Overclock.net › Forums › Graphics Cards › AMD/ATI › 6990??
6990??
post #1 of 8
Im looking at buying a 6990 for Battlefield 3 and future games, would it be a good choice and would it work with my system, I would like to have some advice about this card from someone who owns or owned one
post #2 of 8
I owned a 6990 for a good 4 months. It was an incredibly solid card for being a dual gpu one. I got amazing performance out of it. To avoid bottlenecking you may have to bump up the speed of your cpu though.
However, if you only play on gaming at 1080p you really don't need it. A 1.5GB GTX580 should do you fine. A 6990 would just be a waste of $300 really. You can get a solid 580 here on the forum marketplace for $400.
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
CPUCPUMotherboardGraphics
Intel Xeon E5-2670 V4 Intel Xeon E5-2670 V4 Asus Z10PE-D8 WS Nvidia Titan X
GraphicsGraphicsGraphicsRAM
Nvidia Titan X Nvidia Titan X Nvidia Titan X 128GB of Kingston DDR4 ECC 2133Mhz
Intel 750 NVME 1.2TB U.2 Intel 750 NVME 1.2TB AIC Intel 750 NVME 1.2TB AIC Intel 750 NVME 1.2TB AIC
CoolingOSMonitorKeyboard
EK Water Blocks Windows 10 Pro Dell UP2715K Cherry MX 6.0
PowerCaseMouseAudio
Corsair AX1500i Case Labs S8 Logitech MX Master Pioneer SE-L40
Intel 5960X Asus Rampage V Extreme Nvidia Titan X Nvidia Titan X
GraphicsRAMHard DriveHard Drive
Nvidia Titan X Corsair Dominator Platinum 4x8GB 2400Mhz (2) Intel 530 180GB (2) HGST 4TB
Optical DriveCoolingOSMonitor
Blu-Ray Slot Load EK Water Blocks Liquid Cooling Windows 8.1 Dell UP2715K
Ducky OCN Blues Seasonic 1200W Platinum XForma MBX MKII TBD
AudioAudio
Asus Xonar Essence One (2) Mackie MR5MK2
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
PowerCaseMouseAudio
AudioAudio
post #3 of 8
Would be beast mate, Go for it.
I don't think you will see that much of a bottleneck, But that really depends on what games you will be playing.
My system (AMD)
(14 items)
AMD Phenom II X4 955 BE "Deneb" @ 3415Mhz Gigabyte GA-MA790X-DS4 (1x) Gigabyte AMD Radeon 5770 Kingston HyperX DDR2 1066 4GB
Hard DriveOSMonitorKeyboard
2x 500GB, 1x 1TB external Windows 7 Ultimate Deep Blue 32bit 1x Asus VE248H 24" Monitor Tt eSPORTS Challenger Gaming Keyboard
PowerCaseMouseMouse Pad
Thermaltake 550w Aero Cool Syclone II Logitech MX518 1800DPI Red Mousepad
Audio
Creative Headphones
My system (AMD)
(14 items)
Audio
Creative Headphones
post #4 of 8
It would bottleneck 3.7ghz??
post #5 of 8
Like AMDRocks said it would depend on the game really and OC of the 6990. I've heard people say on here that a 6990 can be bottlenecked by a 1090T. But I mean like I said before...unless you plan to go eyefinity later, you really don't need it.
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
PowerCaseMouseAudio
AudioAudio
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
PowerCaseMouseAudio
AudioAudio
post #6 of 8
Ok I see also would a 580 work with my mobo I think its only AMD also whats the performance on 1 580 on battlefield 3
post #7 of 8
I only play 1080p but I sure as he#¤ use all the power my 2 6950 gives. Playing Crysis 2 or Battlefield 3 at Ultra setting gonna make even a 6990 sweat.
So, I say go 4 the 6990!
3930k
(17 items)
Xeon H2O
Intel Core i7 3930K RAMPAGE IV EXTREME AMD Radeon HD 7970 Series AMD Radeon HD 7970 Series
RAMHard DriveCoolingCooling
Team Xtreme Vulcan 2400 Samsung 840 EVO EK CSQ Nickel Plexi water block Alphacool Monsta 480 radiator
CoolingCoolingOSKeyboard
Alphacool XT45 420 radiator 2x EK CSQ Nickel Plexi Fullcover GPU Windows 7 64-bit Logitech G15
PowerCaseMouseAudio
Cooler Master V1000 Phanteks Enthoo Primo Logitech G500 Cambridge Audio DacMagic Plus
Audio
Yamaha HS50m
3930k
(17 items)
Xeon H2O
PowerCaseMouseAudio
Audio
Yamaha HS50m
post #8 of 8
Well the nVidia website suggests that at 1080p you should easily be able to play the game at Ultra settings. Now, that IS from the nVidia website so could just be a marketing tactic. Check it out and be the judge.
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
PowerCaseMouseAudio
AudioAudio
Verktøy Cu
(20 items)
XForma MBX MKII
(18 items)
PowerCaseMouseAudio
AudioAudio
  Back to Forum: AMD/ATI
