Overclock.net › Forums › Intel › Intel Motherboards › 262F Seems hot for a motherboard...
post #1 of 7
So I'm hoping this is wrong. I just got home, my computer was asleep and it just started up... Seems too hot.
All the temps stayed the same plus or minus 2 degrees after 20 minutes.
Edited by Landmine - 11/2/11 at 8:23pm
Main
(16 items)
Intel I7-2600K ASUS SABERTOOTH P67 Radeon HD 6970 Radeon HD 6970
RAMHard DriveOptical DriveOS
CORSAIR Vengeance 16GB Crucial RealSSD C300 + 5TB Storage Yup, they are there. Windows 7 64bit
MonitorMonitorMonitorKeyboard
u2312hm u2312hm u2312hm Logitech G510
PowerCaseMouseMouse Pad
Thermaltake Black Widow 850W COOLER MASTER HAF X 942 Logitech MX518 X Trac Ripper XL
Main
(16 items)
post #2 of 7
I'm curious...why are you using Fahrenheit!?!?!?!
My guess is that your program of choice is incapable of reading the mobo temperature sensor properly. Use something like RealTemp, HWMonitor, or AIDA64 for that data.
post #3 of 7
Bad sensor. 262f is 127c....... Its broken.
Sent from my AT&T Samsung Galaxy S2 using Tapatalk.
Intel i7-7700K Delidded 5.0Ghz Gigabyte AORUS Z270X-GamingK5 EVGA GTX1080FTW.Hybrid.Scythe GT/AP-15 P/P 2x8GB Kingston HyperX Savage Black 2800CL13
Hard DriveHard DriveHard DriveCooling
Samsung 960 EVO 250GB NVMe Samsung 840 EVO 250GB 1.5TB Hitachi 7K3000 TTWater 360mm w/ Corsair Sp120PWMs
Dell S2716DG 2560x1440 144Hz GSync Razer BlackWidow Chroma v2 Corsair AX750 Corsair Carbide 600C Inverse
MouseAudio
Razer DeathAdder Chroma ALC1220
MouseAudio
post #4 of 7
Tried Asus' Thermal Radar program?
post #5 of 7
HWMonitor is amazing. Thank you for the recommendation. Side note, Asus Thermal Radar is reporting -60.0C
Pretty sure the sensor is bad. All apps reporting the same. BIOS says 80F.
Edited by Landmine - 11/2/11 at 9:01pm
Main
(16 items)
Main
(16 items)
post #6 of 7
Isn't it though? I love HWMonitor.
Yeah, I'm voting for broken sensor.
"This isn't the sensor you're looking for---you can go about your business---move along..."
post #7 of 7
have the same problem, nothing to worry bout. Got rid of mine after i updated the bios on the mobo
My System
(14 items)
Intel 3570K Asus Maximus Gene - V Gainward GTX 570 Goes like Hell Edition Gainward GTX 570 Phantom
RAMHard DriveOSMonitor
Corsair Dominator Platinum 16Gb 1600Mzh OCZ Vertex 2 Windows 7 64bit Asus VG278H
PowerCaseMouse
Corsair AX850 Corsair 600t se white Logitech G500
My System
(14 items)
PowerCaseMouse
  Back to Forum: Intel Motherboards
