Overclock.net › Forums › AMD › AMD - General › 8120 or 960T?
8120 or 960T?
post #1 of 35
I have a Microcenter near me, so I can take advantage of their AMD bundles. Either chip would be paired with a GA-990FXA-UD3, with the difference in price being $60, cheaper in favor of the old chip. I would probably also just pick up that wonderful 8GB set of Samgsung low-profile RAM that everyone loves to overclock till it cries. I'm just going to upgrade the computer in my sig rig, and hold off on upgrading it again until I'm out of college (just about to finish freshman year).
HAFaestus
(18 items)
FX-8120 ASUS Sabertooth 990FX ASUS DirectCU GTX 460 2 x 4GB Samsung
128GB M4 250GB Seagate 1TB WD Black LG 20X DualLayer
OSMonitorKeyboardPower
Windows 7 Professional 64-bit HP w2338h Chicony KB-2961 SeaSonic X750 80+Gold
CaseMouseMouse PadAudio
Cooler Master HAF 932 Black Interior Logitech G9x Razer Goliathus Extended Razer Carcharias
AudioAudio
Denon AVR-1712 Klipsch Qunitet
HAFaestus
(18 items)
AudioAudio
post #2 of 35
960T!
post #3 of 35
Second Intel Rig
(16 items)
2700 4.5/ 1.28 77 290 (2) 16 / 1866
Hard DriveCoolingOSMonitor
1000 360/240 10 64 28 2160
PowerCase
850 540
Second Intel Rig
(16 items)
PowerCase
850 540
post #4 of 35
8120 could be clocked higher but consumes way more power once past 4.3/4.4GHz.
Clock for clock 960T is better.
And, whichever chip you pick, if you plan serious OC, choose Asus Sabertooth over ud3:thumb:
post #5 of 35
I'm probably not going to be doing much heavy overclocking on it. It'll be my desktop rig back home for my parents and for the summer and breaks from school. I'll probably get it to 4GHz, but not much more past that. Just going from what I have now will be so much of an improvement I might not even OC for the time I'm home. I think I can still use my CPU cooler with an AM3/+ socket, no? This upgrade is just to get on roughly the same page as current technology, I'm not going for any records or anything of that sort, just something to make me happy and a little more proud of my computer. wink.gif
HAFaestus
(18 items)
AudioAudio
HAFaestus
(18 items)
AudioAudio
post #6 of 35
More Fans
(9 items)
x100e (RIP)
(7 items)
CPUGraphicsRAMHard Drive
Athlon Neo MV-40 ATI Radeon HD3200 4GB Patriot DDR2 OCZ Vertex 3 Slim 120GB
OSMonitorMouse
Crunchbang LG Green Screen Trackpoint
More Fans
(9 items)
x100e (RIP)
(7 items)
OSMonitorMouse
post #7 of 35
No reason to spend more than $100 on an AMD chip. Get the 960T (or FX-4100 if you want to play with the new stuff). Sink more money into the CPU later, once they get the newer architecture figured out.
The microcenter AMD combos are awesome. I wish there was one close to me.
Light Gamer #1
(12 items)
Light Gamer #2
(10 items)
i3-6100 ASRock Fatal1ty Z170 Gaming K4/D3 MSI r7850 TFIII OC MSI r7850 TFIII OC
RAMHard DriveCoolingOS
G,Skill TridentX OCZ Vector 150 TPC-612 Windows 10
G105 Rosewill Capstone 550M HAF XB M570
Athlon 860K MSI A88X-G45 MSI GTX 460 G.Skill RipjawsZ
Hard DriveCoolingOSKeyboard
PNY Optima Hyper T4 Windows 10 Devastator 2
PowerCase
Rosewill Valens DIYPC Ranger-R4-R
Light Gamer #1
(12 items)
Light Gamer #2
(10 items)
PowerCase
post #8 of 35
I just picked up a 960T a week ago and I absolutely love it! I dropped it in my GA 990XA-UD3 board and enabled core unlocking and voila! it is currently running at x6 @ 4.0GHz at 1.42v. Only thing that sucks about unlocking the chip is you lose the ability to use Core Temp =/
I say 960T all the way!
Phyllis
(18 items)
AMD Ryzen 1800x 4.00GHz @ 1.4v ASRock AB350 Pro4 EVGA 980ti Classified G.Skill 16GB DDR4 3200MHz (Only stable at 2400M...
Mushkin Chronos 120GB SSD { OS + Benchmarks } Seagate 1.5TB HDD { Music + Movies } Asus OEM CD/DVD R/W XSPC RX240 + XSPC RX 360 + Raystorm CPU block +...
OSMonitorMonitorKeyboard
Windows 10 64bit Asus PG278Q ASUS VG248QE Logitech G710s
PowerCaseMouseAudio
Corsair HX1050W Corsair Obsidian Series 900D Logitech G502 Proteus Core  Creative Sound Blaster Recon3D Fatal1ty Profess...
Audio
RAZER BlackShark Circumaural Expert 2.0 Gaming ...
Phyllis
(18 items)
PowerCaseMouseAudio
Audio
post #9 of 35
960t unlocked to 6core slightly OC'ed will be something to be proud of without goin to too much trouble or breaking the bank. so naturally i just bought a 8120 :\ (didnt listen to others) its brand new and doesnt work so its put me off fx series. 960t all the way mate smile.gif
post #10 of 35
depends how far you want to push the clocks and what you use it for, as well as for how much you could get either chip. personnly, ive seen the 8120 for as low as $170 and thats a steel. the phenoms are faster clock for clock, but if you plan on overclocking to the wall the 8120 will have like a ghz leed on the 960t. i would get the 8120 cause i do alot of video compressing, but if your a gamer then it might not be worth it. i think youll be happy with either
EDIT
see you wont be overclocking this to the wall. in that case, its a question of weather you will ever use the 2 or 4 extra cores. if you will, go 8120. if you wont, then go 960t
Edited by jrl1357 - 4/26/12 at 7:58am
  Back to Forum: AMD - General
