Overclock.net › Forums › Graphics Cards › AMD/ATI › 6750 question .
6750 question .
post #1 of 4
How does 2 HD6750 perform ?
1gb DDR5 better or 2gb DDR3 better ?
Can I take one gigabyte 6750 and another ASUS 6750 and link up together ?
post #2 of 4
They perform about on par with one HD 5850. Overclocked, about the same as one HD 5870.
Get the GDDR5 model. GDDR3 would severely hinder performance on the 128 bit bus.
You can mix brands.
Light Gamer #1
(12 items)
Light Gamer #2
(10 items)
i3-6100 ASRock Fatal1ty Z170 Gaming K4/D3 MSI r7850 TFIII OC MSI r7850 TFIII OC
RAMHard DriveCoolingOS
G,Skill TridentX OCZ Vector 150 TPC-612 Windows 10
G105 Rosewill Capstone 550M HAF XB M570
Athlon 860K MSI A88X-G45 MSI GTX 460 G.Skill RipjawsZ
Hard DriveCoolingOSKeyboard
PNY Optima Hyper T4 Windows 10 Devastator 2
PowerCase
Rosewill Valens DIYPC Ranger-R4-R
Light Gamer #1
(12 items)
Light Gamer #2
(10 items)
PowerCase
post #3 of 4
What if I mix two different type and different brand GPU ? It's that okay ?
post #4 of 4
How does 2 HD6750 perform ? 1gb DDR5 better or 2gb DDR3 better ?
its just not worth going for multi GPU in the low end. Instead of getting two HD 6750 cards get a single HD 7850 . Superior DX11 architecture and much better performance in DX11 games. Also even at 1080p games like BF3 need more than 1 GB RAM for max settings. Also CF performance scaling can vary from game to game. In games where scaling is poor or the CF profiles don't work the HD 7850 will be vastly superior.
HD 7850 overclocks very well. At 1 Ghz matches GTX 570 and at 1.2 Ghz GTX 580.
http://www.techpowerup.com/reviews/Powercolor/HD_7850_PCS_Plus/28.html
HD 5770 - 49
HD 7850 (1 Ghz) - 100
GTX 480 -100
HD 6970 - 102
GTX 570 - 103
FYI HD 6770 is identical to HD 5770. so you see HD 7850 at 1 Ghz is twice the performance of a HD 6770. And compared to HD 6750 the HD 7850 is even more better.
here is the sapphire HD 7850 2 GB for USD 200 (190 after rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102998
if you want a card below USD 150 get the EVGA GTX 560 for USD 160 (130 after rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130661
Fragbox
(14 items)
Intel Core i5 2400 DH67BL AMD Radeon HD 6900 Series XFX HD 6950 2GB
RAMRAMHard DriveOptical Drive
Corsair Corsair DDR3 1333 Mhz 2 GB Corsair DDR3 1333 Mhz 2 GB Western Digital Caviar Green SONY DVD-RW AD-7260S
OSMonitorKeyboardPower
Windows 7 Professional 32 bit BENQ G2420HD Logitech K200 Seasonic VX550 psu
CaseMouse
ANTEC 200 V2 Logitech mouse
Fragbox
(14 items)
CaseMouse
  Back to Forum: AMD/ATI
