Overclock.net › Forums › Components › Memory › 2013 Todays memory....???
post #1 of 4
What for today is better for gaming/regular tasks/multitasking.......
1)More memory (GB) size
2)More speed (MHZ)
From what i noticed i tested with 2 different ram 2x2gb set and a 2x4gb set and i noticed that with the 8gb set was quicker for alt tabbing, and with both (12gb) alt-tabbing was allot faster they are 1600mhz but the timing is diff....
does anyone know if i can oc my vengeance memory higher easy??
Edited by =JLumbs= - 3/15/13 at 8:09pm
money$ $y$tem
(14 items)
Q9550 (E0) @ 4.2ghz (1.360) Gigabyte EP45-UD3P 7970 oc windforce, 6870CF, 4870CF an Eyefinity Corsair dominator4gb new GSkill 4gb @ oced 1158mhz
Hard DriveOSMonitorKeyboard
Intel X25-V SSD&WD 640gb cav black, 750gb cav blk Windows 7 home premium 64bit Dell 23"LCD 2xBenQs 21.5"LED Eyefinity Razer Black Widow Mech. and Logitech illuminated
PowerCaseMouseMouse Pad
Corsair AX750w Gold before was Ocz gameXtream 850w Silverstone Raven 2 new NZXT Phantom (white) Logitech G 500 steelseries
Audio
7.2 setup with Z-2300
money$ $y$tem
(14 items)
Audio
post #2 of 4
3) or better timings
is it better to have more ram like say 16gb ram at 1600mhz vs. 8gb @ 2100mhz??????????????
money$ $y$tem
(14 items)
Audio
money$ $y$tem
(14 items)
Audio
post #3 of 4
With Intel, speed is better then timings. So it is better to have 2133 at cas 11 vs 1600 cas 9. As for capacity, it really depends on what you use. 16Gb seems to be overkill for the average gamer. And as you go with larger capacity ram, you tend to give up speed and timings.
If I was doing a build for someone today, I would get them a 2x8Gb kit of 2133 or 1866. The CPU's memory controller does have a lot to do with how well the ram runs though. So even if you bought 2133 ram, there is a chance you can't run it at its rated speed and timings if the IMC can't keep up. You would more than likely need to increase some voltages if that was the case.
My System
(15 items)
6850K ASUS X99-A eVGA GTX 1060 32Gb Team Vulcan DDR4 3000 Cas 15
Hard DriveHard DriveHard DriveCooling
OS: Crucial M500 Seagate HDD Samsung F3 H100i
OSMonitorKeyboardPower
Windows 10 Pro 64 Samsung KU6300 40" Corsair K70 Vengeance Seasonic Gold 750W
CaseMouse
Phantek Enthoo Pro M Logitech G9X
My System
(15 items)
CaseMouse
post #4 of 4
Thanks...
money$ $y$tem
(14 items)
Audio
money$ $y$tem
(14 items)
Audio
  Back to Forum: Memory
