Overclock.net › Forums › AMD › AMD CPUs › 8320 or 8350
8320 or 8350
post #1 of 28
Overclockers have 8320's in stock now but no 8350's for anotehr week or so,
I know there basically the same cpu just with a lower clock.
Can the 8320 deffinatly overclock to the same levels as the 8350 and should I just get the 8320 now?
New gaming
(20 items)
I7 5820k @4.5ghz gigabyte x99s sli EVGA GTX1080 Teamgroup 16Gb 2400mhz DDR4
Hard DriveHard DriveHard DriveCooling
Samsung 850 500GB Western Digital 1TB Samsung 840 250GB 3 X EK vardar 120mm 2200rpm
CoolingCoolingOSMonitor
2 x EK Vardar 140mm 2500rpm Corsair H110GTX Windows 10 Acer 28" 4K
Acer 22" 1080 Razer Blackwidow Chroma Corsair CX850m NZXT H440 Razer
MouseMouse PadAudioOther
Razer deathadder chroma Razer Firefly AKG K702 blue yeti
New gaming
(20 items)
post #2 of 28
All processors are different, it could be a better fabrication which gives you a better overclock or a worse fabrication.
In all honesty though, you're fine with what you have, why are you upgrading to something you won't really see the benefit of? There are better things you can spend your money on tbh.
C
post #3 of 28
C
Like an SSD.
In progress.
(15 items)
3570k Asrock Z77E-ITX GTX670 Windforce 8gb Samsung 30nm
Hard DriveCoolingOSMonitor
OCZ Agility 3 240gb OS and Steam h100i Windows 7 Ultimate 64 Asus VG236HE 120hz
KeyboardPowerCase
Steelseries 6gv2 Antec TruePower New TP-750 Bitfenix Prodigy (White)
In progress.
(15 items)
KeyboardPowerCase
post #4 of 28
C
Check out this thread>http://www.overclock.net/t/1318995/official-fx-8320-fx-8350-vishera-owners-club/2060 I think you'll find that a new Vishera cpu WILL be an upgrade! An ssd is also a good investment! tongue.gif
Guess 20-30% improvement is not a upgrade to some people though.
Intel 5820k Gigabyte X99 Champion EVGA 980 Kingpin Kingston HyperX Predator
OCZ Vertex 4 Asus Bluray Custom Water Win7 Ultimate
MonitorPowerCaseMouse
Asus VG248QE EVGA P1200 Mountain Mods Extended Custom U2-UFO  Mad Catz R.A.T 5
Mouse PadAudio
steelseries M-Audio BX5a DLX
Mouse PadAudio
post #5 of 28
So does anyone know if the 8320 will perform similar the 8350?
post #6 of 28
^ I'd say it seems plausible. When the 1055T came out I got it within a month's release and got a 1090Tish overclocking result for it, but saved the $100. thumb.gif
I just placed an order for an 8320 and I'm hoping for the best.
post #7 of 28
my 8320 is due to arrive this morning.
Will let you know how it compares to my 1075t then will try it @ 4.0ghz to see how it compare to the 8350 then will try to see what I can get out of it.
New gaming
(20 items)
New gaming
(20 items)
post #8 of 28
He'll not gain any FPS when gaming, but for multicore apps yes, he'll see a boost. It depends on what he uses his machine for to be honest.
C
post #9 of 28
The good thing about the new Vishera cpu is that they are running about the Phenom II level core vs. core.
HTPC
(11 items)
CPUMotherboardRAMHard Drive
AMD A-3870K AsRock A75 Pro (FM1) HyperX DDR3 1866 8 GB SAMSUNG 830 256gb
SAMSUNG EcoGreen F4 2TB Plextor Black Blu-ray Burner Phenom II X4 stock Cooler Windows 10
MonitorPowerCase
LG M2762D-PM Glossy Black 27" 5ms (1920x1080) Antec HG 900 Gerenic ATX Case
HTPC
(11 items)
MonitorPowerCase
post #10 of 28
my 955 be is starting to see its age.
  Back to Forum: AMD CPUs
