Overclock.net › Forums › AMD › AMD - General › 4100 and 6790
4100 and 6790
post #1 of 26
would a FX 4100, radeon hd 6790, and 8 gigs 1600mhz ram be enough for bf3? i will probably oc the 4100, and i dont plan on playing at full 1920 x 1080, so will it be enough?
post #2 of 26
Yes. I'd recommend getting an i5-2500k though. Or even an i3-2100 would be better than the AMD processor for BF3.
Word Processor
(25 items)
i5 2500k @ 4.5 Ghz 1.43v asrock z77 pro4-m Zotac GTX 780 2 x SAMSUNG 4GB 240-Pin DDR3 SDRAM DDR3 1600 @ ...
Crucial M4 128 Samsund 840 Series Seagate ST300DM001-1CH166 Seagate ST4000DM000-1F2168
Hard DriveCoolingCoolingOS
HITACHI Deskstar 5K3000  Cooler Master Hyper 212 Plus NZXT Sentry Mix Windows 7 64 bit
MonitorMonitorKeyboardPower
SAMSUNG ToC Rose Black 27"  ACHIEVA Shimian QH270-IPSB Rosewill Cherry MX Brown SeaSonic X750 Gold 750W
CaseMouseMouse PadAudio
Fractal Define XL Titanium Grey Anker High Precision Laser Gaming Mouse  XTRAC Pads Ripper XXL Audio-Technica ATH-M50
AudioAudioAudioAudio
FiiO E10 Pioneer VSX-1021-K Energy Take 5 Classic BIC America F-12
Audio
Pioneer SP-FS52-LR Andrew Jones Designed
Word Processor
(25 items)
Audio
post #3 of 26
Yes it is, but the only way to know for sure is to load it up and give it a try thumb.gif
post #4 of 26
hmm i dont think you could be able to max out with AF and AA on wink.gif the best setting you may get is high-ultra setting somewhere in middle and i really think its upon the user what FPS he/she thinks is playable i have seen people calling 60FPS playable and people saying 30FPS is playable were as generally 30FPS + on a AVG is preferred in my suggestion
but i would highly recommend a 6850 if you have not bought the 6790 it would cost you mere 10 or 20$ but is worth the money and 6850 is minimum recommended fro 1080p res thumb.gif and for CPU if you have not setup one then get a 960T and overclock it which will give you overall a better performance then the 4170 redface.gif
post #5 of 26
BF3 likes cores and disregards Ht completely. 4100 has an edge.
post #6 of 26
alright thank you guys, im on a budget, and i havent pulled the trigger. i think if these hd prices go down, ill get the 4100, and the 6850. ty though thumb.gif
post #7 of 26
hm were are you from anyways ???? thinking.gif that was a good move going for 4100 which is the same just underclocked and a 6850 smile.gif even a cheap 955 BE would do buddy but a 960T is recommend what parts do you have in mind we might just be able to adjust a few things and get and get both 960T and 6850 together or even better wink.gif
Edited by Tarun - 4/3/12 at 1:19pm
post #8 of 26
The 960T would be better the the FX-41** when it come to gaming.
HTPC
(11 items)
CPUMotherboardRAMHard Drive
AMD A-3870K AsRock A75 Pro (FM1) HyperX DDR3 1866 8 GB SAMSUNG 830 256gb
SAMSUNG EcoGreen F4 2TB Plextor Black Blu-ray Burner Phenom II X4 stock Cooler Windows 10
MonitorPowerCase
LG M2762D-PM Glossy Black 27" 5ms (1920x1080) Antec HG 900 Gerenic ATX Case
HTPC
(11 items)
MonitorPowerCase
post #9 of 26
ok, then if i get a 960T, what would be a good mobo that can unlock the cores for under 100. Also would be good for sata 3 and usb3
post #10 of 26
BIOSTAR TA990FXE is around $100.
HTPC
(11 items)
MonitorPowerCase
HTPC
(11 items)
MonitorPowerCase
  Back to Forum: AMD - General
