Overclock.net › Forums › AMD › AMD CPUs › 4000+ Oc
4000+ Oc
post #1 of 4
This is a basic OC 100% stable. Stock cooler, with stock thermal pad.
Did not play with the multi at all.
http://valid.x86-secret.com/show_oc?id=139345
2764.19MHz (230.35 x 12)
I know it isn't that good, but what do you think of this as an everyday overclock?
(Rep me if you like it )
MONOLITH
E6600 L631A871 eVGA 780i Dual G92 GTS's Corsair Dominator 2GB
Samsung Spinpoint F1 1TB Lite-On LightScribe Win Vista SP1 BenQ FP241w
Saiktek Eclipse II Corsair HX620 Rocketfish Razer Copperhead
Mouse Pad
Steelpad Qck Heavy
MONOLITH
Mouse Pad
Steelpad Qck Heavy
post #2 of 4
same cpu and just about the same overclock. Mine is running at 250 x11 at 2.7450 1.45 volts. Very stable and on stock cooling. You could probably push it to 250 x11 but depending on your ram im not sure what divider you should use.
CPUMotherboardRAMHard Drive
Intel Core i5 450M Acer 4GB DDR3 500GB SATA
Optical DriveOSMonitorPower
SuperMulti Dual Layer Windows 7 Home Premium 15.4" Widescreen LED Brick+Battery
Mouse
Touch Pad
Mouse
Touch Pad
post #3 of 4
Try using a 10 or 11 multiplier and push that FSB!! High FSB is the most important part of having a fast overclock. For example, 275 fsb x 10 = 2750 would be faster than 230 fsb x 12 = 2760. You can also use a higher HTT multiplier... it looks like you're using a 3x where you should be using a 4x. The idea is to keep your hyper transport running as close to 1000MHz as possible.
Edit - upon further inspection, you could also use a more aggressive RAM divider. Right now your memory is running under spec (184MHz instead of 200MHz). I bet you could get it over 200MHz easily because Corsair is the $h*t.
Computer
Core 2 Quad Q6600 ASUS P5E X38 8800Ultra OC Crucial Ballistix 2GB
Hard DriveMonitorKeyboardPower
Western Digital Raptor Samsung 940BX nord lead 2X Seasonic S12 650W
Lian Li PC-65B
Computer
Lian Li PC-65B
post #4 of 4
Hell yeah thanks indignation! I'll try that tomorrow. +rep for you baby!
MONOLITH
Mouse Pad
Steelpad Qck Heavy
MONOLITH
Mouse Pad
Steelpad Qck Heavy
  Back to Forum: AMD CPUs
