Overclock.net › Forums › Intel › Intel CPUs › 29C on e6600 ?
29C on e6600 ?
post #1 of 11
I just finished my build and I'm currently running a zalman 9700 waiting on my V-6 stinger to be made..I have not even installed OS yet but my BIOS temp for my e6600 running idle is 29c. is this about right? Just want to make sure that I have spread my paste in the right abount. I lucked out as both the IHS and teh 9700 where very flat and mirror finish on the zalman. so is 29c about what a week 30b C2D e6600 on air using a zalman 9700 should run at on idle?
Thanks
e6600 30b C2D @ 3.4 Evga 680i Evga 8800gtx * 2 Extream team ddr2 1000 2gb
150g raptor - 250gb segate*2 Lighton DVD burner xp pro 64 bit / Vista 64 business 32" Protron 1368*768
Logitech G-15 750 PCP&C quad Armor 250mm side fan Razer copper head
Mouse Pad
gaming lights up red
Mouse Pad
post #2 of 11
Thanks
yeah that sounds about right, but as soon as you overclock temps will go up.
My love machine
i7 2.9 MacBook Intel HD Graphics 4000 1536 MB 8GB DDR3
Hard DriveOSMonitorPower
512 SSD OSX El Capitan 13.3" 60W
MacBook
My love machine
MacBook
post #3 of 11
Yes that is a Nice temp. When in the BIOS the temp you are shown represents 80c Load. However remember when in Windows to use the TAT monitor as its the most accurate.
post #4 of 11
Yeah the tat temps scare you
My love machine
MacBook
My love machine
MacBook
post #5 of 11
Also dont be alarmed if the TAT tems seem higher..Thats simply becasue TAT stress's the CPU a little more from what i know.
post #6 of 11
Loading the CPU with TAT's built-in stresser puts a freakish, far-from-real-world strain on the CPU cores. I think TAT is higher because it does measure the temp at the core using a new kind of sensor. Maybe someone could clarify this stuff for us that would be nice.
Conroe 6600 @ 3.6 Asus P5B-E Verto 7900 GS Corsair CM2X 6400 2GB
Hard DriveOSMonitorKeyboard
Raptor 150 GB XP Pro Gateway 22" MS Natural Ergonomic 4000
PowerCaseMouse
Thermaltake 500W Spire Pininfarina IBM Scrollpoint III
PowerCaseMouse
post #7 of 11
yes Intel's TAT measures the core of the cpu just like coretemp (a smaller program) http://www.xtremesystems.org/forums/...d.php?t=103638
It measures directly on the core so sometimes the temps can be much higher than say speedfan or everest.
and yes TAT's stressing utility really strains the processor and heats it up very quickly. I heard somewhere that this is because it is putting voltage through all of the transistors but I am not sure of this. TAT's stress utility usually gives me temps 5C more than say orthos.
Hope this helps you.
My System
Intel Core 2 Duo e6600 Gigabyte Ga-965p DS3 Evga 7900gt 512mb Corsair XMS 2gb ddr2
WD 300gb Win Xp Pro/Linux ViewSonic 22" Widescreen Saitek Eclipse
PowerCaseMouseMouse Pad
FSP Group FX600-GLN ATX12 AeroCool ExtremeEngine3T Logitech G7 My epic dual mousepds
My System
post #8 of 11
the stress utility gives me more than 15c
My love machine
MacBook
My love machine
MacBook
post #9 of 11
cool guys thanks for all the info
Mouse Pad
Mouse Pad
post #10 of 11
Yea I learned alot from this thread too!
Pro
Q6600(B3)@3.33 P5K Deluxe 6600 2GB Ballistix Tracer
33GB Normal DVD Drive linux Samsung 19Inch
MS Wireless 600W Antec 900 RAZR
Pro
  Back to Forum: Intel CPUs
