Overclock.net › Forums › Benchmarks › Benchmarking Software and Discussion › 9779 in 3d 06 mark.
9779 in 3d 06 mark. - Page 3
post #21 of 30
Originally Posted by alexisd
Look like my card's that's the max working in the memory department to see if can go up in those scores.I did a fresh windows install would see.And you using the monster 6300 C2D.Nice
E6600
If you've tried a fresh install and you card can't go higher then it looks like you're alrready topping out. as 3DMark2006 is heavily GPU intensive I don't think you'll be able to get that much more even if you overclock the CPU more.
post #22 of 30
testing link.http://service.futuremark.com/orb/pr...08&UID=6612924
My System
E6850 SLA,G0,@3.7 P5N32 SLi/680iSB=Jing ting/nb=spirit II[1203]bios] MSI 470 GTX[order on his way] 4 gig ocz Reapers pc 8500
Hard DriveOSMonitorKeyboard
2 WD 250gig 16mb/raid 0\1 WD640 AALS 32MB win xp pro sp3/Windows 7 Beta LCD,22"=Samsung 2MS,226BW,52"samsung LN5A550 Thermaltake xaser
PowerCaseMouseMouse Pad
oczgamexstream700 wtt x blade/modded Razor deathadder thermaltake gamer pad/led
My System
post #23 of 30
Use 84.56 and install through control panel.
Set your graphics card as a 7900GT.
#well
(18 items)
Lenovo L530
(8 items)
Intel Core i7 4770k Gigabyte Z87X-UD4H Sapphire RX 580 Corsair CMX8GX3M2A2000C9
Samsung 840 EVO Generic DVD±RW Burner Noctua NH-D14 Windows 10
MonitorMonitorKeyboardPower
Dell U2711 Samsung SyncMaster 2233 Ducky DK9008 Overclock.net Edition, Cherry MX B... Corsair TX850
CaseMouseMouse PadAudio
Fractal Design Core 2500 Logitech G303 QPAD HeatoN L M-Audio Fast Track USB
AudioAudio
Beyerdynamic DT-770 80 Ohm AntLion ModMic v3
CPUGraphicsRAMRAM
Intel Ivy Bridge 3210M Intel HD 4000 Graphics Soldered Corsair Vengeance
500GB DVD-+RW Windows 7 Professional 1600x900
#well
(18 items)
Lenovo L530
(8 items)
AudioAudio
CPUGraphicsRAMRAM
post #24 of 30
I pass that one.Work if I put 7900GT because mine 7950GT is no there.
My System
My System
post #25 of 30
Overclocking your cpu won't help all that much in the FPS scores, but 1/3 of the test of 3m06 is CPU score. Overclocking your cpu another 200 mhz will give you about another 150 pts in that category, hence raising your overall score.
I'm just pushing 10k with 2 7900gtx so 9.7k on a 7950 is pretty kick ass.
My System
Athlon64x2 4800AM2 2.4Ghz DFI LP NF590 SLI-M2R/G xfx 7900gtx & bfg 7900gtx 2GB Corsair 6400C4Pro
2 x RaptorX 150 XP home 32 bit Acer 24" LCD AL2423W Saitek Backlit keyboard
PowerCaseMouse
TT Toughpower 750 Antec Nine Hundred Razer Copperhead
My System
PowerCaseMouse
post #26 of 30
I went up in the cpu and gain some point's,the cpu is no stable @ 2.8 but I know is memory,mine memory the xms are @ max rigth now.Going to try my G.skills later this week as long I have to reset cmos don't want to do that today.And thank's for your comments. Want to run the g skills with no divider and x11 in the cpu to see if I can get the 10,000.And you run those benches @ 3.12?
My System
My System
post #27 of 30
Originally Posted by FrankenPC
Prior to Conroe, only AMD's could do that on the ASUS SLI. One of these days, I'll get a Conroe and "go for the gold".
AMD + Crossfire worked darn nice also
I got 10k with an Opty 170 at 2.9 GHz and dual X1900's. You should be able to get it at 2.9 or so.
Here is my score of 10,098 with the Opty:
http://service.futuremark.com/compare?3dm06=346565
It seems to be the SM3.0 score that's holding you back. You beat my SM2.0 score and are close to my CPU score (which does not weigh too heavily). Iwould have expected better SM3.0 from 7950's. At this point, does not seem a whole lot better than volt modded 7900's
E8400 @ 3.8 GHz DFI LANPARTY DK X38-T2R eVGA 8400GS 2GB Mushkin DDR2 800 (single stick)
250GB WD SATA None Windows XP Pro 32-bit HP Pavilion f1703
N/A Corsair HX520 Coolermaster Cavalier N/A
Mouse Pad
N/A
Mouse Pad
N/A
post #28 of 30
So far only in the top 30 GPU systems the s dumper and the viper use the 7900GT volt mod and beat the 7950GT S dumper with theC2D andViper @ 2.9 or so that mean,my case I think is memory related?Don't you think?
My System
My System
post #29 of 30
Yah all those the benches I've put were at 3.12Ghz with ram at 4,4,3,4,11 @1040Mhz.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #30 of 30
im @ 2.7 that's mean is no that bad.
My System
My System
