Overclock.net › Forums › Graphics Cards › AMD/ATI › 39C load ??
39C load ??
post #1 of 8
i bought some used 3850 powercolor
the temps dont even hit 40 on any stress test
is it some epic card or bad sensor
Rated
E5700 @ 3.5Ghz Gigabyte G41M-ES2L ASUS GTS250 2GB
Hard DriveOSMonitor
400GB SATA Samsung Win XP 32bit 1080p
Rated
Hard DriveOSMonitor
post #2 of 8
What does it hit at load and if you say 39oc then there is your answer.
When its loading most parts will be under heavy load for graphical and for processing to load in all the programmes and for the desktop e.c.t.
so 39on the gpu is not bad.
post #3 of 8
tbh load temps 39 max is someting i never seen , all gpus i had (over 15) was at 60+ at load and rised fast as i speak..
Rated
Hard DriveOSMonitor
Rated
Hard DriveOSMonitor
post #4 of 8
another thing , is atitool fails to load with card , rivatuner fan control dont work too umm
Rated
Hard DriveOSMonitor
Rated
Hard DriveOSMonitor
post #5 of 8
Powercolor 3850 uses a Zerotherm heatsink fan and so it performs much better than the stock one.
Many reviews showed that the load temp is in this range of 54-64C, depending on the ambient temp and the loading software.  So, unless your ambient temp is a much lower than average, I suspect the sensor might be a little off to give a load temp of 39C.
The reviews below all used RivaTuner to check the temp.  Two reviews mentioned that the fan runs at 100% power/rpm all the time and cannot be controlled, in its default state.
So, I suppose you will have to devise a way to control the fan speed.
Reveiw links:-
http://xtreview.com/review219.htm
http://ixbtlabs.com/articles3/video/rv670-part2-page1.html
http://www.guru3d.com/article/amd-ati-radeon-3850--3870-review/8
post #6 of 8
Uninstall everything, Catalyst, Ati Tool and whatever third party softwares installed.
Install this Catalyst package then make sure the clocks are full throttle. Check the temperatures again under load.
http://sites.amd.com/us/game/downloads/Pages/radeon_win7-64.aspx
ケンジ
(16 items)
CPUCPUMotherboardGraphics
i7-3960X i7-980X GA-X79-UD7 / GA-X58A-UD9 7970 + 465
GraphicsRAMRAMHard Drive
2x 6990 + 580 16GB 2133 MHz 24GB 2000 MHz 120GB x 2 RAID0
Hard DriveHard DriveCoolingCooling
120GB x 4 RAID0 Raptor 300GB x 2 RAID0 CPU-370 CPU-370
CoolingCoolingOSPower
VID-AR699 EK FB X58A-UD9 Win 7 Ultimate x64 1500W / 1250W+1200W
ケンジ
(16 items)
post #7 of 8
well i realised than i cant control fan , the voice is anyoing but it does job on temps flawlessly atleast . i might later connect fan to power suply medium speed which is easy. t
thx for answers
Rated
Hard DriveOSMonitor
Rated
Hard DriveOSMonitor
post #8 of 8
btw it idles at 25C , and i guess its correct ,card is pretty cold ;o
Rated
Hard DriveOSMonitor
Rated
Hard DriveOSMonitor
  Back to Forum: AMD/ATI
