Overclock.net › Forums › Intel › Intel - General › 1230$ish gaming build help me put a 7970
post #1 of 7
http://pcpartpicker.com/p/1q1Cs
is it possible to get a 7970 with this build for around 1230ish$
I want to keep the i5 4670k wireless OS monitor keyboard and speaker
post #2 of 7
You can get 7970's for less than $300, so yes, it's possible.
post #3 of 7
where??? and is it worth getting a used gpu?
post #4 of 7
$299 after rebate - http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
and 2400MHz G.Skill Ares is on Sale for $66.30 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231665 (much better than your original choice of memory)
post #5 of 7
There are no new cards worth the asking price because almost all of them are revised designs now. I would buy a used reference card or a the original sapphire 7970 oc if I can find one. Imo, there should be negative rep for the XFX deals that are routinely posted. They are doing the community a disservice lol.
The 3930
(26 items)
Junior's 3930
(22 items)
DATA/HTPC
(20 items)
The 3930
(26 items)
Junior's 3930
(22 items)
DATA/HTPC
(20 items)
post #6 of 7
I heard the xfx gpu sucks but are the psu for the xfx good?
post #7 of 7
Yes, they are good units for the price and are better then the corsair CX psu's. All XFX psu's are based on seasonic designs.
AMD Rig
(11 items)
FX 6300 Asus m5a99x evo MSI GTX 660 8gb corsair vengeance
Samsung 840 120gb  Asus Silverstone argon ar 01 Windows 7 64 bit
PowerCaseAudio
xfx xxx 650 Antec One Asus Xonar DG
AMD FX 8350 Asus crosshair V formula-Z Asus 7970 Corsair vengeance pro 1600mhz (2x4gb)
Hard DriveCoolingOSPower
Corsair force series GT 120gb + western digital... Corsair H100  Windows 7 home premium 64-bit Corsair AX 750
CaseAudio
Corsair 650D Asus Xonar DGX
AMD Rig
(11 items)
PowerCaseAudio
CaseAudio
  Back to Forum: Intel - General
