Overclock.net › Forums › Intel › Intel CPUs › 4ghz!
4ghz!
post #1 of 6
http://files.zenixstudios.com/40812.7.JPG
http://valid.x86-secret.com/show_oc?id=132407
My System
Core 2 Extreme X6800 3.6 24/7 P5W DH Deluxe 8800GTS G92 G.SKill PC8500 DDR2 2GB
Hard DriveOSMonitorKeyboard
150GB raptorx2 raid0 Windows XP Pro Apple 30 " 2560x1600 G15
PowerCaseMouse
1000w PC P & C U2-UFO G7
My System
PowerCaseMouse
post #2 of 6
Nice, I also hit the big 4ghz, but can you get it stable?
C2D E6600 @ 3.2ghz 458fsb Gigabyte GA-965P-S3 Vmod Evga 8800gtx @ 752 / 2028 2gb G.Skill PC6400 HZ
2x wd80 Pioneer dvd-r+ xp 22" Mitsubishi crt 1920x1440
Logitech TT Toughpower 750W Floor.... Laser
post #3 of 6
Probably yeah, what is a good stability test? I have been doing all sorts of stuff already for an hour with 4.0ghz I think I can pass stability.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #4 of 6
Orthos Prime, two instances of SP2004, or two instances of Prime 95 will get you at pretty much full load.
If you can run a test like this for more than 15 minutes or so its a good sign.
Testing for a much longer period of time, like overnight will show long-term stability
post #5 of 6
Nice going..
Also try dual runs of Pi32M.. this is also a good indicator .. then Prime away.
Keep on going up.
OS X 10.6.4
Mac Mini Mac Mini Server 2011 Intel HD3000 8Gb
2 Internal drives None OS X / W7 x64 Dell U3011
Apple Wireless & Wired Internal Mini brick Magic
OS X 10.6.4
post #6 of 6
Way to go!
E8400 @ 3.8 GHz DFI LANPARTY DK X38-T2R eVGA 8400GS 2GB Mushkin DDR2 800 (single stick)
250GB WD SATA None Windows XP Pro 32-bit HP Pavilion f1703
N/A Corsair HX520 Coolermaster Cavalier N/A
Mouse Pad
N/A
Mouse Pad
N/A
  Back to Forum: Intel CPUs
