Overclock.net › Forums › AMD › AMD CPUs › 2800+xp-m ??
2800+xp-m ??
post #1 of 13
Is this a good cpu??? I heard the mobiles run cooler and oc well...picked it up on e-bay and deciding if I wanna get a good board for it...
My System
(3 items)
CPUOS
I7 Q720 Windows 7 Ultimate
My System
(3 items)
CPUOS
post #2 of 13
I've had a 2600 XP-M for a while. Hardly "decent" by todays standards but my system runs pretty well. I can still play any game I've tried (doom3, source, bf2). Ran at 2.65GHz highest I got it on watercooling.
Definantely not as good as your current set up though.
My System
CPUMotherboardOSMonitor
XP-M 2600 NFII Ultra Infinity Windows XP Home Dual 17" CRT
Zboard stock keyset Lim. Edition X-connect Lian Li PC71~MODDED~ Logitech Cordless Optical
My System
post #3 of 13
I have several mobiles, great overclockers, they make good folding rigs.
My System
FX-57 lapped DFI Lanparty NF4 SLI DR 2x7800GT OC 2x512 PNY DDR600
Hard DriveOSMonitorKeyboard
4x36gb Raptors raid-0 2000 pro HP P1100 20 inch Micro wireless
PowerCaseMouse
Antic 550 True Control TT Armor Ge optical
My System
PowerCaseMouse
post #4 of 13
yeh, the sandy is being replaced with an e6600 rig but I haven't gotten into this folding thing ...what's yup with that??? some kinda research thing I gather.
I always have 5-8 rigs around...so maybe I should....
My System
(3 items)
CPUOS
My System
(3 items)
CPUOS
post #5 of 13
Folding is medical reserach.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #6 of 13
oic....numbers crunching... huh...well maybe I'll look into it..ya gotta run a rig 24/7??? kinda off topic on the mobile but maybe I'll use it for that...Can ya get a ""TAX"" credit for folding??
My System
(3 items)
CPUOS
My System
(3 items)
CPUOS
post #7 of 13
The 2800 mobiles aren't any better than an XP series due to the vcore is 1.65 stock, same as an XP. The 2600 and down mobiles are 1.45 vcore stock. Those are the ones you want. 2600, 2500, 2400 are about the best.
My Sandy Rig
(14 items)
Intel i7 2700K 4.8ghz @ 1.32 vcore Asus P8Z68-V/Gen3 PowerColor 7950 Boost Patriot DDR3 1600 4gb x 2
WD 1TB, 750 black LG SATA DVD burner Corsair A70 dual fan 7 Home Premium 64bit
Zalman 23"  Azio PC P & C 750 Silencer NZXT ZERO
MouseMouse Pad
Logitech MX-500 Laser My Desk
My Sandy Rig
(14 items)
MouseMouse Pad
post #8 of 13
oic ...then heat issues...hmmmm..could get my dog to water cool it, he's a good licker...prolly just oc it where i can and drop it in a "for sale" paper ad...where's the info on this folding stuff??
~~edit I found it
My System
(3 items)
CPUOS
My System
(3 items)
CPUOS
post #9 of 13
You want a 2500/2600 1.45v.......2800 (1.65v) is just a desktop chip.
You'll need a decent (NF7-s) board too.
post #10 of 13
If you are going the route of the XP-M chips, be sure to get a quality board for it. The Abit NF7-S ver 2 board is perhaps the best OCing socket A board. If you get a board that doesn't allow for adjusting the multi, you'll end up with a default of 6x and it'll actually become a slower computer. Be sure to get decent cooling on the chip too. They can take quite a bit of voltage, but will also get pretty hot. As others have said the XP-M 2800 series and above use the standard 1.65 voltage, so they don't OC as well. The 2400, 2500, and 2600 series are the better OCers, but you have to also make sure that you're getting the right ones because those also came in standard voltage models as well.
Here is a list from wikipedia on which models take what voltage. Pay attention to the serial number as the first four letters will let you know what voltage it takes and the next four numbers designate which speed it is:
Athlon XP-M "Barton" (Mainstream, 45W TDP, Socket A)
* All models support: MMX, SSE, Enhanced 3DNow!
Model Number Frequency L2 Cache FSB 1 Multiplier Voltage Release Date Part Number
Athlon XP-M 2200+ 1667 MHz 512 KiB 266 MT/s 12.5x 1.45 AXMH2200FQQ4C
Athlon XP-M 2400+ 1800 MHz 512 KiB 266 MT/s 13.5x 1.45 AXMH2400FQQ4C
Athlon XP-M 2500+ 1867 MHz 512 KiB 266 MT/s 14x 1.45 AXMH2500FQQ4C
Athlon XP-M 2600+ 2000 MHz 512 KiB 266 MT/s 15.0x 1.45 AXMG2600FQQ4C
[edit]
Athlon XP-M "Barton" (Desktop Replacement, 72W TDP, Socket A)
Athlon XP-M 2400+ 1800 MHz 512 KiB 266 MT/s 13.5x 1.60 AXMA2400FUT4C
Athlon XP-M 2500+ 1867 MHz 512 KiB 266 MT/s 14x 1.65 2003 AXMA2500FKT4C
Athlon XP-M 2600+ 2000 MHz 512 KiB 266 MT/s 15x 1.65 AXMA2600FKT4C
Athlon XP-M 2800+ 2133 MHz 512 KiB 266 MT/s 16x 1.65 June 7, 2003 AXMA2800FKT4C
Athlon XP-M 3000+ 2200 MHz 512 KiB 266 MT/s 16.5x 1.65 2003 AXMA3000FKT4C
[edit]
Athlon XP-M "Barton" (Low Voltage, 35W TDP, Socket A)
Athlon XP-M 2200+ 1667 MHz 512 KiB 266 MT/s 12.5x 1.35 July 13, 2004 AXMD2200FJQ4C
Athlon XP-M 2400+ 1800 MHz 512 KiB 266 MT/s 13.5x 1.35 AXMD2400FJQ4C
X2 5000+ BE Gigabyte GA-MA78GM-S2H AM2+ Integrated HD3200 2x2GB OCZ DDR2
Hard DriveMonitorPowerCase
Maxtor 40GB Samsung 2220WM 22" Antec Neo HE 550W Ultra Wizard
  Back to Forum: AMD CPUs
