Overclock.net › Forums › Graphics Cards › AMD/ATI › 7770 vs 7850
7770 vs 7850
post #1 of 25
My current video card, a 5450 is pretty terrible at gaming.I 'm looking for an upgrade, but I'm more geared towards the 7770 as its about 70$ cheaper, how big is the performance difference on a 1080p monitor? I'm also want to know the best price/performance brand for both the 7770 and 7850. Also are any of these still voltage unlocked?
Current Rig
i5 4670k z87e-itx Radeon 7770 2x4gb Samsung Wonder Ram
ocz vertex 128gb Some Random LG Custom Loop Windows 8
acer 23" cooler master stormtrigger Corsair CX430 prodigy
Mouse
steelseries sensei raw
Current Rig
Mouse
post #2 of 25
the 7850 offers better performance for price. It's leagues ahead of the 7770.
post #3 of 25
best price performance is a 7950 currently but since you are very tight in budget i would say go 7850 to have playable frame rates at 1080p (above 30)
Zero Ex 2
(21 items)
Intel Core i7 3770K De-Lidded w/CLU @ 4.6 GHz ASUS Z77 TUF Sabertooth 2x Asus GTX 1080 Strix 8GB @ 2100/11000 MHZ SLI 2x Kingston Hyper-X Beast 8GB DDR3 @ 2200 MHz
Samsung 850 Pro 1TB SSD Western Digital 60EZRX 6TB 5400RPM HDD Samsung SH-S203N 20X LightScribe DVD RW Corsair H100i + 4x CM 120mm @ Push/Pull
CoolingOSMonitorKeyboard
5x CM 120mm + 1x CM 230mm + 1x NZXT 140mm Windows 10 x64 Samsung UA50JS7200R 50'' 4K SUHD HDR Smart TV Gigabyte Aivia Osmium
PowerCaseMouseMouse Pad
Seasonic X-Series Gold 850W Cooler Master HAF 932 Gigabyte Aivia Krypton CM Storm Speed-RX S
AudioAudioAudioOther
Creative SB X-FI Titanium Fatality Pro Edifier S760D 5.1 Dolby Digital Sound System Corsair Vengeance 2100 Wireless 7.1 Gaming Headset Microsoft Xbox 360 Wireless Gamepad + Receiver
Other
MSI Star PCI-E USB 3.0 Hub
Zero Ex 2
(21 items)
Other
post #4 of 25
7770 can easily get 30fps at 1080p, just not maxed. It falls between a 6770 and a 6850. 7850 is close to a 6950 at stock clocks, and OC's farther than a 6950.
post #5 of 25
i'm talking maxed, you want to play with all the bells and whistles on and have 30fps minimum that is the minimum you could really accept nowdays.....
7770 no go
go for something faster for 1080p res
Zero Ex 2
(21 items)
Other
Zero Ex 2
(21 items)
Other
post #6 of 25
The general consensus is that the 7850 is the least expensive AMD card that's suitable for 1080p gaming at decent settings. In case you're wondering about NVIDIA, their least expensive 1080p card is the GTX 660.
Julia
(11 items)
Centurion (Dead)
(11 items)
AMD Athlon 64 3700+ EPoX EP-9NPA+ Ultra EVGA GeForce 6800 GS (256-P2-N389-AX) CORSAIR VS1GB400C3
Western Digital Caviar SE WD1600JS NEC ND-3520A Windows XP Dell M780
PowerCaseOther
FSP Group SAGA+ 450R Cooler Master Centurion 5 w/ Window (CAC-T05-WW) Samsung Floppy Drive (SFD321B/LBL1)
Julia
(11 items)
Centurion (Dead)
(11 items)
PowerCaseOther
post #7 of 25
My 7850 does very tidily at 1080p, and I know it could do much better if I had a stronger CPU. Any games you're wondering about in particular?
Timid Beast
(16 items)
Athlon II x3 445 @3.825GHz ASUS M4A785TD-V Evo Sapphire 7850 6gb 1360 7-8-7-22-29 Kingston
Crucial M4 64gb Caviar Blue 500gb 22x DVD RAM Cooler Master Hyper 212+
OSMonitorKeyboardPower
Windows 7 Professional 64 bit Hanns G 23" 1080p Xenta Black Chiclet Corsair CX430
CaseMouseMouse PadAudio
NZXT Gamma Microsoft Sidewinder x8 Oak ASUS Xonar DG > Superlux 668b
Timid Beast
(16 items)
post #8 of 25
Why not a used 68xx or 69xx they have 256bit so they are ok for 1080p gaming at least better than a 7770
post #9 of 25
I have no objections towards last generations video cards if they still work well within my budget. My only concern is my power supply, its a 430W CX so i don't think a 6850 could run on it. Sounds like 7850 is the winner, which brand would be best?
Current Rig
Mouse
Current Rig
Mouse
post #10 of 25
This would be my bet if they were in stock > http://www.newegg.com/Product/Product.aspx?Item=N82E16814131484
This LE model (Tahiti) will OC to a 7950 for much cheaper.
Colossus
(15 items)
i5 3570K ASRock Extreme4 SLI EVGA 670 FTW Corsair Vengeance 8gb 1600mhz
Samsung 830 256gb ASUS DRW Hyper 212+ P/P Windows 8 Pro 64-bit
HP 2311x Razer Blackwidow Seasonic x650 Corsair Graphite 600t
MouseMouse PadAudio
Razer Death Adder Steelseries Astro A40 2013 edition
Colossus
(15 items)
MouseMouse PadAudio
  Back to Forum: AMD/ATI
