Overclock.net › Forums › Graphics Cards › AMD/ATI › 142% 7970 Usage Problems...
post #1 of 5
Evening OCN, been folding for a few days here on my new rig. First couple days went fine, then my PPD started to drop because of a weird GPU usage problem. I've got dual 7970's running and a 3930K, the second GPU is running at full like it's supposed to when it's folding, but the first one will zoom from 0% to 142% usage while I'm folding. Temperatures are beneath the 70*C mark, and both cards have adequate power being delivered to them. Already tried backdating the drivers, but the problem is random.
Anybody else ever have this problem, or know how to fix it?
Thanks,
Zepp
"D'yer Mak'er"
(46 items)
Stronger, Stiffer, Cleaner.
EK Waterblocks R9-290X Reinforcement Bracket
Intel 3930K (4.411GHz @ 1.35V) Asus Rampage IV Black Edition Sapphire Radeon R9-290X (1010/1260) Sapphire Radeon R9-290X (1010/1260)
Corsair Dominator GT 16GB Kit @ 1604MHz (9-9-9-24) Asus Raidr 240GB PCI-E SSD Samsung EVO 250GB Samsung EVO 250GB
CoolingCoolingCoolingCooling
(X3) NoiseBlocker BlackSIlentPro PL-2 @ 5V Bitspower 45* Single Rotary Adapter (Matte Blac... (X3) Bitspower Chrome Stop Plug (W/ Black O-Ring) (X2) EK Monarch (Nickle Base, Clean Acetal Top)
Bitspower Mini Valve (Matte Black) (X4) NoiseBlocker eLoop B12-2 @ 7V (X3) NoiseBlocker/Phobya eLoop Black "Silent Ed... (X4) NoiseBLocker BlackSilentPro PK-2 @ 7V
(X1) NoiseBlock eLoop B12-PS Bitspower X-Station (White) (X3) ModMyToys Splitter PCB (Single 3-Pin --> 5... Bitspower Acrylic Pump Top
ModMyToys Splitter PCB (Single 3-Pin --> 3 3-Pins) (X2) EK-FC R9-290X Nickle/Acrylic (X2) EK-FC R9-290X Reinforcement Brackets (X2) EK-FC R9-290X Backplates
HardwareLabs BlackIce SR-1 360MM  HardwareLabs BlackIce SR-1 560MM  BItspower Black Mod Kit XSPC D5 Vario
Bitspower 150mm Reservoir (Acrylic base, clear ... (X14) Bitspower X47 Acrylic Fittings (Matte Bla... (X3) Bitspower Dual Rotary Snake Fittings (Matt... (X4) Bitspower 90* Angled Fittings (Matte Black)
CoolingCoolingCoolingOS
(X2) Bitspower Enhanced Dual 45* Multi-Link Ada... (X3) Bitspower Enhanced Dual 90* Multi-Link Ada... Bitspower Pressure Equalizer Stop Plug (Matte B... Windows 8.1 + Full Office Suite
BenQ XL2420TE Logitech G710+ Silverstone Strider Evolution 1000W (Sleeved by... CaseLabs SMH10, XL Window, standard ventilated ...
MouseMouse PadAudioOther
Razer Ouroborus  Akasa Venom XXL Schiit Asgard 2 (soon to be happening) (X6) Silverstone 120mm Magnetic Fan Filters
OtherOther
(X4) Silverstone 140mm Magnetic Fan Filters Vintage Soviet Ushanka Over Monitor, For Good Luck
FX-8350 Asus Crosshair V Forumula-Z MSI R7970-2pmd3gd5/oc (water cooled) Corsair Dominator Platinum
Hard DriveOSMonitorKeyboard
WD Black  Windows 7 Home Premium  Samsung Syncmaster S20B350H Razer Anansi
PowerCaseMouseMouse Pad
EVGA Supernova NEX750G Cooler Master HAF-X (Modded) Logitech G700 Cheap one
AudioOtherOtherOther
Sound Blaster Zxr (when it comes out) CPU Block: Swiftech Apogee HD (Black) X2 120mm Bitfenix Specter PWM Red L.E.D Fans (o... X2 200mm Bitfenix Specter Pro Red L.E.D Fans
OtherOtherOtherOther
Bitfenix Specter Pro Red L.E.D 230mm Fan X2 Thermal-Star gauge style thermometers w/ cus... 10ft DangerDen Dream Flex 1/2 X 3/4 in Red UV T... GPU Block: Swiftech Komodo R7970 Full Cover
Phobya 400mm Extreme (Dual 200mm) Radiator Alphacool UT60 120mm Radiator Alphacool XT45 120mm Radiator Swiftech MCP35X PWM Pump (Black)
OtherOtherOther
FrozenQ 250mm Blood Red Liquid Fusion Reservoir Drainage Loop (AlphaCool matte black T-block, d... Too many Bitspower Black 1/2 X 3/4 Compression ...
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
post #2 of 5
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
post #3 of 5
Reinstall drivers. Something is horribly wrong there, and it's probably at the software level. If you get above 100% usage, that's a sensor error. It might be unstable, as well.
post #4 of 5
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
post #5 of 5
Fresh driver and F@H install fixed the problems. I had already done a driver reinstallation before this, but thanks for the help.
+1
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
"D'yer Mak'er"
(46 items)
OtherOther
OtherOtherOther
  Back to Forum: AMD/ATI
