Overclock.net › Forums › Intel › Intel CPUs › 2550k Core Voltage lower on load and higher on idle???
post #1 of 11
can someone help me understand why my core voltage is 1.360v when it is on idle and 1.336v when i'm stress testing using prime 95 small ffts and IBT?
IDLE
347
LOAD
340
bios settings if it is relevant
450
450450
450
i5-2550k @ 4.5GHz - 1.375v Asus P8Z68-V Pro/Gen3 EVGA GTX 980 Corsair 8GB Vegeance DDR3-1600 1.5v
Hard DriveHard DriveHard DriveCooling
Crucial 128GB SSD Two 2TB Samsung F4 HDDs 3TB Toshiba HDD Noctua NH-D14
OSMonitorMonitorKeyboard
Windows 7 x64 Ultimate QNIX QX2710LED Achieva Shimian QH270-LITE Ducky Shine II Brown MX Switches w/ Green Backl...
PowerCaseMouseMouse Pad
Seasonic X750 Corsair 400R Logitech G500 Steelseries
AudioAudioAudioAudio
Gustard H10 Headphone Amplifier Audio-Technica AD900X HE-560 Headphone Sennheiser HD 650
post #2 of 11
faulty mobo?
mobos do funny things as long as its not a major heat problem on your mosfetts i woulds stress about it
Bernice
AMD Athlon II X4 635 Foxconn Aloe 1.01 Radeon HD 4350 Kingston ddr3 2gb X3
Optical DriveOSMonitorKeyboard
Light scribe Windows 7 Home Premium Asus VW246H, Dell 17" Hp stock
CaseMouse
stock hp pavillion e9300z HP stock
Bernice
CaseMouse
post #3 of 11
When the system is put under load, the vcore drops. It's called vdroop. It's normal.
SB goodness
(14 items)
Core 2 duo
(9 items)
folder
(8 items)
2500k @ 4.6ghz,1.47v 24/7 GIGABYTE GA-P67A-UD4-B3 $200 EVGA GTX 970 SSC @ 1505mhz 16gb 2400 SuperSC DDR3
Hard DriveCoolingOSPower
960gb Sandisk Ultra II Corsair H100i v2 Windows 7 64-bit SeaSonic X650 Gold
CaseMouseMouse Pad
Obsidian Series® 750D Airflow Edition Zowie FK 2 Speed by Surface/Steelseries SX/Steelseries 9HD
Core 2 Duo E6750 Asus P5n32-e SLI EVGA 8800gt superclocked @ 750/725 gaming/folding 4gb Fatal!ty ddr2 800
64gb SSD Stock Win 7 64 bit Corsair CX500
NZXT
Intel Pentium E6300 MSI G41M4-F GTX 460 2gb A-data ddr2 800
Hard DriveOSPowerCase
150gb raptor Ubuntu 13.04 64-bit Coolmax 520W NZXT
SB goodness
(14 items)
Core 2 duo
(9 items)
folder
(8 items)
CaseMouseMouse Pad
NZXT
post #4 of 11
Put load line calibration on the next step up (I think it's ultra high?) and it should fix the problem.
By the way, you should OC with offset voltage. You get low voltage and low clockspeed then it ramps up perfectly fine. Saves power and extends lifespan of the system biggrin.gif
Eff You Intel
(14 items)
FreeNAS
(9 items)
Beast
(14 items)
AMD Ryzen 7 1700X AsRock X370 Taichi Sapphire R9 Fury Tri-X OC 32GB (2 x F4-3200C14D-16GFX)
Plextor M8Se(G) 1TB People still use these? lol Cryorig H7 Winblows 10 Professional X64
Pixio PX277 Logitech G510 Seasonic SS-860XP2 Fractal Design Define C TG
MouseMouse Pad
Logitech G500 Xtrac Ripper
Intel Xeon E3-1245 v5 SuperMicro X11SSM-F-O C236 Integrated 2 x 16GB Kingston ValueRAM ECC KVR21E15D8/16
5 x 8TB Seagate IronWolf Pro in ZF2 Array CoolerMaster Hyper 212 Evo FreeNAS 11 EVGA SuperNOVA G2 550W Gold
Fractal Design Node 804
i7 4790k Asus Z97 Pro WIFI-AC Sapphire Nitro Radeon R9 Fury Tri-X OC+  G.Skill 4 x 8GB F3-2133C9D-16GXH
2 x Intel 730 480GB SSD in RAID 0 Asus DRW-24B1ST/BLK/B/AS Noctua NH-D15 Winblows 10 Pro x64
Pixio PX277 Logitech G510 Seasonic SS-660XP2 Fractal Design R4 Blackout
MouseMouse Pad
Eff You Intel
(14 items)
FreeNAS
(9 items)
Beast
(14 items)
MouseMouse Pad
MouseMouse Pad
post #5 of 11
thanks. i put the load line calibration up one and it fixed it. i would go for an offset overclock for reasons like you say but i find it requires more time to get it right and this quick overclock was so i could play The Last Story on the Dolphin emulator with near perfect FPS redface.gif
post #6 of 11
Fixed it is the wrong way to think about it IMO. Intel incorporated the droop in the design to allow for voltage spikes when load changes suddenly. It is perfectly fine (and maybe better for longevity) to have a droop in the voltage under load.
post #7 of 11
ok so i took what you said into consideration and changed it back. now would i say i got 4.6ghz at 1.370v (in the bios) or 1.336v under load (cpu-z)? which would be correct in saying so?
post #8 of 11
1.336v under load. When it isn't under load the voltage is less relevant - there is less current and less heat generated. Especially if you are using offset mode and have one of the power savings states or EIST enabled - then when not under load, Vcore will be automatically lowered.
Edited by GeneO - 4/1/12 at 9:23pm
post #9 of 11
Strange - then again, my i5 750 on my MSI board has a similar issue - the voltage under load is higher than at idle, whereas Intel's vDroop spec is to lower the operating voltage under load. Probably a BIOS update may fix the issue?
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Core i5 4690K ASRock Z97 Extreme4 XFX Radeon 7950 32 GB DDR3-2133
Samsung 850 EVO SSD Samsung DVD/CD-writer Corsair Hydro H60 Windows 7
MonitorMonitorPowerCase
ASUS PA248Q Dell U2412M XFX 850W Black Edition XXX Fractal Design Arc Midi 2
Pentium Dual Core E6700 MSI G41M-P33 Combo ATI HD4350 Kingston ValueRAM DDR3-1333
RAMHard DriveOSMonitor
Kingston ValueRAM DDR3-1333 WD Caviar Blue Windows 7 64-bit Sony 32" TV set
Apex TX-381
CPUGraphicsRAMHard Drive
Core i5 430M GT230M (1 Gb dedicated) 8 GB DDR3-1066 640 GB
OSMonitor
Windows 7 Home Premium (64-bit) 15.6"
4690K System
(12 items)
HTPC
(9 items)
HP dv6 laptop
Apex TX-381
OSMonitor
post #10 of 11
Do you have offset voltage and one of the power savings states (C1E, C3 or C6) or EIST enabled? If so your idle Vcore will be less than your load Vcore as it will be dynamically lowered when idle. Otherwise the idle should be higher than the load.
The OP has a lower Vcore under load but is not using offset voltage.
  Back to Forum: Intel CPUs
