Overclock.net › Forums › Components › Computer Room / Office › £15 desk :/
£15 desk :/
post #1 of 7
Hi,
I just got a CRT monitor for my PC...and that thing is HUGE.
As such I need to upgrade to a bigger and better desk...preferably a corner desk.
Anyone know where I can get one in the UK for £15 or if I can build one for £15?
post #2 of 7
Buy a door blank and prop it on some filing cabinets.
post #3 of 7
Unfortunately I have no filling cabinets XD
I was really hoping I'd be able to build a cheap corner desk for £15... literally just need a corner desk with room for monitor, keyboard and mouse XD
post #4 of 7
Buy an 8 by 4 bit of 22mm MDF from B&Q and just build one. I'm sure last time I checked they were like 18 quid.
Current Setup
Intel i5 2500k @ 4.5GHz Asus P8Z68-V PRO 2 x inno3d GTX 570's in SLi 8Gb G.Skill RipjawsX CL9 @ 1600MHz
Hard DriveOptical DriveOSKeyboard
2 x 1tb WD SATA-III & 2tb Samsung SATA-II Sony Optiarch Windows 7 64-bit Razer Black Widow Ultimate
PowerCaseMouseMouse Pad
OCZ Fatal1ty series 750W Modular NZXT Phantom Enthusiast Razer Naga Razer Goliathus (largest version)
Current Setup
post #5 of 7
Okay...you sure that's going to be able to support the weight of a medium sized CRT telly...cus that's pretty much what my monitor is...
post #6 of 7
Look in for sale adds locally or 2nd hand stores
My System
phenom 1055t 95watt asus crosshair v formula 6950 2gb (unlocked) 4gb gskill ripjaws cl7
Hard DriveCoolingOSMonitor
120gb corsair force 3 + 750gb wd black corsair h100 (cpu) antec 620 (gpu) windows 7 x64 home premium 19" hd tv
PowerCase
corsair hx 850 modular haf x
My System
PowerCase
post #7 of 7
I can get a 8x4 25mm sheet of MDF for £30...
Other than B&Q...anyone know where I could get an 8x4 sheet of thick MDF or stronger wood for £15?
  Back to Forum: Computer Room / Office
