Overclock.net › Forums › Graphics Cards › AMD/ATI › 7930, 7970, 7990 cfx
post #1 of 5
Will my current 7970 work in CrosFire with a 7930, and then a 7990 which I will add later?
Hackintosh
(15 items)
Macintosh
(21 items)
4930K RIVBE ASUS R9 290 16GB
Hard DriveCoolingOSOS
2TB 7200RPM NZXT X60 OS X 10.9 WinBlows 8
1728x1080 144Hz Razer Black WIdow Ultimate 750W Corsair Fully Modular NZXT Phantom 820
MouseMouse PadAudio
Razer Lachesis 5600DPI Razer Soft RIVBE Onboard Sound
CPUCPUMotherboardGraphics
PowerPC 970MP PowerPC 970MP IBM CPC945 7800 GTX 512
GraphicsRAMHard DriveHard Drive
7800 GTX 512 64GB DDR2 1066MHz 500GB 7200RPM HDD 120GB OCZ Agility III
256GB Samsung 840 Pro Blu-Ray Drive Custom Loop Mac OS X 10.5.8
OSMonitorMonitorMonitor
Debian 7.3.0 1680x1050 Apple Cinema Display 1680x1050 Apple Cinema Display 1680x1050 Apple Cinema Display
GIGABYTE Force K3 1000W 80+ Platinum Apple G5 Razer Lachesis 5600DPI
Other
2SE2-E Bootable SATA II Card
CPUGraphicsRAMHard Drive
MPC7448 ATi Mobility 9700 2x1GB DDR2 400MHz OCZ Murcury Legacy
Optical DriveOSMonitor
DVD Burner+Reader Mac OS X 10.5.8 1680X1050 TFT Panel
Hackintosh
(15 items)
Macintosh
(21 items)
MouseMouse PadAudio
Other
post #2 of 5
The HD 7970 will work with the HD 7870 Tahiti LE (7930) but your Hd 7970 will be lowered to its performance.
Your HD 7970 will become a 2GB card and will be limited by the HD 7870 Tahiti Le 256bit bus. (HD 7970 = 3GB 384 bit bus)
Also you won't be able to add a HD 7990 to the equation because the HD 7870 Tahiti Le and HD 7990 only have a single crossfire bridge connector.
7870 tahiti LE
HD 7990
While the HD 7970 has two crossfire bridges
I recommend two HD 7970 and maybe add a third HD 7970 later on
Quad Damage
(24 items)
Intel i7 4930k @ 4.6Ghz Asus Rampage IV Extreme (Koolance Full WB) 2 x GTX 1080ti FE in SLI (EK WATERBLOCK) Corsair Dominator GT 2133 MHz (16GB)
3 TB Seagate OCZ Vertex 4 256GB Crucial M4 128GB ADATA SX900 128GB
CoolingCoolingCoolingCooling
RIVE Koolance Waterblock (VRM and PCH) Feser X-Changer 360 Feser X-Changer 240 Feser X-Changer 480
CoolingCoolingCoolingOS
WaterCool MoRA3 Pro with Gentle Typhoon 3 x MCP 655 pumps (With EK top...all serial) 2 x EK FC 1080ti Blocks Windows 7 Ultimate x64
MonitorMonitorKeyboardPower
Asus ROG Swift PG348Q (3440x1440 @100hz) CrossOver 27Q Led-P Logitech G15 EVGA SuperNova 1600T2 (Titanium)
CaseMouseMouse PadAudio
Corsair Obsidian Heavily Modded Logitech G700 RocketFish Speed/Control M-audio AV-40 (Logitech G-35)
Quad Damage
(24 items)
post #3 of 5
Best option is a 7990 and cfx later or 7970 and cfx later. One 7990 or 2 7970 's will be plenty horsepower for some time to come. The best is always go for the best single card solution you can afford. Seeing that you own a 7970 get another.
7930 and 7970 cfx is a waste as the 7970 will be reduced to a 7970.
The box
(17 items)
Intel Core i7 4930K RAMPAGE IV FORMULA AMDKMDAP AMDKMDAP
GraphicsRAMRAMRAM
AMDKMDAP Corsair  Corsair  Corsair
The box
(17 items)
GraphicsRAMRAMRAM
post #4 of 5
Can I crossfire a 7990 a 7970 and a 7970
Hackintosh
(15 items)
Macintosh
(21 items)
MouseMouse PadAudio
Other
Hackintosh
(15 items)
Macintosh
(21 items)
MouseMouse PadAudio
Other
post #5 of 5
yes you can that would essentially give you quad 7970's
Home
(17 items)
Server
(15 items)
intel Xeon 2670 intel xeon 2670 Intel S2600CP Evga 980ti
RAMHard DriveHard DriveOptical Drive
64gb Ecc 24x 128gb ssds  Crucial Mx1000 Asus
OSMonitorMonitorKeyboard
Windows 10 Pro Sony XBR43X830C 43" 4K Monoprice 28" 4k Max Keyboards NightHawk X8 Custom
PowerCaseMouseMouse Pad
Evga Supernova 850w  Norco Rpc-4224 Logitech G900 Chaos Steelseries QCK
Audio
FIIO E7/E9 combo
CPUCPUMotherboardRAM
Intel L5640 Intel L5640  Supermicro - X8DT3 24Gb ECC
Hard DriveHard DriveHard DriveOS
4x 128gb ssd's raid 0 - Cache Wd Red 3tb Seagate 8tb smr - parity Unriad 6.2
PowerCaseOtherOther
ThermalTake 700 watt  Norco 4220 HP sas expander Lsi 9211-8i
Home
(17 items)
Server
(15 items)
Audio
FIIO E7/E9 combo
PowerCaseOtherOther
  Back to Forum: AMD/ATI
