Overclock.net › Forums › Intel › Intel - General › 2008 PC system near death?
post #1 of 2
Hi guys, i think something isn't right anymore about my rig.. my old rig..
Specs : ASUS p5b-vm (LGA 775)
Q660 2.4GHz
2GB DDR2
GTS 450 ddr3 1GB
and that's it.. well, yesterday i turn my pc on and it showed the American megatrends bios screen something like that and after a couple of seconds the pc beeped (idk how many times) but it beeped several times, and then it went black and idk if it restarted or was shut down..
before that event happened, i experience many frustrating problems, like the memory controller is messed up sometimes it restarts and shows a black screen -- to fix it i need to reseat the memory and unplugging and plugging the cables again (24 pin cable , CPU 4pin cable)..
When certain problems occur, i would remove the memory and listen if the pc beeps, if it does then it tells me that the power is stable and sufficient. When not, then I would plug and unplug the cables to make the PSU be "responding" again...
I decided to replace my PSU to my new non-generic PSU , and then it powers up..So it turns out that my PSU is causing all these problems..
After the last greatest problem ever happened, I used my trick by removing the memory and listen to the beeping --- no beeps.
Unplugging and plugging the cables again --- not working
Replacing my PSU with my new one --- still not working..
I don't have any idea on how to fix this.. I think my MOBO is dead already?
Core i3 2100 @ 3.1 GHZ ECS H61h2-m12 HD 7950 8GB ddr3 1333mhz Transcend
Hard DriveCoolingOSOS
Western Digital Caviar Blue 500GB Stock coolers ; Air cool Windows 8 Release Preview Windows 7
PowerCaseMouse
Cougar ST-550 Caseless  Thermaltake Ryujin Gaming Mouse
PowerCaseMouse
post #2 of 2
I would say you are correct its the motherboard.
Worse than crack.
(14 items)
Intel 3570k Asrock z77 extreme4 Saphire R9 290 Samsung green
Hard DriveHard DriveOSMonitor
Samsung 840 ssd Samsung f3 spinpoint Win8 pro X-star 2560x1440 27in
KeyboardCaseMouseMouse Pad
Microsoft x4 Sidewinder Haf 922 Razor Naga Fragmat
Worse than crack.
(14 items)
  Back to Forum: Intel - General
