Overclock.net › Forums › AMD › AMD Motherboards › 125W = 95 W
125W = 95 W
post #1 of 19
Ok so right now i'm using an ASUS M5A78L-M LE coupled with a Phenom II X4 B45 @ stock speeds (X3 445 UNLOCKED WITH L3 cache). Since the processor is rated at 125W, i'm kinda bummed about it. I got no real worries about the VRM's blowing courtesy of ASUS' trademark VRM protection feature. It's just that CPU throttling kicks in WAY too often while i'm video encoding+playing BF3+streaming. So is there a way i could undervolt the processor so as to reduce the TDP by a tad atleast? Right now the things sitting at stock speeds @ 1.28v. Planning on reducing the volts down to 1.20 or 1.24 at the very least. Problem is however i can't really find an option to do that in the BIOS. All i'm getting to do is overvolt the CPU but not undervolt. Besides reducing the multi, any other suggestions guys?
Edited by PunkX 1 - 11/18/11 at 10:51pm
Kukumonster
A pleasant surprise :)
Cooler Master USP 100 Black Edition
Value redefined.
Amd Athlon II X3 435
Core i5 2320 Intel DH67BL Sapphire R9 285 Corsair 8GB (4x2)
Hard DriveHard DriveHard DriveCooling
Kingston HyperX Fury 240GB  WD Blue 1TB Seagate Barracuda 500GB Noctua NH-C14S
CoolingOSMonitorPower
Noctua NF-A140*2 Windows 10 Pro (TP) LG 22" 1080p  Seasonic G-550 F3 550W
Cooler Master USP100 Black Edition
Kukumonster
Value redefined.
post #2 of 19
you should go to CPU/NB VID/FID menu. it is a submenu where you can adjust the CPU voltage and multiplier. same goes for the NB.
Sandy Thunder
(18 items)
QuickSilver X1
(15 items)
i7-3930k C1 4.6GHz @1.344v Sabertooth X79 2x EVGA GTX 560 Ti SC SLI 900/2106 Dominator 1866 16GB 9-10-9-27
Hard DriveHard DriveCoolingOS
Crucial M4 64GB 'Cuda 320GB XSPC Rasa 750 RX240 push/pull + Alphacool UT60 ... Win 7 Pro x64
MonitorMonitorMonitorKeyboard
Asus VE198D 19" Samsung 920NW 19" Samsung 906BW 19" Logitech G510s
PowerCaseMouseMouse Pad
Corsair HX850M Carbide 400R Cyborg M.M.O. 7 Corsair MM200
AudioOther
Bose Music Monitor Nuforce Icon HDP
Phenom II x6 1090T BE Sabertooth 990FX Radeon HD 5770 1GB Corsair Veangence Blue
WD Caviar Black 1TB  Lite ON 16x DVD-R/RW ThermalRight Silver Arrow Windows 7 Professional 64 bit
Syncmaster 921BW 19" & Syncmaster 965 19" and S... Apple aluminum wired keyboard Corsair TX650 Silverstone TJ05 with window and thermal contro...
MouseMouse PadAudio
logitech mx air None Monsoon MM-700
Sandy Thunder
(18 items)
QuickSilver X1
(15 items)
AudioOther
MouseMouse PadAudio
post #3 of 19
I tried doing that. Right now everything's set to auto. I can't go any lower than that. All i get to do is increase the voltage mad.gif
Kukumonster
Value redefined.
Kukumonster
Value redefined.
post #4 of 19
Have you tried K10Stat?
Tutorial here might get you started:
FX 8350 GA-990FXA-UD3 Zotac 670 corsair vengeance
Hard DriveHard DriveOSMonitor
WD6401AALS x2 raid 0 Crucial M4 win 7 pro x64 hp zr2740w
thermaltake meka g1 corsair tx750 nzxt gamma logitech g600
Audio
HT Omega Claro+
Audio
HT Omega Claro+
post #5 of 19
Awesome, I undervolted my processor down to 1.15v, completely stable!! Temps went down by 6C thumb.gif. The current TDP is @ 110w down from 125w! Rep+
Here's a screen:
337
Edited by PunkX 1 - 11/18/11 at 1:01pm
Kukumonster
Value redefined.
Kukumonster
Value redefined.
post #6 of 19
See, this is why you should buy a motherboard that's actually capable of handling the power draw of 4 cores or more.  Because if you don't, (depending on the mobo/manufacturer) you could enter end up with burnt ash or performance loss during load tongue.gif
post #7 of 19
Noted xd thumb.gif. Being just a college-going kid, i never exactly had a top-of-the-line budget at the time. The MSI 785GM-E51 was actually falling within my budget but there was no way i was going in for an MSI (thanks to you biggrin.gif). I'd rather take my chances with a 3+1 phase ASUS. Anyway I've been saving up for a Crosshair V Formula and it ain't too far away. For now lemme enjoy my low ass voltages. Just happy that the TDP's gone down to almost 110W.
Edited by PunkX 1 - 11/18/11 at 10:49pm
Kukumonster
Value redefined.
Kukumonster
Value redefined.
post #8 of 19
Guess i'm relatively safe(er) for now.
Kukumonster
Value redefined.
Kukumonster
Value redefined.
post #9 of 19
Intel Core i5-6300HQ Dell Proprietary 4GB Nvidia GTX 960M Samsung 12GB (1x8GB 1x4GB) DDR3L 1600 MHz
256GB SanDisk M.2 SSD 1TB HGST 7.2k HDD Custom Cooling by Dell Solutions Windows 10 Home 64-Bit
MonitorKeyboardPowerMouse
15.6" 1920x1080 IPS Screen Dell 130w PSU Logitech G602 Wireless
Mouse Pad
Xtrac 'Ripper' Mouse Pad
Intel Core i7-2760QM Toshiba Qosmio X775 Nvidia 1.5GB GTX 560M 8GB DDR3 1333
120GB Samsung 830 SSD + 1TB HGST 7200RPM HDD CD/DVD-RW Stock Windows 10 Home 64-Bit
17.3" - 1600x900 Standard backlit 180w Power Adapter Logitech G500s
Audio
Harmon/Kardon Onboard
Mouse Pad
Audio
post #10 of 19
Originally Posted by Imglidinhere View Post
How am i pulling just 91w confused.gif. Before on stock voltage (1.30v), the processor was drawing 125w. With the voltage reduced to 1.15, it should be drawing about 110w according to my calculations.
Edited by PunkX 1 - 11/18/11 at 11:22pm
Kukumonster
Value redefined.
Kukumonster
Value redefined.
  Back to Forum: AMD Motherboards
