Overclock.net › Forums › AMD › AMD - General › 6350 vs 6300
6350 vs 6300
post #1 of 4
which one is better at gaming I be planning on overclocking the cpu
games at 1080p like planetside 2 dayz arma 3 starcraft 2
post #2 of 4
Both are the same except for clock speed. The FX 6300 comes with a lower TDP also. If your overclocking then stock clock speed doesn't matter. Go for whichever one is cheaper. The FX 6300 most probably.
Jay
FX 8350 4.4Ghz at 1.36v GA 78LMT USB3 Rev 5.0 Sapphire R9 285 OC 16GB Kingston Savage Ram
Hard DriveHard DriveCoolingOS
1TB Western Digital 500GB Seagate Barracuda Noctua NH-D15S Windows 8.1
MonitorPowerMouseMouse Pad
Asus MG279Q Fressync OCZ ZS 650 Watt PSU Dragonwar ELE-G9 Dragonwar
Jay
post #3 of 4
If you are building a new system then i would get a locked i5 if you are playing those games.
AMD Rig
(11 items)
FX 6300 Asus m5a99x evo MSI GTX 660 8gb corsair vengeance
Samsung 840 120gb  Asus Silverstone argon ar 01 Windows 7 64 bit
PowerCaseAudio
xfx xxx 650 Antec One Asus Xonar DG
AMD FX 8350 Asus crosshair V formula-Z Asus 7970 Corsair vengeance pro 1600mhz (2x4gb)
Hard DriveCoolingOSPower
Corsair force series GT 120gb + western digital... Corsair H100  Windows 7 home premium 64-bit Corsair AX 750
CaseAudio
Corsair 650D Asus Xonar DGX
AMD Rig
(11 items)
PowerCaseAudio
CaseAudio
post #4 of 4
Out of those two CPU's the FX-6300. They are essentially the same chip and you can OC the 6300 with no trouble to be fast. That being said, an i5 is a good gaming CPU and usually benches better than the FX-6300 and they both OC if you get the K version of the i5.
Are you building a whole new PC or just upgrading?
onlyHAFsane
(10 items)
FX-8350 ASUS Sabertooth 990FX R2.0 Sapphire HD7950 Vapor-X Corsair Vengance LP (2x4GB)
Hard DriveHard DriveOSKeyboard
Samsung 840 EVO WD Black Windows 7 x64 Logitech G105
PowerMouse
SeaSonic X650 Fully Modular Mionix Naos 5000
AMD Phenom II X4 965 BE  ASUS M5A97 Evo Sapphire Radeon 7850 HD 2GB 8GB (2x4GB) Corsair XMS3
Hard DriveOptical DriveCoolingCooling
Seagate Barracuda 759GB ASUS DVD-RW 24x F-2x120mm R-1x120mm 2x80mm Cooler Master Hyper 212 EVO w/ Swiftech Helix
OSMonitorKeyboardPower
Windows 7 x64 Panasonic 42" Plasma Logitech K400 Antec HCG 520M
CaseOther
Cooler Master HAF XB NZXT 5 Channel Fan Controller
onlyHAFsane
(10 items)
PowerMouse
CaseOther
  Back to Forum: AMD - General
