Overclock.net › Forums › Case Mods & Cases › Builds & Case Mods › Case Mods › Case Mod Work Logs › 810 Degrees Below
810 Degrees Below
post #1 of 10
This will be my first ever case mod and I have been forever wanting to do a build with a white switch 810 and a blue/black liquid cooling and hardware setup. Now seeing that I am a student and am dead broke, this is simply a list and a place to organize everything together, but fear not. When I get some cash and time there will be pics galore.
Hardware
1x Nzxt Switch 810
1x Western digital Caviar Black 2tb HDD
1x Corsair AX1200
1x EVGA GTX680 (Possibly 2)
1x G.Skill Ripjaws X Series 32GB (4x8GB) DDR3 1600
1x MSI Z77A-GD65
1x Intel Core i7-3770k
1x Asus Black Blu-ray Burner
12x Enermax Vegas duo 140mm
Liquid Cooling
1x Black Ice GT stealth 360 radiator Blue
1x Bitspower D5 / MCP655 Pump Mod Kit + D5/MCP655 Mod Top V2 w/ D5 Variant Pump Installed
Pump Top Style: Pump Mod Top V2(G1/4) - Acetal
Mod Kit Style: Pump Mod Kit - Blue
Pump Type: Swiftech MCP655 Variable Speed
1x XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block
25 Feet of Tygon R-3603 (3/4 OD) Tubing
2x Monsoon Free Center Compression Fitting - 1/2"ID x 3/4"OD - Modders 6 Pack White
2x EK-FC680 GTX - Acetal+EN
1x FrozenQ Reservoir (Not sure which one yet)
2x Mayhems Aurora Nebula Blue Dye
Other Mods
MDPC-x black Heatshrink
50 feet of White/Black/Blue 550 Paracord Mil-Spec Type III 7-Strand
Ideas
El wire to produce glow from front edge
Illuminated midplate (White or blue, maybe switchable)
Thats it for the start of this mod. I hope to be able to get the case pretty soon and then from there its whenever I can acquire the cash...so it will be awhile...Any suggestions or ideas would be much appreciated and welcomed.
Edited by germish12 - 4/24/12 at 9:43pm
post #2 of 10
post #3 of 10
An i7-3930k its a hexcore sandy bridge. I will fit
post #4 of 10
No, it won't fit. The 3930K is an X79 LGA2011 CPU... that board can only take LGA1155 CPU's... the cpu's you need to be looking at are the 2500K, 2600K and those that are in that processor family...
To see the CPU's that board in particular supports... please go here
post #5 of 10
Right. My bad wasn't paying attention this morning and las night. So I will be using an i7-2700k thanks for that.
post #6 of 10
May as well go for ivy. Make use of pci 3.0.
Big Blue
(18 items)
2600k 4.6GHz @1.4 P8Z68-V PRO/GEN3 EVGA GTX 670 FTW 16GB G.Skill Ripjaw X @1600
500GB WD Caviar Blue SATA III 128GB Crucial M4 SATA III Some LG thing Corsair H100
OSMonitorMonitorMonitor
Windows 7 Ultimate 64 Bit Samsung Syncmaster BX2231 Samsung Syncmaster BX2231 Samsung Syncmaster BX2231
Logitech G510 Corsair TX-750 Antec Twelve Hundred Logitech G9X
Other
Logitech G13
Big Blue
(18 items)
Other
Logitech G13
post #7 of 10
Core i7 3770K
WC
(11 items)
CPUMotherboardRAMHard Drive
Intel Core i7-3770K GIGABYTE GA-Z77X-UD5H SAMSUNG 16GB 30NM OCZ Vertex 4
Western Digital Caviar Black LITE-ON 24X DVD iHAS224 XSPC RayStorm RX360 RX240 Windows 8
MonitorPowerCase
CROSSOVER 27QLED SeaSonic Platinum Platinum-860  NZXT Switch 810 White
WC
(11 items)
MonitorPowerCase
post #8 of 10
When is that coming out...I haven't been following it since they pushed the dates back...I can't seem to find it on newegg or tigerdirect
post #9 of 10
wasn't it the 29th?
post #10 of 10
Thought it was supposed to be sometime in february initially...But I could be getting it confused with the gtx 600 series from nvidia.
  Back to Forum: Case Mod Work Logs
