Skill 1600 CAS9 Kingston SSD Now 60GB
WD Caviar Blue 1TB LG Slim Blu-Ray player Silverstone NT06-PRO  Widows 7 Home Premium
PowerCase
Silverstone Sfx Series ST45SF 450W Silverstone SG05
Main
(21 items)
HTPC
(10 items)
PowerCaseMouseAudio
Audio
Asus Xonar DX
PowerCase
post #5 of 23
Should cope without too much trouble. The DDC pumps are more suited to higher restriction loops than the D5, but it should cope just fine.
The different tops don't really affect performance all that much with the D5 according to Skinne, it is more about looks and barb compatibility than anything else.
Thanks for the reply. I'll rep you when I get home. I updated my post above yours if you could take a second to check it out for me!
I'm thinking I'll stick with one GPU and get a 600-series NVidia when they're out.
Project 4
Mouse Pad
Project 4
Mouse Pad
post #6 of 23
My temp on my gpus never went past 50. Keep in mind I was using ATI.
Case Labs th10
(21 items)
Other
Case Labs th10
(21 items)
Other
post #7 of 23
They all run on 12v and should be identical no matter where you buy them. They are all made by the same company (Laing) after all.
I also edited my previous post
Main
(21 items)
HTPC
(10 items)
PowerCaseMouseAudio
Audio
Asus Xonar DX
PowerCase
Main
(21 items)
HTPC
(10 items)
PowerCaseMouseAudio
Audio
Asus Xonar DX
PowerCase
post #8 of 23
Aha! I see, that's good to know. I did buy the DDC from bmaverick, yeah, it's extremely loud. We've tried to fix it but to no avail. I guess it's a known issue with those versions of the 350...
All I know is I'm fed up of 350's. My first one burned out and this one annoys the hell out of me. Here's to hoping the third pump's a charm...
Project 4
Mouse Pad
Project 4
Mouse Pad
post #9 of 23
Yeah, the motor controller on the old DDC 1-T isn't great. The mod that I did to it worked really well; I can still hear the pump when it is quiet but not over any background noise.
I knew about the noise issue before buying the pump and was planning on seeing how bad it was before attempting the mod. I lasted all of about 15mins before putting my DCP2.2 back in, so I can understand where you are coming from.
If you fancy a cheap and quick project (took me about 2 hours) and you have some basic soldering skills then I would give the mod a shot.
Main
(21 items)
HTPC
(10 items)
PowerCaseMouseAudio
Audio
Asus Xonar DX
PowerCase
Main
(21 items)
HTPC
(10 items)
PowerCaseMouseAudio
Audio
Asus Xonar DX
PowerCase
post #10 of 23
I could, but I fancy restructuring my loop anyway. I can get a 655-B for $65.
Now all I need to do is pick a reservoir. I'm thinking a multioption.
Project 4
Mouse Pad
Project 4
Mouse Pad
  Back to Forum: Water Cooling
