Overclock.net › Forums › Overclockers Care › Overclock.net Folding@Home Team › ....6098 WU is not worth any points?
post #1 of 10
O-o what the deuce? Thing is chugging away and doing nothing.
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
3770k @ 4.5 1.312 load Zotac Z77 ITX Wifi GTX 1070 Gaming 2126/2249 w/ Hybrid cooler TridentX 16GB 2400MHz
Hard DriveHard DriveCoolingCooling
Samsung 850 Pro 1TB Seagate 2TB H105 EVGA Hybrid GPU cooler
OSMonitorKeyboardPower
Windows 10 Asus MG279Q - 24" 144Hz 1080p Filco Majestic II w/ Cherry Reds Seasonic X 760W
CaseMouseMouse PadAudio
Bitfelix Prodigy Logitech G400 Razer Goliath AKG A701
AudioAudio
JDS Labs Objective 2 JDS Labs ODAC
Core i5 750 3.99 (190x21) 1.376v Load ASUS P7P55d-E Pro GTX 670 FTW <- Poor overclocker :( 8GB (4x2GB) G.Skill DDR3 1600
Hard DriveHard DriveOptical DriveOS
Samsung 830 Evo 128GB 2x 2TB  Some DVD drive OSX 10.10.4
MonitorPowerCaseMouse
Asus 1080P Crap TX 750 HAF 922 G400s
Mouse PadOther
Apple Keyboard Xbox One controler
CPURAMHard DriveHard Drive
C2D 2,26GHz under volted @ .978v 8GB  Crucial M4 64GB SSD 500GB Scorpio Black
OSMonitorKeyboardMouse
OS X 10.0 1280x800 Built-in Trackpad
Audio
Built-in
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
AudioAudio
Mouse PadOther
Audio
Built-in
post #2 of 10
Just remember, its not the points that matter. wink.gif, what is 6098? gpu?
Main Rig
(12 items)
R7 1800x ASUS Prime 370 Pro RX 480 Corsair Dominator
Samsung 850 Pro  None Windows 10 Pro HP w19e: 1440x900 | Sony KDL40S-5100 1920x1080
CMStorm Quick Fire. CM 1050w  Cooler Master Cosmos II Roccat Kone XTD (Optical)
Main Rig
(12 items)
post #3 of 10
6098 is SMP. It takes considerably longer than other SMP units. While most of the SMP units I get are in the 2:30 TPF range, the 6098's I folded were at 6:39. I haven't had one in a few weeks, but IIRC the bonus was pretty nice.
Neurosis
(7 items)
Monochrome
(28 items)
Patchouli
(11 items)
i7 5820K Gigabyte GA-X99 Gaming G1 EVGA GTX-980ti EVGA GTX-980ti
RAMHard DriveOS
Corsair DDR4 32GB Samsung 950 Pro NVME Windows 10 Pro x64
i7 2600K @4.5GHz Gigabyte P67A-UD7 B3 EVGA GTX 780 Ti SC 3GB EVGA GTX 780 Ti SC 3GB
RAMHard DriveOptical DriveCooling
2x4GB Super Talent DDR3-1600 CL9 Western Digital Caviar Black WD1001FALS LiteON iHBS212 EK Supreme HF Copper/Acetal
CoolingCoolingCoolingCooling
4x Noiseblocker NB-BlackSilentPro PLPS 120mm PW... Bitspower Water Tank Z-Multi 150 Aquacomputer Flow Rate Sensor "High Flow USB" G1/4 Bitspower black compression fittings
Tygon silver tubing 0.5" ID 0.75" OD 2x Watercool HEATKILLER® GPU-X³ GTX TITAN/780/7... Alphacool HF D5 acetal pump top Aquacomputer D5 pump (USB/Aquabus)
CoolingCoolingOSOS
EK CoolStream XTC 420 6x Noiseblocker NB-BlackSilentPro PK-PS 140mm P... Windows 7 x64 Pro Arch Linux x64
Hewlett Packard LP2475W Ducky Shine II Seasonic X750 Lian Li PC-A77A Silver
MouseAudioAudio
Logitech MX Revolution RME Fireface 800 Dynaudio BM6A
i7 2600K Gigabyte GA-Z77X-UD5H Intel HD3000 EVGA GTX980
RAMHard DriveHard DriveCooling
Corsair Vengeance Western Digital Caviar Black WD1600JD Western Digital WD20EARS (2), WD20EARX (1), WD2... Thermalright HR-02
OSPowerCase
Ubuntu Server 12.04 LTS x64 Seasonic X760 Lian Li PC-A77F
Neurosis
(7 items)
Monochrome
(28 items)
Patchouli
(11 items)
RAMHard DriveOS
CoolingCoolingOSOS
MouseAudioAudio
OSPowerCase
post #4 of 10
Crap I deleted mine....
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
AudioAudio
Mouse PadOther
Audio
Built-in
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
AudioAudio
Mouse PadOther
Audio
Built-in
post #5 of 10
Are you using HFM.net? If yes, then you need to update your projectinfo.tab file from here. I'm currently running 6098 and had the same problem. HFM showed 0 credit and 0 ppd.
Blaze
(18 items)
Intel Core i7 Extreme 980X at 4.2GHz Rampage III Extreme NVIDIA GeForce GTX 580 3GB Hydro Copper 2 NVIDIA GeForce GTX 580 3GB Hydro Copper 2
GraphicsRAMOptical DriveCooling
NVIDIA GeForce GTX 580 3GB Hydro Copper 2 24GB G.Skill Ripjaws 1600MHz 8-8-8-24  LG BD Writer EK Supreme HF
3x RX360 + RX480 2x Alphacool VPP655 + EK Dual Top Phobya Balancer 250 28x Gentle Typhoons AP-15
Windows 7 Ultimate x64 Asus VE276Q Razer Arctosa Antec HCP1200 + Corsair CX430
CaseMouse
Mountain Mods Extended Ascension Razer DeathAdder
Blaze
(18 items)
CaseMouse
post #6 of 10
Hello, I started about a week ago here and I have having this issue but with project 7200 on SMP. I have completed this unit like 6 times and under the stats thread, credit is unknown and the PPD is shows as zero. Other projects I have done, i have gotten credit for them and the PPD values update at 3% into the fold.... Project 7200 does not even when it's 70% complete, it does not have a PPD value.
I am using the latest FAH GPU Tracker V2 client
post #7 of 10
I think some of the WUs have issues with calculating PPD but IDK.,
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
AudioAudio
Mouse PadOther
Audio
Built-in
Gsvlip Dudyrm
(15 items)
Oda'maksv
(9 items)
AudioAudio
Mouse PadOther
Audio
Built-in
post #8 of 10
Actually it's just that some of the WUs are not in the psummary or whatever it's called. psummary is just not current. I found this solution from here.
Blaze
(18 items)
CaseMouse
Blaze
(18 items)
CaseMouse
post #9 of 10
Stanford or someone is not updating the link that tells HFM what the point value of the WUs are. There are some work arounds that have been made. I did not check what previous people have linked to but they might be it or you can find it by googleing it.
post #10 of 10
The 6099 is also in that ballpark
been crunching a 6099 for half a day and it hasn't registered any points in HFM. I think The values are just not in the HFM archive
Wet Willy
(17 items)
Oold man 555
(11 items)
i7 920 @4.217 1.24 v's 24/7 Asus p6t6 ws Revolution (full water blocks) GTX 480 SLI @867-1734 samsung 30nm at 2040mhz. 8-9-9-26 1.54v's
Hard DriveOptical DriveCoolingCooling
OCZ Agility 3 RAID0 lite on dvd burner Raystorm Danger Den 480 Full copper (paralleled)
OSMonitorMonitorKeyboard
Dual boot, Windows7 64bit/Linux ubuntu64bit 1hpw2207h1680/1050  Sharp 60" LED 120hz s510
PowerCaseMouseAudio
Ultra 1600w X4 NZXT, Tempest EVO logitech s510 combo Harmon Kardon AVR245
Phenom II X4 B55 m4n82 deluxe ghetto gtx 460 patriot viper 1066
some crap sata dvd thermal take big typhoon windows 7 ultimate
MonitorPowerCase
hp 2207h ultra lsp 750watt cooler master elite
Wet Willy
(17 items)
Oold man 555
(11 items)
PowerCaseMouseAudio
MonitorPowerCase
  Back to Forum: Overclock.net Folding@Home Team
