Overclock.net › Forums › Intel › Intel CPUs › 486 cooling
486 cooling
post #1 of 11
what kind of cooling goes on a 486? i don't see any trace heat sink compound or a spot for the sink to latch on to. should i use a pentium 1 heat sink that sticks to the cpu or did they not have heat sinks on older ones
e2140 P5N32-SE SLI Deluxe 8500gt super+ 1gb 4gb 2x buffalo 1x rendition, 1x kngstn valueram
160gb seagate dvd-rw and a false cd drive like in sig xp home oem samsung crappy POS
really bad crappy some piece of crap i got for cheap bad
Mouse Pad
bad
Mouse Pad
bad
post #2 of 11
I doubt they had hs's on the older ones...
Optiplex 790
(6 items)
Some shit.
(7 items)
E7200 3.6GHZ 9*400 1.25v Gigabyte P35-DS3R BFG 9800GTX OC 2*1GB Kingston HyperX D9GKX 1200MHZ C5, 2.0V
80GB WD SATAII NEC 3550A DL DVD+/-RW Win XP Home HP W2007
Microsoft Digital Media Pro XClio Goodpower 500W Cooler Master Centurion 5 Logitech G5
CPUGraphicsRAMHard Drive
i5 2400 Sapphire HD6670 LP 4GB DDR3 500GB 7200RPM
OSMonitor
Windows 7 Professional 2 x Dell 2408WFP
i5 3317U HD4000 4GB DDR3 128GB SSD
Optical DriveOSMonitor
Who needs one? OSX 10.8 11" 1366x768
Optiplex 790
(6 items)
Some shit.
(7 items)
OSMonitor
post #3 of 11
Double sided thermal tape
i5 2500k @ 4.5GHz 1.4v ASRock Z68 Extreme3 Gen3 MSI R9 290x Gaming 2x4GB Corsair XMS3 1600
Hard DriveHard DriveCoolingOS
Crucial BX100 250GB Toshiba 2TB Thermalright Macho 120 Rev.A Win 10 Sexy Phwoar bits
LG 29UM68 (2560x1080) Logitech MK600 SuperFlower GG HX 650W FD Define R4 White Window
MouseMouse PadAudioAudio
Logitech G502 CM SWIFT-RX XXL Cheap USB DAC Epiphany Acoustics EHP-O2
Audio
AKG K612 Pro
Audio
AKG K612 Pro
post #4 of 11
They do not need heatsinks Lol
They dont get hot enough, I might dust off the old 386DX today, got some prince of persia and transport tycoon to take care of
C2D E6600 @ 3.2ghz 458fsb Gigabyte GA-965P-S3 Vmod Evga 8800gtx @ 752 / 2028 2gb G.Skill PC6400 HZ
2x wd80 Pioneer dvd-r+ xp 22" Mitsubishi crt 1920x1440
Logitech TT Toughpower 750W Floor.... Laser
post #5 of 11
Hmm, thats strange cause my old one had a small 40mm gold heatsink and fan...
Doesn't suck
(12 items)
XPS L702X
(9 items)
i7 4770s 3.1Ghz Gigabyte B85M-D3V RX480 8gb 16GB
128GB SanDisk SDSSDHP128G Matshita DVD-Ram Stock Windows 10 Pro
G19 APEVIA ATX-AP900W Cooler Master Microsoft Optical Wheel Mouse
Intel Core i7-2670QM GT555M 8GB  2 x Seagate 7200RPM 500GB
Optical DriveOSMonitorKeyboard
BluRay combo drive Windows 7 Premium 17" Laptop + 24" 1920x1080 Dell Backlit laptop keyboard
XPS L702X
Doesn't suck
(12 items)
XPS L702X
(9 items)
XPS L702X
post #6 of 11
now that brings back distant memories of my first PC encounters
Desktop
Opteron 165 CCBBE 0615DPMW 2.6GHz (9x290) DFI NF4 SLI-D (HR-05-SLI Passive Chipset Cooler) BFG 8800GTS OC 640MB 620/1860 Mushkin Redline 4x1GB DDR475 (3-3-2-7 2T)
3x 74GB WD Raptor (RAID 0) + 2.2TB of SATA HDDs NEC DVD/RW SATA XP Home Edition SP3 IIyama H481S 19' TFT 1280x1024
Eluminix (Backlight) OCZ Modstream520w 28A,12v Single Rail Antec P182 Razer, Copperhead Blue
Mouse Pad
Razer Exactamat
Desktop
Mouse Pad
Razer Exactamat
post #7 of 11
My 486 DX4-100 did not have a heatsink on it.
Sig rig
Intel Q6600 G0 23A Asus P5K Deluxe Wifi HD 3870 2x2 GB G.Skill DDR2-800
2x250 GB Seagate RAID 0 + 320 GB Seagate Samsung SATA DVD Windows XP Pro/Vista Ultimate 64 bit Viewsonic VA2012wb
Saitek Eclipse Corsair HX620 Lian Li V2000b Logitech G7
Sig rig
post #8 of 11
Outside of the rare passive CPU heat sink, the only cooling in the old AT cases were the single 80mm PSU exhaust fans. Heat wasn't really an issue because viable overclocks weren't even an option without major chip/socket replacement = days of desoldering.
post #9 of 11
my 386sx (16mhz) has no cooling on it... still runs wolfenstein3d like a charm (thats the only reason im keepin it)
Optiplex 790
(6 items)
Some shit.
(7 items)
OSMonitor
Optiplex 790
(6 items)
Some shit.
(7 items)
OSMonitor
post #10 of 11
For 486's, you don't need a HS up to about 40-50 MHz. 50 and beyond should have one. 486's mostly used a passive HS, although some, especially 100-133 MHz, used a small active HS. If yours is a 3.3v part, (most of the slower ones are 5v) up to maybe 75MHz is safe.
Most 486 HS have some sort of clip that grabs the edges of the cpu, since sockets 1-3 do not have tabs on them. Some just use metalized double sided tape. I used to pick up discarded PCs all the time, and have seen a few 486-66's with nothing. Careful, though, even a 33MHz 486 with nothing gets extremely hot.
btw, i've found that most 5v 486's will run perfectly stable and much cooler on 3.3v.
E4300 @ 2.64 GHz ASUS P5LD2 Evga GeForce 7950GT 512MB 2 x 1 GB PQI TURBO DDR2 800
2x Seagate Momentus 7200.3 in RAID 0 Samsung lightscribe DVD burner intel stock Cu core with old 3 blade Thermaltak... Windows 7 Ultimate 64 bit
Samsung SyncMaster B2230HD Dell Dell 350W generic
MouseMouse PadAudio
logitec The desk Creative SBLive!
MouseMouse PadAudio
  Back to Forum: Intel CPUs
