Overclock.net › Forums › Intel › Intel CPUs › 915P Chipset at 4.1 GHz Stable!
post #1 of 13
WOO! Just did a quick try for my 640@ 256.5x16, and it posted, booted, and everything is A-OK! Who thought a 915 chipset could breach the 250FSB barrier? Not me for sure...
CPU: 4103Mhz FSB: 1026
http://valid.x86-secret.com/show_oc?id=131642
I'll be shooting for 4.2Ghz tomorrow...I really want to get some good cooling now though! Now that I know I can go 4.0Ghz+, I'm gonna have to get rid of stock to cool this baby down and go higher
Sandy Beach
(14 items)
2500K @ 4.5GHz/1.32v P8P67-PRO [BIOS 1704] MSI GTX780 TFIV G.Skill 4x4GB DDR3-1600 (8-8-8-24-1T)
Hard DriveCoolingOSMonitor
512GB 850EVO, WD Black 1TB & ES.2 1TB & Cuda 3TB XSPC Rasa w/ RS240 Windows 7 Ultimate x64 Dell SX2210
Filco Ninja w/ Browns SilverStone Strider Plus 750W [Sleeved] Custom Stacker 832 Logitech G500
Mouse Pad
Steelseries 4HD
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
post #2 of 13
You =
Me =
Flux
i7 2600K GA-P67A-UD7 GTX 580 2 x 2GB Corsair
C300 (OS), Velociraptor (storage) Lite-On W7 64-bit Pro Samsung 275T
Black Widow Ult. Silverstone DA750 Lian Li T60 R.A.T. 7
Mouse Pad
Q-Pad
Flux
Mouse Pad
Q-Pad
post #3 of 13
Originally Posted by Syrillian
You =
Me =
Ehh...Only one problem, Dual-priming I get an error after a few minutes so I think I'm gonna have to up the vcore to keep a stable 4.1-4.2Ghz clock under 100% load...
But I won't be shooting for that until I get away from stock cooling and go aftermarket...I'm thinking BTVX/Scythe Ninja/AC Freezer7 Pro w/ FM91...
We'll see.
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
post #4 of 13
Or do you think I might need to bump up the chipset voltage to keep it stable at this high of a clock? It's currently just on AUTO, priming @ 41C...
Should I bump it up and try again?
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
post #5 of 13
Perhaps I missed it, but I couldn't find your Vcore. I don't think that I would up the voltage very much, until you upgrade your cooling.
Voltage to the NB should be okay on "Auto".
Another factor might be your timings, maybe a little looser?
Anyone else?
Flux
Mouse Pad
Q-Pad
Flux
Mouse Pad
Q-Pad
post #6 of 13
Anyone else?
My vcore is set on 1.4000 right now from the stock 1.3875. I've had to keep it at 1.4v since 3.9Ghz for stability, so I guess it could need more for 4.1+
I just tried raising the Chipset voltage from 1.5 to 1.6 and i still got the same error while priming :-\\
When I upgrade my cooling, I'll try 1.4125 vcore I suppose. Should I try raising my FSB Term. Voltage also?
And nah my timings are fine, these are the stock timings rated for DDR400 and I'm only running DDR405 right now, they went all the way up to DDR450 with 2.5-3-3-7 back when I was sitting at 3.6Ghz.
Thanks for your help so far
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
post #7 of 13
that is awesome.
i have the AC Freezer7 Pro. its not a bad heatsink. i also0 got the ceramique thermal grease. there is not a b ig differance from factory. i probably didnt need it. but i have always heard its not wise to OC with factory heatsink. i guess you proved them wrong.
i wonder how far i can actually push my cpu. i have 3 90mm fans 1 120mm fan and the fan that came with the heatsink i bought. i have had this cpu OC'd to 3.5 Ghz so far and ran stable. cpu at 100% was about 60.
but now i bought 2 seagate sats HD's and if i OC more then 5% when i restart it bios wont recognize my HD's and then says overclocking failed.
here is my thread
http://www.overclock.net/intel-cpus/...-over-5-a.html
please help
MY NEW RIG
Q6600 G0 (L727A871) ASUS P5K Premium BFG GTX 280 G Skill 2GBHZ
Hard DriveOSMonitorPower
2 SeaG 250GB ST3250620AS Win 7 ultimate bill gates edition 64 bit Gateway 24" LCD Works 600W
CaseMouse
TT XASERIII V1000+ BK Logitech optical wireless
MY NEW RIG
CaseMouse
post #8 of 13
Hey, before this core 2, I had a pent D 930 @ 4 ghz 1.4 vcore. After 2 months it burnt up It was running 30's idle 60's max temp. Im not too sure as to why it happened, but it was not a fun experience. I hope you have more luck than me! And very nice overclock for that chipset, wow.. I had a 945 chipset, p5ld2 (has vcore droop )
i5 4690K @ 4.4/1.13v | 4.7/1.28v ASROCK Z97M-ITX/ac 560TI Crucial 1600lv @ 1900 / 999
Hard DriveHard DriveCoolingOS
Crucial M550 256 Random 1TB RAID1 Noctua NH-D14 10 x64
BENQ 24" 1200p + 22" 1080p Razer cr@p CX750M Cooler Master Microatx
MouseAudio
Logitech G402 Onboard FTL - CMOY amp + Beyer DT770 80ohm
MouseAudio
post #9 of 13
How'd you get the FSB that high? I can't get it above 219MHz.
Intel Pentium 4 561 ES ASUS P5GPL-X nVidia GeForce 7900GTX 2x 512MB Corsair XMS
120GB Western Digital Lite-On DVD Burner 1 <3 Beryl+Ubuntu 6.10 17" sick-ass CRT
Saitek Eclipse 500W Aspire Green and Glowing Logitech MX 518
Mouse Pad
Regular Mat
Mouse Pad
Regular Mat
post #10 of 13
Well as not many people know this, my secret for helping ASUS owners is as follows. If your BIOS has under the "JumperFree Config" section a "Performance Mode" selection, change it from [AUTO] to [STANDARD] or even [TURBO] for the highest of clocks. I had to go from auto to standard to make it from 3.6Ghz to 3.9Ghz, and then to turbo for 3.9Ghz upward. Chipset core voltage doesn't seem to have any effect on the FSB or anything as I just leave that and FSB term. voltage on AUTO.
Check your BIOS for that setting though and see what you can get out of it. I know that almost ALL 945 and below chipsets have this setting when you have an AMI bios... Others I don't know, but it should.
Get back to me.
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
Sandy Beach
(14 items)
Mouse Pad
Steelseries 4HD
  Back to Forum: Intel CPUs
