Overclock.net › Forums › Components › Hard Drives & Storage › 127 gig?
127 gig?
post #1 of 8
I have a 250 gig wd harddrive and service pack 1 and windows is still telling me that it's 127 gigs. Is there something else that I have to do after I install sp1? The thing I use to do is install partition magic and partition the space that windows wasn't seeing and then combine partitions but I want to know if there is an easier way.
My System
AM2 3800x2 Asus M2N-SLI Delux Geforce 7800gt 2GB XMS2
Hard DriveOSKeyboardPower
250GB Xp Pro G15 Sunbeam
CaseMouse
Thermaltake Armor G5
My System
CaseMouse
post #2 of 8
Win SP1 cannot detect HDs bigger than 130GBs or... 127GB. Get it in another computer and format it using the other computer and then install Win on it.
Or... you can get a copy of Win with SP2 slipstreamed on it.
Q8400 DFI LP DK P45-T2RS eVGA GTX 650 Kingston
2.8TB Total LG Super DVD Burner SATA VII Enterprise x64 Gateway FHD2401
PowerCaseMouseMouse Pad
Corsair VX550W NZXT Source 210 White Logitech G400 Razer Kabuto
Audio
Creative Audigy
Audio
Creative Audigy
post #3 of 8
ya there's something after sp1 lol...it's called "sp2"
Desktop
(15 items)
AMD FX 8120 Gigabyte XA990-UD3 Gigabyte GTX670 Windforce III G. Skill RipJaws
Crucial M4 Western Digital Blue LG Dual Layer Sata Antec Kuhler 920
OSMonitorKeyboardPower
Windows 8 Dell 2007wfp 20.1" Logitech G710+ Corsair Professional HX650
CaseMouseMouse Pad
Coolermaster Silencio Steelseries Sensei [RAW] Func F10.s
Desktop
(15 items)
CaseMouseMouse Pad
post #4 of 8
No need to get smart. Sp1 is suppost to correct the issue with windows only being able to reconize a drive bigger then 127gigs.
My System
CaseMouse
My System
CaseMouse
post #5 of 8
Well, SP2 is also much better than SP1. Also, theres a nasty thing in SP2 which reverts your DMA drives to PIO. And I need to get the hotfix which is only available through calling M$. Go figure.
Audio
Creative Audigy
Audio
Creative Audigy
post #6 of 8
Don't bother with SP1 if your copy of Windows doesn't have it, go straight for the SP2.
Also, since that the 250GB is only being recognize as 127GB, the rest of the drive should be as unformatted drive, I'd say go to computer management window and then Disk management and you'll see the rest of the drive unpartitioned, create one and store all the stuff that you want there.
I think you have to install WinSP2 from the start to actually for the OS to recognize the full size of the drive. I think.
post #7 of 8
Boxxy Minaj
(15 items)
Intel i7 2600K @4.8GHZ ASUS P8P67 Pro MSI Twin Frozr II HD6870 1GB 16GB Kingston HyperX DDR3-1600
Hard DriveCoolingOSMonitor
1TB WD Black + 6TB in storage Corsair H50 Mac OS X 10.7.2 21.5 ASUS VH222 + 40" Samsung HDTV
Logitech G15 Antec Earthwatts 750w Lian-Li A05N Logitech Performance MX
Mouse PadAudio
Razer Exactmat (control side) Griffin iMic + Altec Lansing Octaine 7
Boxxy Minaj
(15 items)
Mouse PadAudio
post #8 of 8
Originally Posted by reberto
I figured out that the original release of Windows XP doesn't recognize hard disk sizes greater than about 127GB. So if you're installing XP on a machine with an absurdly large hard drive like mine, get your mitts on a copy of Windows XP Service Pack 1 or later, which knows how to deal with mongo hard drives.
Link
Link2
My System
CaseMouse
My System
CaseMouse
  Back to Forum: Hard Drives & Storage
