Overclock.net › Forums › AMD › AMD CPUs › 830 vs 955
830 vs 955
post #1 of 16
(I did a search to try and find the answer..couldn't find anything close, so I'm asking for the brain trust here for help)
I've been saving up for a 955be (upgrading my sig rig...finally), however I found a great deal on a phenom II 830 (cheapest i've seen the 955be was $115, and I can pick up a 830 for $49). My question to you guys is this; how big of a difference will the 955be be vs the 830? I'll be (attempting) to overclock both.
Rest of my system is in the sig rig for reference.
(And i'm 99% sure I'll have to upgrade my motherboard for either one....looked to me like the 770de isn't compatible with either chip).
Thoughts? (and thanks in advance for any advice!)
Blue4u
(10 items)
Blue4u
(10 items)
post #2 of 16
I'd say the 830 for $50 is by far the route to go. It's got the L3 cache unlike the 840, so it really is just a multiplier locked phenom II.
I don't know how well they overclock being HTT clock bound, but to be honest I would still go into it expecting 3.7-3.8ish if done right, and you're going to be more then fine sitting at that rather then the possible max on the 955 being around 4.
My thoughts.
x6 1055T Crosshair IV Formula Sapphire HD6850 4GB Mushkin Redline 1600 cas.6
Hard DriveHard DriveCoolingOS
Samsung 840 Series 120GB WD Caviar Black 750GB Prolimatech Armageddon 7 Home Premium x64
Acer G235HAbd 23'' 1080p Logitech G11 PC Power & Cooling 500w ABS Canyon 595 Full Aluminum
MouseAudio
Logitech MX518 Syba Connectland 2.0 Speakers
MouseAudio
post #3 of 16
If I where you. I would get the 955BE. its a beast of a CPU. However there is somthing better than both of what you suggested in your OP.
960t Its a 4 core Thuban based black edition CPU, with a 95W Thermal design. what that means is its a locked down 6 core thuban CPU, with unlocked multi and lower heat output than the Phenom's. Best of all people are having great luck unlocking core's 5 and 6! I see people with unlocked core's hitting 3.6-3.8 easy, some report hitting 4.0 with it. I say get the 960T!
Gizmoto
(18 items)
They beat me:(
(15 items)
Home Server V1.0
(17 items)
AMD Phenom II x6 1040t @2.7Ghz ASRock 880GM-LE FX  AMD Radeon HD 4250 integrated graphics Micro Center(ADATA) 8Gb (2x4) 1333
Western Digital Caviar Blue 640Gb Samsung SpinPoint F4 2Tb Seagate Barracuda 7200.9 ST3500641AS-RK 500Gb Seagate Barracuda 7200.9 ST3500641AS-RK 500Gb
Optical DriveOptical DriveCoolingOS
ASUS 24X DVD Burner ASUS 24X DVD Burner Stock AMD Cooler Windows 7 Home Premium 64 bit
OSOSPowerCase
Linux Mint (VM) Linux Ubuntu (VM) Inland ILG-500R2 500w PSU DiabloTek Evo Mid-tower Case
Other
Inland IL internal card reader
Gizmoto
(18 items)
They beat me:(
(15 items)
Home Server V1.0
(17 items)
OSOSPowerCase
Other
post #4 of 16
I just got the 830 the other day. Great upgrade from an Athlon x2 for a budget system.
Not overclocked anything yet, but hoping to get 3.2 out of it.
Rig 2.0
(16 items)
i7 3770k Asus P8Z77-V EVGA GTX780 SC ACX Samsung DDR 3 (2 DIMMS) MV-3V4G3D/US
Samsung 830 SSD WD Caviar Black Asus DVD/RW Xigmatek s-1283 HDT (Air Cooling)
CoolingCoolingOSMonitor
Scythe Slipstream 1200RPM (x2) Antec 140mm + Antec 120mm + Xigmatek 120mm (x2) Win 7 64bit Acer S243HL bmii - 24"
PowerCaseMouseAudio
Corsair TX750 Corsair Carbide 300R MX 518 Auzentek X-Fi Forte 7.1
Rig 2.0
(16 items)
PowerCaseMouseAudio
post #5 of 16
While I agree the 960t is a beast, you're not looking at the big picture. The 830 can be found for $50 right now, the 960t was $125 last I saw. They will have roughly the same performance clock for clock, and clock probably within a couple hundred MHz of each other. If you're comparing price/performance do I really need to spell it out?
MouseAudio
MouseAudio
post #6 of 16
You might have to, seeing how all these people are recommending the 955.
IT HAS OVER 100% MORE BANG FOR THE BUCK.
1055T@3445MHZ 1.2V/ SB Pentium G620@0.84v ASUS M4A79XTD EVO/ ASUS P8P67 Sapphire 6870/ Club 3D 5770 2x2gb Kingston DDR3 1333mhz @ 1467mhz 7-7-7-17
Hard DriveOSPower
Samsung Spinpoint F3 1TB Windows 7 Home 64bit Corsair 600W
Hard DriveOSPower
post #7 of 16
I personally love my 955, and itt was on sale for $100 brand new. So with some price matching and beating I bet you can get a hell of a deal for a 955.
Definitely a very good bang for your buck.
post #8 of 16
the 955 will OC better and easier having the unlocked multi and starting out higher to begin with (955 is 3.2, 830 is 2.8).
The 830 is a really great deal, but if your looking for the best OC and performance, the 955 is it.
The 830 is really just a renamed 925.
Edited by blupupher - 11/2/11 at 11:04am
'Pooter
(15 items)
Server
(15 items)
Phenom II 830 x4 Gigabyte GA-880GM-D2H MSI GTX 460 Hawk 12 gigs (2x2 and 2x4) Corsair DDR3 1600
Hard DriveOptical DriveOptical DriveCooling
Samsung  Samsung DVD-RW  Samsung DVD-RW  Cooler Master Hyper 212+
OSMonitorKeyboardPower
Windows 7 Pro x64 ASUS VH242H 23.6" Logitech MX 3200 Wireless Antec Neo Eco 620
CaseMouseOther
Antec P-180 Mini Logitech MX 3200 Wireless Crucial m4 128
AMD Athlon II X2 210e Gigiabyte MA785GMT-UDH2 ATI Radeon HD 4200 G.Skill Sniper
OCZ SSD Seagate SSHD Corsair A50 WHS 2011
PowerCase
Antec Neo Eco 400 Antec 300
'Pooter
(15 items)
Server
(15 items)
CaseMouseOther
PowerCase
post #9 of 16
I know the 830 is a good deal. But for overclocking it is going to be difficult to achieve a nice overclock on that. Overclocking with the f s b can be tricky because year overclocking so many different components. But for 50 dollars that is a darn good deal. But if you want to overclock the 955be is the way to go. Or like the other guy said 960t. Both those cpu's are pretty close in price.
The Money Pit
Intel 2500K (4.5Mhz)  Gigabyte GA-Z68X-UD3H-B3  Gigabyte GTX 970 Windforce G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin ...
Western Digital Caviar Black WD1002FAEX 1TB 7200 ASUS 24X DVD Burner DRW-24B1ST/BLK/B/AS Win. 8.1 Samsung 24" LED SA350
PowerCase
Rosewill BRONZE Series RBR1000-M 1000W ThermalTake V9 Black edition
The Money Pit
PowerCase
post #10 of 16
Oh, and BTW, you can get a 955 BE in the FS forum here for $90 right now.
'Pooter
(15 items)
Server
(15 items)
CaseMouseOther
PowerCase
'Pooter
(15 items)
Server
(15 items)
CaseMouseOther
PowerCase
  Back to Forum: AMD CPUs
