Overclock.net › Forums › Graphics Cards › NVIDIA › 369% TDP spike on gtx 670
post #1 of 17
http://i.imgur.com/aNiNg.png
This happened after running the unigine heaven benchmark for about 10 minutes, I then quit to desktop after a successful run. As I'm sitting there looking over the GPU-Z graphs from the benchmark I get a driver crash/recovery. About 30 seconds later I get a second. When I look back at the graphs that is what I saw. Did I get a bad card or is this a software issue? The results there in GPU-Z are from the Heaven run and after the spike. Before the driver crashes the max TDP reported from GPU-Z was around 101%, since I'm not overclocked. Then it spiked up to 369% after the driver crashes.
post #2 of 17
Just a guess, but it could just be a reporting error due to the driver crash. Perhaps try a different driver? Go up to the beta version or down the stable, do a clean reinstall, etc.
Try running a couple different monitoring programs as well.
Can't view imgur(and most other imagehosts) stuff at work, so not sure what your graph actually shows redface.gif but that's the stuff I would do to try and narrow it down to whether its hardware or not.
IX
(15 items)
i5 2500k@4.5GHz MSI z68-GD65 Gigabyte 670 Windforce SLI 2x 4GB 1600MHz
Hard DriveHard DriveHard DriveCooling
Crucial m4 64gb Spinpoint F3 1TB Spinpoint F4 2TB Mugen 3
MonitorMonitorKeyboardPower
Catleap Q270 SE Asus VG236 Daskeyboard S Seasonic X750 Gold
CaseMouseAudio
Corsair 650D Logitech G500 X-Fi Titanium HD
IX
(15 items)
CaseMouseAudio
post #3 of 17
I'm on the official .34 drivers which are the release drivers for the 670. I've reinstalled once using a clean install yesterday. I'll keep that in mind though, thanks.
post #4 of 17
.34 are the beta drivers from what I understand. .25 are the release drivers, as they are what come on the cd.
Current
(18 items)
The Battler
6700k Asus Maximus VIII hero EVGA GTX 1070 FTW EVGA GTX 1070 FTW
32Gb Corsair Vengance LED 3000MHz Samsung EVO 120GB SSD Western Digital Cav. Blue 1TB Samsung EVO 500GB SSD
Optical DriveCoolingOSOS
Pioneer Blueray drive Noctua NH-D15s Windows 7 Pro 64bit Windows 10 Pro 64bit
Acer Predator XB271HU 165Hz BenQ XL2720Z Logitech G910 Corsair RM850i
CaseMouseMouse PadAudio
Corsair 760t (black) Logitech G900 Steelseries QCK+ Asus xonar essence stx
i5-2500k @ 4.6GHz 1.33v Gigabyte GA-Z68X-UD5-B3 Gigabyte Windforce GTX670OC Gigabyte Windforce GTX670OC
RAMHard DriveOptical DriveCooling
8Gb Corsair XMS3 1600MHz C9 OCZ Vert.II 60Gb, WD 500Gb CavBlue, WD 1Tb CavBlue Asus 24x DVD-RW Noctua NH-U12P
OSMonitorMonitorKeyboard
Windows 7 x64 LG 27EA63V-P LG 27EA63V-P Logitech G710+
PowerCaseMouseAudio
Corsair HX-850 CM Storm Stryker Logitech G502 Asus Xonar Essence STX
Audio
Sennheiser HD598
Q8400 @ 3.6Ghz - 1.32v Asus P5E - Deluxe x48 2x MSi nGTX460 HAWK SLi - (900c/2100mem 24/7) 4Gb Mushkin Redline PC2-8000 DDR2 Frostbyte
Seagate Barracuda 500gb x2 Asus DVD 22x burner Win7 Home Premium 64bit 32" Sony Bravia LCD
Logitech G110 Corsair TX750w CM 690II Advanced Logitech G500
Current
(18 items)
The Battler
PowerCaseMouseAudio
Audio
Sennheiser HD598
post #5 of 17
Hmm interesting, I never installed from the cd, just went straight to their website. It is listed under their website as release drivers though, the 670 currently has no beta drivers. I might try installing .25 and seeing if that helps but I have a feeling it's not that.
http://www.nvidia.com/object/win7-winvista-64bit-301.34-driver.html
from Anandtech:
"The official launch drivers for the GTX 670 are 301.34, which are also the official launch drivers for the GTX 690. These drivers do not support any other cards but are otherwise virtually identical to the 301.33 press drivers used for the GTX 690 launch. For all other NVIDIA cards we’re using 301.24."
post #6 of 17
Probably bad reading. No way you can get that much power Spike. It would cause damage to the card and not possible to pull that much.
Ishimura
(21 items)
Silent Knight
Intel Core i7 3770K @ 4.6GHz ASRock Z77E-ITX eVGA GTX 1080 Ti Hybrid AMD Radeon R9 16GB DDR3-2400MHz
Hard DriveHard DriveCoolingCooling
SanDisk Ultra II 960GB Toshiba X300 5TB Corsair H100i GTX eVGA Hybrid Water Cooler
CoolingOSMonitorKeyboard
4x GentleTyphoon AP-15 Windows 10 Pro 64-Bit Philips Brilliance BDM4065UC 4K Razer BlackWidow Chroma
PowerCaseMouseMouse Pad
eVGA SuperNOVA 750 G3 Define Nano S Logitech G502 Proteus Core PECHAM Gaming Mouse Pad XX-Large
AudioAudioAudioAudio
Audioengine D1 DAC Mackie CR Series CR3 Audio-Technica ATH-M50 Sennheiser HD 598
Audio
Sony XB950BT
AMD Phenom II X4 955 @ 4.2GHz ASUS M4A79XTD EVO AMD Radeon HD 7970 3GB @ 1200/1500 2x 4GB G.SKILL Ripjaws X DDR3-1600
OCZ Agility 3 60GB WD Caviar Green 1.5TB 2 x Seagate Barracuda 2TB XSPC Raystorm
CoolingCoolingOSPower
EK-FC7970 XSPC RS360 Windows 10 Pro 64-Bit Corsair TX750
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
post #7 of 17
I'm getting the same problem, not sure whether to consider it stable or not as it's odd possibly driver related.
post #8 of 17
mine goes up to 305%...didn't overclock..and never crashed...did we get a defective batch?
post #9 of 17
Nah it is bad reading, your GPU would have automatically shut down to protect itself or exploded if that were the actual power draw.
Skylake 1080 FTW
(18 items)
XPS 15
(7 items)
i7-6700K  ASUS Maximus VIII Ranger EVGA 1080 FTW TridentZ DDR4-3000
Samsung SM951 128GB Samsung 840 Pro 256 GB Muskin Reactor 1TB Seagate Baracuda 2TB ST2000DM001 HDD
Hard DriveCoolingOSMonitor
Seagate Baracuda 2TB ST2000DM001 HDD Corsair H110i GT Windows 10 Pro  Acer XB321HK 32" 4K G-sync
Corsair K70 Rapid Fire EVGA SuperNova 650 P2 NZXT H440 Black Logitech G900
Mouse PadOther
Razer Vespula CyberPower CP1500PFCLCD - PFC Sinewave UPS Syst...
i7-7700HQ 2.8Ghz(3.8Ghz Turbo) Dell XPS 15-9560 Nvidia GTX 1050 8GB DDR4-2400
Hard DriveOSMonitor
256GB PCIE SSD Windows 10 Pro 15.6" 1080p
Skylake 1080 FTW
(18 items)
XPS 15
(7 items)
Mouse PadOther
Hard DriveOSMonitor
post #10 of 17
no this is common. It happens for me to when drivers crash, that's all it is no need to worry thumb.gif
Chuggin' along
(16 items)
Intel Core i7 2600K@4.6GHz MAXIMUS V GENE GTX 970 STRIX@1475/8212 8gb G skill Sniper 2133
Seagate Barracuda 1TB OCZ Agility 3 Intel 120gb 520 H100
OSMonitorKeyboardPower
Windows 8 Pro BenQ XL2420T +2 Samsung s24d590pl  Corsair K90 OCZ ZX 850w
CaseMouseAudio
Corsair 500R R.A.T. 7 Sennheiser HD 518
CPUGraphicsRAMHard Drive
i7 4700 GTX 860m 12GB 120gb SSD
Hard DriveOSMonitorMouse
1 TB  Windows 8.1 17' 1080p RAT 7
AudioAudio
Bose quiet comfort 15 sennheiser hd 518
Chuggin' along
(16 items)
CaseMouseAudio
AudioAudio
  Back to Forum: NVIDIA
