Overclock.net › Forums › AMD › AMD CPUs › 89w CPU or not?
89w CPU or not?
post #1 of 7
I want to go dual core, without having to get DDR2 RAM and all that so im sticking with AMD, i got my eyes on a 4400+ Toledo. But my question is, should i get the cheaper 89watt version or the regular one?
I have a feeling the 89watt one may not OC as well or something.
post #2 of 7
i'm not the most knowligable about amd but isn't that a mobile cpu?
e2140 P5N32-SE SLI Deluxe 8500gt super+ 1gb 4gb 2x buffalo 1x rendition, 1x kngstn valueram
160gb seagate dvd-rw and a false cd drive like in sig xp home oem samsung crappy POS
really bad crappy some piece of crap i got for cheap bad
Mouse Pad
bad
Mouse Pad
bad
post #3 of 7
Nope its s939
post #4 of 7
The 89w version will be the better one.
Desktop
(15 items)
AMD FX 8120 Gigabyte XA990-UD3 Gigabyte GTX670 Windforce III G. Skill RipJaws
Crucial M4 Western Digital Blue LG Dual Layer Sata Antec Kuhler 920
OSMonitorKeyboardPower
Windows 8 Dell 2007wfp 20.1" Logitech G710+ Corsair Professional HX650
CaseMouseMouse Pad
Coolermaster Silencio Steelseries Sensei [RAW] Func F10.s
Desktop
(15 items)
CaseMouseMouse Pad
post #5 of 7
89w means it runs it will probably run cooler which means u can OC it more
post #6 of 7
Nope. They don't OC any different.
Studio Machine
Intel Q6600 @ 2.6 Ghz I forget. nVidia 8400 2GB DDR2
1x320GB, 1x750GB CD/DVD+-RW Windows Vista Ultimate SP1 & Arch Linux 64bit 19inch Acer X193W
Logitech UltraSlim Pathetic 350w Cube 2 Quid Bargain Bin Thing
Studio Machine
post #7 of 7
hes pretty much right, i have the 85w version and i had it on phase which didnt really give much more of an oc, i could get it to post up to about 3.0ghz but really stable at 2.8 but all this was with 1.4vcore and sometimes 1.375, it didnt like alot of vcoore unlike my opti 170 which has to have like 1.7vcore to be stable at 2.8 or 2.9, its not so much youll get a higher oc its jsut less vcore to do it
i would go for the lesser wattage of the two and if i recall its a few bucks cheaper
xeon
W3520 x58 ud5 9800gtx+ tridents
Hard DriveOSMonitorPower
wd black x2 W7 64 acer 23 ocz 850hx
haf932
xeon
haf932
  Back to Forum: AMD CPUs
