6099 WU
post #1 of 21
Since I switched to V7 I actually received a 6099 WU.I am going to make a wild guess and conclude that getting one of these is not very popular. It was certainly 8 hrs of work (if not a bit more) and it only paid 14,100 points. I know the deal is you run what they send but this one does leave a bit of a sour taste. I ran mine on my i7-970@4.05Ghz.I can only imagine how bad it gets for a guy running something like a 955.I can't see working smp WU's with anything less that an I7-970@4.05. What is the PPD for a highly clocked I5 (no hyperthreading) better or worse than I am getting?
WC Rig
i7-930@4.05GHz ASUS P6X58D-Preminum XFX GeForce 275 896mb 6GB Corsair TR3X6G1600C8D
WD 150gb Raptor LightScan Win 7 64-bit Acer 22"
G15 Corsair HX620W Antec 1200 several various
Mouse Pad
none
WC Rig
Mouse Pad
none
post #2 of 21
cranking on one right now in native linux via my phenom ii x4 b55 @ 3.7ghz , ppd 11,400, eta of 20 hrs
Doesn't seem to be very productive for my rig.
Wet Willy
(17 items)
Oold man 555
(11 items)
i7 920 @4.217 1.24 v's 24/7 Asus p6t6 ws Revolution (full water blocks) GTX 480 SLI @867-1734 samsung 30nm at 2040mhz. 8-9-9-26 1.54v's
Hard DriveOptical DriveCoolingCooling
OCZ Agility 3 RAID0 lite on dvd burner Raystorm Danger Den 480 Full copper (paralleled)
OSMonitorMonitorKeyboard
Dual boot, Windows7 64bit/Linux ubuntu64bit 1hpw2207h1680/1050  Sharp 60" LED 120hz s510
PowerCaseMouseAudio
Ultra 1600w X4 NZXT, Tempest EVO logitech s510 combo Harmon Kardon AVR245
Phenom II X4 B55 m4n82 deluxe ghetto gtx 460 patriot viper 1066
some crap sata dvd thermal take big typhoon windows 7 ultimate
MonitorPowerCase
hp 2207h ultra lsp 750watt cooler master elite
Wet Willy
(17 items)
Oold man 555
(11 items)
PowerCaseMouseAudio
MonitorPowerCase
post #3 of 21
20 hrs and it isn't even a bigadv, just a big ole core a3 smp. I am getting those 6099 and 8084's. The story about running old equipment that you pulled out of your closet and dusted off just isn't cutting it anymore. I have 3 broke down X58 boards and 2 of them are still in warranty but I am so broke until payday I can't send them in for RMA.I have the cpu's and the RAM so some how some way I have to get those boards sent in. Luckily my place has refrigerated air that is inclusive with the rent. If the landloard ever poked his nose in here he would have a fit.
WC Rig
Mouse Pad
none
WC Rig
Mouse Pad
none
post #4 of 21
The 609x used to be a one of the best A3 core unit and were fairly common back in the days. On my 3770K they are about 45k PPD while a good A4 (8084) is just shy of 50k.
On my 2500K@4.9 I was getting 29k, IIRC I was just above 7min TPF. Right around where your i7 is, about 12h if the 14k credit is correct. My 3570K@4.9 was at about 33k.
Frigg d.y.
(23 items)
i7 3770K@4600MHz 1.288V ASUS P8Z68-V EVGA Geforce GTX780Ti@1293MHz 2x4GB G.Skill TrindentX 2400 CL10@2133 CL10
Hard DriveHard DriveCoolingCooling
Corsair Force F60 2.5" SSD OCZ Agility 3 120GB 2.5" SSD EK-Supremacy CSQ Full Nickel EK-FC Titan Nickel CSQ
CoolingCoolingCoolingCooling
Alphacool VPP655 w/ EK D5 X-Top Rev.2 EK-Coolstream Rad XTX 360 & XSPC RS240 Phobya Balancer 150 Reservoir 3xScythe GT AP-15@7V, 2xNexus Real Silent 120mm...
OSOSMonitorMonitor
Linux Mint 16 64-bit Windows 7 64-bit Qix Qx2710LED Evolution II 2560x1440 Dell U2311H 1920x1080
Keycool 84 w/ Cherry MX Clear  Enermax Platimax 1500W NZXT H630 Func MS3
Mouse PadAudioOther
Qpad Sweclockers Edition BRIK DAC & AMP Ducky DK9008G2 Pro w/ Cherry MX Clear
Frigg d.y.
(23 items)
OSOSMonitorMonitor
Mouse PadAudioOther
post #5 of 21
arvidab, should I conclude that I really am not doing so bad then. Is it just that the WU is a big one and does take some time to work? Working one for 20hrs like Asustweaker is simply how it goes with a lower clocked 4 core (without hyperthreading) cpu.
WC Rig
Mouse Pad
none
WC Rig
Mouse Pad
none
post #6 of 21
I'd say you're doing good, it does take a bit of time but I think the points you get for it is proportionally good. At least a whole lot better than if you were getting 7645, takes nearly 16h on my 3770K and only gives 23k on completion, 35k PPD.
Frigg d.y.
(23 items)
OSOSMonitorMonitor
Mouse PadAudioOther
Frigg d.y.
(23 items)
OSOSMonitorMonitor
Mouse PadAudioOther
post #7 of 21
When I first started folding last summer 609x were great units. My 3570K at 4.9 got between 30-33k ppd when I ran it in native Linux for tc. I'm actually working on one now on my 3570k, but I'm using the Windows client and I'm at 23k ppd
The main rig
(18 items)
The Wife's Rig
(15 items)
minecraft box
(9 items)
Intel Core i7 3770K at 4.5ghz Asus z77 Maximus V Formula evga NVIDIA GeForce GTX 780 Classified Samsung "Wonder Ram" 8gb (4x2) @ 1866 mhz
ocz vertex 4 256 gb ssd Western Digital cavier green hdd 1tb Sea Gate 1.5 tb hdd Samsung External Blue Ray Writer
CoolingCoolingOSMonitor
Xspc rasa 750 rx360 with 3 sp120s Bitfinex Fan Controller Windows 8.1 Professional Acer 23 inch led
Logitech G510 Seasonic 750 watt fully modular Black Nzxt Switch 810 Razor Deathadder
OtherOther
Asus mpcie wifi adaptor Azio usb Bluetooth dongle
i5 3570k @ 4.5 ghz Asus Maximus IV Gene-z68 Evga NVIDIA GTX 780 Classified 8 gb Samsung "Wonder Ram" @ 2133 mhz
320 gb western digital intel ssd LG Blue Ray Drive Corsair H100
CoolingOSMonitorKeyboard
4 stock corsair fans on h100 Windows 8.1 Acer 23 inch led Logitech G510
PowerCaseMouse
Rosewill Capstone 750 watt NZXT Switch 810 black Razor Deathadder
Intel Core 2 Quad Q9400 GIGABYTE GA-G41MT-S2PT G41 + ICH7 Micro ATX  GTX 670 FTW 8 GB DDR3
500 gb seagate cd burner/ dvd player H80 in push pull Windows 7
Power
Thermaltake 600 Watt
The main rig
(18 items)
The Wife's Rig
(15 items)
minecraft box
(9 items)
OtherOther
PowerCaseMouse
Power
post #8 of 21
I think I will go native Linux as I also am at 23kppd. I am running on an unactivated copy of Win 7 (but I do have the key) and the 30 day period is winding down. I just hate the thought of being down while I work through a Linux install but you guys can take up the slack while I am working at it.+ rep for the motivation to go native Linux labnjab.
Edited by PCCstudent - 5/31/13 at 9:05am
WC Rig
Mouse Pad
none
WC Rig
Mouse Pad
none
post #9 of 21
i would recommend kubuntu kde. Do the install with a usb drive, using ext3 journaling system. Whole install should be only 15 mins with the CPU you have.
KDE has a beautiful desktop environment, and a lot of pick and choose themes. Follow the F@H website install guide for the client and the control interface. Once you have it running I have a pretty useful conky config that includes a script for work unit progress. The beta core_17's for GPU's are now natively supported in linux as well. Must be a GTX4xx series or newer.
Here's a screeny of the conky running work unit monitor on my secondary rig
Wet Willy
(17 items)
Oold man 555
(11 items)
PowerCaseMouseAudio
MonitorPowerCase
Wet Willy
(17 items)
Oold man 555
(11 items)
PowerCaseMouseAudio
MonitorPowerCase
post #10 of 21
Asustweaker, I am almost certain of the answer but I still will ask, Is an 8Gb USB stick large enough to work without issue? (that would be an 8Gb kubuntu kde), as you advise.
WC Rig
Mouse Pad
none
WC Rig
Mouse Pad
none
  Back to Forum: Overclock.net Folding@Home Team
