Overclock.net › Forums › AMD › AMD CPUs › -128C temp???
-128C temp???
post #1 of 6
ok when i run speedfan it reports one of my temps at -128C as shown in the picture. what is that??? i'm runing everything on air, not even that many fans. it's probably a bug in speedfan or a misreported temp right??
post #2 of 6
Yes it is a bug on speed fan normaly your cpu temp is temp 1 and that one seems i be normal, so just ignore this
His
(9 items)
Ryzen R5 1600 Asus Strix B350-F MSI GTX 1060 6GB OC 2 x 8gb Gskill Ripjaw V 3200MHZ
Hard DriveOSMonitorPower
1TB Samsung EVO 850 Windows 10  X-Star 27" 1440p @ 96hz Silverstone Strider 1000w
Corsair 270R
His
(9 items)
Corsair 270R
post #3 of 6
and look at my voltages at the bottom are those reported wrong too i mean the -12v at -4? or is that just my sucky PSU
post #4 of 6
Do you live in Antarctica by any chance?
Compos Mentis
AMD Athlon 64 X2 5200 Brisbane 2.7GHz Foxconn A7VMX-K XFX GeForce 7800GT 256MB GDDR3 Crucial 2GB 240-Pin DDR2
Hard DriveCase
SeaGate 200gb PATA Antec 900
Compos Mentis
Hard DriveCase
post #5 of 6
Have you configured speedfan? I belive there was a site that gave you the speedfan code after you filled out some questionaire about your rig and it gave you only the temps that were available for you and removed all those -128C things and random temps etc.
FX-57 Rig
AMD Athlon64 FX-57 DFI Lanparty NF4 SLI-DR EVGA 7950GX2 OCZ 2x1 GB 2-3-2-5
Hard DriveOSMonitorKeyboard
74GB Raptor Windows Vista Ultimate Acer AL2216W 22" Widescreen Saitek Eclipse (Blue)
PowerCaseMouseMouse Pad
680W Aspire Thermaltake Armor Logitech G5 Icemat v2
FX-57 Rig
post #6 of 6
no i haven't i'll go look for that site
  Back to Forum: AMD CPUs
