Overclock.net › Forums › Graphics Cards › Graphics Cards - General › 1680x1050 GPU?
1680x1050 GPU?
post #1 of 14
What is the best gpu i can add to my computer?
I have:
Cooler Master Centurion 534 - psu 380W CM
Asus P5LD2 SE
Intel Core 2 Duo E4300@1.80Ghz
2x512MB DDR2 Kingston 533Mhz
2x1GB DDR2 Kingston 800Mhz
Asus nVidia Geforce 7600GT 256MB
WD 160GB+WD 640GB
Monitor Samsung 226BW (1680x1050).
post #2 of 14
I think you need a full upgrade.
new build
(14 items)
i5 2500K Asus P8P67 MSI GTX 1060 Gaming 6GB G Skill 8G 1600MHz
Hard DriveHard DriveOSMonitor
Samsung 850 evo SSD 1TB WD 500GB Windows 7 Ultimate 64bit Samsung 23" 1920 x1080
PowerCaseMouse
Antec TruePower 650 CoolerMaster HAF 912 Logitech G500
new build
(14 items)
PowerCaseMouse
post #3 of 14
I was going to recommend a GTX 560 TI (awesome card for the price) but you'll need to change out that power supply mate. 500W is the minimum and you should be able to pick one up pretty cheap.
post #4 of 14
I was going to recommend a GTX 560 TI (awesome card for the price) but you'll need to change out that power supply mate. 500W is the minimum and you should be able to pick one up pretty cheap. If the power supply upgrade is not in your budget, what about a GTS 450 which should give you everything you need.
Sorry for the double post my connection had a conniption
post #5 of 14
what use will there be for a 560Ti if his cpu is dual 1.8G?
Even 460 sounds a bit much to be honest
new build
(14 items)
PowerCaseMouse
new build
(14 items)
PowerCaseMouse
post #6 of 14
Would i be able to see big difference switching from 7600gt to gts450? Is this much better card, and would my 380 psu be enogh to support it?
post #7 of 14
a 4670, even then it will suck because of the cpu, it is too slow
pote reload
(14 items)
intel 3570k@4.4@1.25 gigabyte z77z-ud3h gigabyte gtx460 768mb oc 850/2100 8gb ddr3 1600 corair vengeance blue
samsung 500gb hd502hj, 2x crucial m4 64gb raid 0 sony optiarc 24x hyper 212+ win8 x64
MonitorPowerCaseMouse
envision lcd wide 19 + lg tv lcds 32" 32ld330 1... corsair vx 550w cheapo steelseries ikari laser
pote reload
(14 items)
post #8 of 14
Based on your PSU restrictions, I would say either a hd5770, or gts450 would probably be the most powerful cards you would want to use. Of the 2, the hd5770 draws less power, and outperforms a gts 450. It's descent for some 1680x1050 gaming, you can probably find one used for cheap, or the updated hd6770 model new shouldn't be too bad price-wise. I had a hd5770 for about 2 weeks, it performs very similar to a hd4870.
post #9 of 14
I have oc my proc to 2,8Ghz. Can that make any diff. what gpu should i get?
post #10 of 14
I've had this processor before, you should be fine when playing most games. ( you'll only be bottlenecked when playing games like GTA 4 or Crysis 1 or 2) Even then you'll still notice the difference the GPU has to offer.
Go ahead and upgrade your GPU like you want. a 450 will do you fine as of now. You'll see a huge difference in performance, as the 7600 gt doesn't even have unified shader architecture, it'll be like night and day.
Titanus
(12 items)
LS-FX2
(17 items)
AMD K15 970A-G46 (MS-7693) AMD R9 290 G.Skill
RAMHard DriveOptical DriveCooling
G.Skill Yes 24 Stock
OSMonitorKeyboardPower
Win 7 Professional Gs90 series Microsoft sidewinder Tx750
CaseMouseMouse PadAudio
Azza solano 1000 Logitech G500 Starcraft 2 "Zerg Rush" mousepad 2.1 "average" system
Other
Blue Yeti Microphone
GraphicsMonitorKeyboardCase
gt 320 13 inch built-in apple alluminum unibody
Mouse
apple trackpad
Titanus
(12 items)
LS-FX2
(17 items)
Other
Mouse
apple trackpad
  Back to Forum: Graphics Cards - General
