Overclock.net › Forums › Cooling › Air Cooling › 54C Idle 1090T
54C Idle 1090T
post #1 of 15
I recently upgraded my motherboard, and ever since my cpu temperatures are ridiculously high. It is 54c idle, figured I put too much paste on, so after about a week I put fresh coat on and tried again. It continues on. My old board, with the same cooler and same paste, ran around 20c cooler, but I'm figuring the sensors were off. That board was jacked and showed really messed up data, so now I am thinking my current cooler has always kept it at 53c, but I just never knew. I don't know what to think anymore. Anyone have any suggestions besides getting a new cooler, because I'm broke at the moment.
Mine
(19 items)
Intel Core i7-6700K 4.0GHz Quad-Core Asus Z170 PRO GAMING ATX LGA1151 EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200
PNY CS1311 480GB SSD Barracuda 500 WD 1000 WD 1000
CoolingOSMonitorMonitor
Thermalright TRUE Spirit 140 POWER 73.6 CFM Windows 10 Acer S277HK 27" 4K Acer 23" 1080p
Acer 23" 1080p Razer Black Widow Ultimate EVGA SuperNOVA G2 550W 80+ Gold Corsair 330R Titanium Edition ATX
Mouse
Logitech G303 Daedalus Apex
Mine
(19 items)
Mouse
post #2 of 15
Soooo... what kind of CPU cooler do you have?
Sager NP8652
(12 items)
Intel Core i7 4720HQ P65_P67SG Nvidia GTX 980M 16GB DDR3 1600mhz
Hard DriveHard DriveOSMonitor
Crucial MX100 512GB 500GB HDD Windows 7 x64 Home AOC Q3277FQE
KeyboardMouseMouse PadAudio
Sentey Cobalt Pro Mionix Naos 7000 Steelseries QK Mini Steelseries Arctis 3
Sager NP8652
(12 items)
post #3 of 15
It's possible the mobo BIOS or sensor is off. Are you using Core Temp to read the cores?
post #4 of 15
What software are you using to monitor the temps and have you contacted ASUS or AMD?
post #5 of 15
The ASUS board is the one I replaced. I changed it in my rigbuilder, but for some reason it isn't showing it correctly on my sig. I use GIGABYTE GA-990FXA-UD3.
As for the temp software, I use AMD Overdrive.
Basically, I was getting a ridiculous amount of blue screens. I've always had a problem with my ASUS board, I just never felt it was worth RMA'ing or dealing with. Though, a few sticks of my RAM decided to blow out, and I've had to replace a perfectly good power supply with that board as well. It also showed my voltages being 4+ lower than it should be, but my vmeter showed my PSU was putting out the proper amount. So, I figured I should go ahead and replace my board. Since the replacement, the voltages show correctly, and the blues screens stopped. Problem is, the temperature is showing much, much, higher than my old board. So either I put the heatsink back on improperly (twice) or my old board was such trash that it was reading the temps wrong and my new board is actually correct. I'm figuring my temps have always been this high, just never knew it.
Edited by Zinxe - 3/14/12 at 5:59pm
Mine
(19 items)
Mouse
Mine
(19 items)
Mouse
post #6 of 15
Temps are way too high. (or do you live directly on the equator and use your computer outside?)
You should check your CPU temps in the BIOS under component Health (something like that)
Normal would be 30ish in the BIOS
I don't use AMD Overdrive to check CPU temps. Does it do CPU or are you looking at your GPU temps
post #7 of 15
If your running your cpu at stock and have an aftermarket heatsink your temps should be in the low 30c idle.
Try using cpuid hardware monitor and see what the temps are on there.
http://www.cpuid.com/softwares/hwmonitor/versions-history.html
R2D2
(17 items)
R2D2
(17 items)
post #8 of 15
Hwmonitor screenshot
post #9 of 15
I've got the same board and processor and I'm idling ~31°C. Try using EasyTune from Gigabyte, that helps me check temps. HWMonitor doesnt show any temps for my processor??? confused.gif
The Green Box
(19 items)
Intel 4770K ASUS Gryphon Z97 mATX ASUS GeForce GTX 780TI-DC2-3GD5 ASUS GeForce GTX 780TI-DC2-3GD5
g.skill 16gb 1866mhz Seagate 1TB Samsung 60GB SSD Seagate 2TB External
Hard DriveOptical DriveOptical DriveCooling
OCZ 120gb Vertex 3 SSD Lightscribe CD/DVD R/W ASUS Bluray R/W Corsair H80i with 120mm (x2) Noctua Fans
OSMonitorKeyboardPower
Windows 8.1 Pro ASUS VG278HE & HP 2009m Saitek Eclipse II Corsair 850W
CaseAudioAudio
Bitfenix Phenom M NVIDIA Special Edition M-Audio AV40s Polk 10" Powered Subwoofer
The Green Box
(19 items)
CaseAudioAudio
post #10 of 15
I used this cooler for a while, but the stock cooler worked better by about 10c.
Also, I know it says "Russia", but I'm in the states. I just named it Russia, and gave my hd's Russian city names. biggrin.gif
Edited by Zinxe - 3/22/12 at 9:09pm
Mine
(19 items)
Mouse
Mine
(19 items)
Mouse
  Back to Forum: Air Cooling
