Overclock.net › Forums › Intel › Intel - General › $1700 budget.
$1700 budget.
post #1 of 13
I have been looking at so many reviews and benchmarks ect. for ever. i know this is what i want, but i want to check if everything is compatible and good for its price!
http://pcpartpicker.com/p/Q45a
Thanks!
EDIT: please critisize anything if you think its a bad buy.
post #2 of 13
That honestly looks like a very solid build. You have clearly done your research. I assume you already have a copy of Windows since I don't see one listed there. You will love that monitor. I recommend going with an Nvidia graphics card so you can lightboost hack that monitor. Once you lightboost hack you get almost 0 motion blur! The difference is insane!
My rig
(18 items)
4770k M power EVGA GTX 980 SC G.SKILL Sniper (2 x 4GB) DDR3 1600 9-9-9-24
Hard DriveCoolingOSMonitor
512GB Samsung 940 Pro h100 Windows 8 Home premium Asus VG248QE
Asus VG248QE Corsair K90 Kingwin Lazer Gold 850w Fractal Design Arc Midi R2
MouseMouse PadAudioAudio
Logitech G700s Corsair Asus Xonar M-Audio BX5 d2
Audio
krk 10s
My rig
(18 items)
Audio
krk 10s
post #3 of 13
Yeah man, great choices. Remember to shop around for that window 7 OEM. Often times you can get them cheaper than newegg.
Also, I just want to point out that your case has blue LEDS and the strip is red LEDS.
Also, if you're in the USA and in range of a Microcenter, you can afford a 3770k for just a little bit more, but only in store. It's also quite a trip to be in a micro center, it's like best buy if they catered to computers instead of kitchen appliances and physical media.
*EDIT* If you want to shave off some price, perhaps by buying a lesser expensive ASrock mother board and maybe a silver rated power supply, and get a crucial SSD (Really reliable brand IMO), and maybe hold off on the light kit for a while, you could get yourself a RADICAL 1440P MONITOR, and make the games you'll be maxing out at 1080p look EVEN BETTER.
Look at OCN's 1440p club, open an image full size, and zoom in.
Edited by Clam Slammer - 4/13/13 at 2:38pm
post #4 of 13
do you think i should go with a high end 670? or just go for the 680?
post #5 of 13
Do you plan to Crossfire ? If not that PSU is too much for your build. even a decent 550W will do you justice. If you want to go with a 750W. it's your choice. But in that case you CAN"T skip this deal Seasonic M12II 750W Semi Modular PSU. it's for 70$.. just grab it man.
If you want less power and you were just shooting for safety i would recommend the Rosewill Capstone PSU. it's a solid unit.
other than that. every thing is very well chosen.
One more thing. You can shove 20-30$ off that SSD. if you look on the marketplace here. there are couple of people with same SSD for 110$ shipped.
If you plan to go crazy on the OC.. 4.4+ i would recommend changing the Hyper evo which is a solid entry level heatsink into a Noctua NH-D14 or Phantec PH-12
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
intel i7 3770K Gigabyte Z77 UD3R Sapphire Radeon r9 290x Sapphire Radeon r9 290x
Corsair Vengeance 8GB seagate barracuda 7200 RPM 1 TB PNY 120GB SSD PNY 240GB SSD
CoolingCoolingCoolingCooling
ek supermacy full nickel Mayhem Pastel white  Mayhem blue non stain dye ek FC r9 290x
ek fc r9 290x  swiftech mcp655 Koolance COV-RP450  EK-CoolStream RAD XT 240mm
CoolingCoolingCoolingMonitor
Swiftech MCR320 360MM  Primochil ghost rigid compression fittings Primochill PETG Tubes X-star
Nixeus moda v2 EVGA SuperNova GS850 NZXT H440 Logitech G400
Mouse PadAudio
Razer Goliathus Asus Xonar DGX
intel i5 4430 Asrock z78 pro 4 Sapphire 7870 XT G.Skill Aries 8GB
A LOT OF THEM Corsair H80 Windows 7 ultimate Samsung
Cooler Master Quickfire TK Corsair 650XT Thermale take armor revo 4 Cooler master storm xornet
Mouse PadAudio
Steelseries CKQ Steelseries Flux luxury edition
Intel i7 3770k GigaByte GA-Z77x-UD3H sapphire R9 290X Corsair Vengeance 8GB
Hard DriveOptical DriveCoolingCooling
western digital caviar blue Samsung HF-132B Corsair Sp120 Corsair AF AF120 LED
Alphacool ST30 AlphaCool XT45 EK supremacy Clean CSQ Full Nickel PrimoChill Advanced LTR tubing
CoolingCoolingCoolingOS
Swiftech MCP50X Alphacool Cape Corp 100ml Koolance VID-290X Windows 7 Ultimate
MonitorMonitorKeyboardPower
X-Star Dp2710 @ 92HZ BenQ E2400HD Cooler Master Quickfire Ultimate seasonic M12II 750W
CaseMouseMouse PadAudio
Corsair Carbide 500R logitech G400 Cooler Master SteelSeries Syberia V2
Other
NZXT LED strip
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
Mouse PadAudio
Mouse PadAudio
Other
NZXT LED strip
post #6 of 13
if you are lucky with your 7970 and it's voltage unlocked. you will reach 1200 1600.. that would eat both the 370 and 680 ALIVE smile.gif
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
Mouse PadAudio
Mouse PadAudio
Other
NZXT LED strip
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
Mouse PadAudio
Mouse PadAudio
Other
NZXT LED strip
post #7 of 13
Thanks!
don't bother with the Nvidia lightboost and going with Nvidia. Zero motion lag exists on slow monitors
You could get rid of the DVD writer, surely you don't have one around?
Phantom 410 ... Err,
consider these cases instead
http://pcpartpicker.com/part/bitfenix-case-bfcsnb150wwwbsp
http://pcpartpicker.com/part/enermax-case-eca892bgbl
http://pcpartpicker.com/part/fractal-design-case-fdcaarcr2blw
and that PSU is not recommended and for a single PSU you DONT NEED A 850W PSU. 550-600 is enough. Seriously
http://pcpartpicker.com/part/rosewill-power-supply-capstone550m
http://pcpartpicker.com/part/rosewill-power-supply-capstone650m
Ayase Eli
(20 items)
Testbench
(10 items)
MC Server
AMD Ryzen 7 1700 ASRock X370 SLI Killer Zotac GTX1070 "FE" with ID Cooling Frostflow 240G Crucial BallistiX Sport LP 16GB 8x2GB
Hard DriveHard DriveHard DriveCooling
Zotac SSD Premium 480GB OCZ Vector 180 480GB Hitachi 7K3000 3TB 7200rpm ID Cooling Frostflow 240L
ID Cooling Frostflow 240G Phanteks F140MP x2 CoolerMaster Silencio FP120 x2 Phanteks F140SP
CoolingMonitorKeyboardPower
Delta AFB1212SH x2 Dell U2713HM CM Storm MECH FSP Aurum PT 1200
Phanteks Enthoo Pro Logitech G102 Tesoro Aegis X3 Virtus.Pro AKG K7XX
Intel i7 6700k Gigabyte Z170X-UD5 Depends Depends
Hard DriveCoolingMonitorKeyboard
Plextor M5S Depends Dell U2312HM CM Storm Quickfire Rapid-i
PowerMouse
FSP Aurum PT 1200 CM Storm Mizar
Intel i7 2600 4GHz Gigabyte Z77X D3H Intel HD Graphics 2000 obviously Kingston HyperX Genesis 4X4GB DDR3 1600
Hard DriveCoolingCoolingCooling
Intel 530 240GB Deepcool Captain 240 Arctic Cooling Bionix 140 Delta AFB1212L
OSPowerCase
Windows 10 Pro CoolerMaster G750M NZXT Switch 810
Ayase Eli
(20 items)
Testbench
(10 items)
MC Server
PowerMouse
OSPowerCase
post #8 of 13
Get a Western Digital 1TB Blue, WD10EZEX 1 platter model. For power supply 500W will be plenty. Rosewill Capstone 550W is one excellent option. The rest seems good to me. The rest you can throw at a better cooler like a Antec Kuhler 620 or equivalent.
post #9 of 13
550W Antec Earthwatts Platinum
Incredible value for platinum and more than enough for one GPU + CPU. If you plan on going CF, go ahead with the 750W.
Also, I'd buy 2133Mhz RAM and drop the 1TB HDD but that's personal preference.
Never Finished
(18 items)
Intel i7 6700K ASUS Z170 Pro Gaming Sapphire Tri-X R9 290X 8G Corsair Vengeance LPX DDR4 2666Mhz - (2x8GB)
Hard DriveCoolingCoolingOS
Samsung 960 EVO M.2 500GB EK Predator 360 EK 250 X3 Reservoir Windows 10 Pro
Dell U2515H Corsair Raptor K40 Corsair RM650x Fractal Design Define S
Logitech M500 Gigabyte GP-MP8000 Extreme Accuracy Yamaha HTR-4068 Philips FWB C355 speaker set
AudioOther
Hyper X Cloud II Samson C01U Pro
Never Finished
(18 items)
AudioOther
post #10 of 13
2133MHz? Nah. Pointless. 1600MHz is all you need for a Intel proc.
Ayase Eli
(20 items)
Testbench
(10 items)
MC Server
PowerMouse
OSPowerCase
Ayase Eli
(20 items)
Testbench
(10 items)
MC Server
PowerMouse
OSPowerCase
  Back to Forum: Intel - General
