Overclock.net › Forums › AMD › AMD - General › 8350 Build
8350 Build
post #1 of 9
This build is for my girlfriend. I want to OC her processor to at least 4.5 GHz. She is a huge gamer and she wants an overkill machine.
http://pcpartpicker.com/p/1uBmZ
Is there any way I can make this machine better but the same price or cheaper with the same performance?
Scotty
My Laptop
(7 items)
Lizzy
(9 items)
Intel Core i7-3610QM TOSHIBA Portable PC (U3E1) Intel HD Graphics 4000 8.00 GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
Hard DriveOptical DriveOS
699GB TOSHIBA MQ01ABD075 (SATA) TSSTcorp CDDVDW SN-208AB Microsoft Windows 7 Home Premium 64-bit SP1
AMD A8-5600K MSI FM2-A75MA-E35 AMD Radeon HD 7560D Crucial Ballistix Sport 4GB (2 x 4GB) DDR3-1600...
Hard DriveHard DriveOptical DriveOS
Western Digital Green 4TB 3.5" 7200RPM Internal... Sandisk 64 GB SSD LG BH10 Blu Ray Burner Windows 10 Pro
Apex DM-318 HTPC Case w/275W Power Supply
Scotty
My Laptop
(7 items)
Lizzy
(9 items)
post #2 of 9
The GTX 670 is ranked higher and is cheaper.
http://www.videocardbenchmark.net/high_end_gpus.html
If you save money there, you can afford to get a better PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151118
I would go with a different SSD.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147188
Everything else looks good.
EDIT: I have grown to HATE Caviar Blue. I order 6 at a time from newegg and almost ALWAYS end up RMA'ing 1 or more due to bad spots revealed in a surface scan. The last Blue I bought (and I mean the last one) was completely DOA (clicker). If you need a storage drive, go for the gold and get a Black edition.
Edited by WizardontheJob - 8/21/13 at 12:05pm
Jarvis
(26 items)
Pepto Pony
(12 items)
MrDVR
(15 items)
AMD Ryzen 5 1600X CROSSHAIR VI Hero MSI GTX 980 Gaming 4g MSI GTX 980 Gaming 4g
G.SKILL Ripjaws V Series 16GB 2x2 Samsung 850 EVO 250Gb SSD Intel 160 Gb SSD Intel 250 Gb SSD
Optical DriveCoolingCoolingCooling
Generic DVD-RW 2 x Noctua (NF-P12-1300 )1300rpm Premium Silent... Monsoon 90° Rotary Angle Fitting - 5/8" - Red Bitspower Dual / Single D5 Top Upgrade Kit 100 ...
CoolingCoolingCoolingCooling
ModMyToys DreamFlex Premium 3/8" ID Tubing Reta... Coolance Liquid Coolant Bottle, 700mL Fluoresce... Coolance PMP 450 Variable Speed D5 Pump Bitspower D5 Mod Top V2 Pom version
Alphacool NexXxos UT60 Full Copper Radiator 240 Noctua NF-A6X25 FLX Quiet Computer Cooling Fan ... NZXT Sentry Mesh Fan Controller w/ Five 30 watt... 2 x Corsair Air Series SP120
CoolingOSMonitorKeyboard
COUGAR CF-V12H Vortex Hydro-Dynamic-Bearing  Microsoft Windows 10 Professional Samsung KS8000 4k UHD 65" Microsoft Wireless Comfort 5000 Keyboard and Mouse
PowerCase
SeaSonic X Series X-850 My TV Stand Cabinet
FX-4300 Gigabyte GA-78LMT-USB3 EVGA Geforce GTX 260 G.Skill Ripjaws X
Corsair SSD Samsung 7200 Laptop drive Some DVD Burner I took out of a dead Dell. Noctua NH-C12P SE14
Dell 19" 16:9 Logitec wireless Enermax 650w Apevia X-Cruiser3 Pink
A6-6400K Dual Core MSI A78M-E35 Onboard 4Gb G.Skill Ripjaws 1600Mhz (2 x 2)
Intel 320 SSD Western Digital 2.5" 1Tb 7200rpm  LG External Blue-ray Combo Drive Noctual NH-L9a 92mm SS02
OSMonitorKeyboardPower
Windows 7 Ultimate 64bit Toshiba Regza 52" 1080p Logitech K400 Antec EarthWatts Green EA-380D
CaseAudioOther
A piece of plywood and some zip ties. Onboard Hauppauge WinTV HVR-2250 dual tuner card.
Jarvis
(26 items)
Pepto Pony
(12 items)
MrDVR
(15 items)
PowerCase
CaseAudioOther
post #3 of 9
We already have the GPU so that can't change. Anything else?
Scotty
My Laptop
(7 items)
Lizzy
(9 items)
Scotty
My Laptop
(7 items)
Lizzy
(9 items)
post #4 of 9
Check my edit above.
Jarvis
(26 items)
Pepto Pony
(12 items)
MrDVR
(15 items)
PowerCase
CaseAudioOther
Jarvis
(26 items)
Pepto Pony
(12 items)
MrDVR
(15 items)
PowerCase
CaseAudioOther
post #5 of 9
You may want a better cooler for that CPU, maybe a Closed Loop Cooler since it is a fairly power hungry CPU, or even a better air cooler. The 212 is good, but for the 8350 it may not be enough. Also, I am no monitor expert, but I feel like you could get a bigger and better, or just as good, monitor for around the same price. The Samsung 840 EVO SSD is out now and is right around $100, you could drop the CPU down to the 8320, which will OC like a champ, and throw some extra money at the SSD budget. Also, you could get Seagate Barracuda HDD for nearly the same price as the Blue if you are worried about that.
I just edited the build a bit to add a CLC and a different SSD. Also changed the case because the 200R is a lot better than that Thermaltake case imo. In all honesty, if you decide to go with the build that you posted your girlfriend will not be dissapointed, but just to show other options for nearly the same price.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($159.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($92.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($114.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($58.65 @ Newegg)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Disk ($89.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Video Card: Gigabyte Radeon HD 7970 GHz Edition 3GB Video Card ($363.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($39.99 @ NCIX US)
Power Supply: Rosewill Hive 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.99 @ Newegg)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive ($21.98 @ Outlet PC)
Monitor: Asus VS239H-P 23.0" Monitor ($159.99 @ Microcenter)
Total: $1217.86
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-08-24 18:31 EDT-0400)
onlyHAFsane
(10 items)
FX-8350 ASUS Sabertooth 990FX R2.0 Sapphire HD7950 Vapor-X Corsair Vengance LP (2x4GB)
Hard DriveHard DriveOSKeyboard
Samsung 840 EVO WD Black Windows 7 x64 Logitech G105
PowerMouse
SeaSonic X650 Fully Modular Mionix Naos 5000
AMD Phenom II X4 965 BE  ASUS M5A97 Evo Sapphire Radeon 7850 HD 2GB 8GB (2x4GB) Corsair XMS3
Hard DriveOptical DriveCoolingCooling
Seagate Barracuda 759GB ASUS DVD-RW 24x F-2x120mm R-1x120mm 2x80mm Cooler Master Hyper 212 EVO w/ Swiftech Helix
Windows 7 x64 Panasonic 42" Plasma Logitech K400 Antec HCG 520M
CaseOther
Cooler Master HAF XB NZXT 5 Channel Fan Controller
onlyHAFsane
(10 items)
PowerMouse
CaseOther
post #6 of 9
Unless you want to add a second video card 550 watts is more then enough
You dont need 750 watts for a system with one video card
Seravee
(27 items)
Intel Core I7 6850K Gigabyte X99 Ultra Gaming EVGA GTX 1080 FTW2 Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo WD Green WD60EZRX  WD Red WD80EFZX 8TB  Seagate Ironwolf Pro 10 TB
Optical DriveCoolingCoolingOS
LG CH12NS30 x5 Noctua NF-A14 FLX Noctua NH-D15S Windows 7 64 Bit
MonitorMonitorKeyboardPower
Asus PG279Q LG 49UH750V 4K LED TV Corsair Gaming Strafe RGB EVGA SuperNova G2 750 watt
CaseMouseMouse PadAudio
Phanteks Enthoo Luxe Roccat Kone EMP Roccat Sense Metor Sennheiser HD 598
AudioAudioAudioAudio
Onkyo TX NR646  Dali Opticon Vokal x2 Dali Opticon 2 x2 Dali Opticon 1
AudioOtherOther
Dali E12 F Subwoofer CableMod E series PSU cable set CableMod LED Strips
Seravee
(27 items)
AudioOtherOther
post #7 of 9
Do you think that the Rosewill Capstone 550-M is the way to go then? I almost switched to that, but I figured the Hive was not bad so the expandability and price is right on the money.
onlyHAFsane
(10 items)
PowerMouse
CaseOther
onlyHAFsane
(10 items)
PowerMouse
CaseOther
post #8 of 9
Capstone is better then the Hive yes
Seravee
(27 items)
AudioOtherOther
Seravee
(27 items)
AudioOtherOther
post #9 of 9
Stick with the 8350 over the 8320. Build looks good.
Work Rig
(22 items)
Intel Core i7-6850K 4.5 GHz  ASUS TUF SABERTOOTH X99 LGA2011-V3  Asus STRIX GTX 980 ~1600 Core Asus STRIX GTX 980 ~1600 Core
32GB 3000MHz HyperX Savage DDR4  Samsung 850 Pro 512GB SSD  Samsung 256GB SM951 M.2 SSD PCIe 3.0 x 4 (PE246... WD 3TB Black SATA 6Gbs
WD 4TB Red in RAID 1 WD 4TB Red in RAID 1 ICY DOCK DuoSwap MB971SP-B Fits 5.25" Bay allo... LG WH14NS40 14x SATA Blu-ray Internal Rewriter
CPU - Corsair Hydro H110  GPU x 2 - Nzxt G-10 x 2 + Corsair H-90 x 2  Lamptron FC-5 V2 Fan Controller 4 Aerocool Dead Silence 140mm Fans on the radia...
OSOSMonitorMonitor
Windows 7 Ultimate 64 bit LINUX KXStudio AOC i2769Vm 27-Inch Screen IPS Monitor AOC i2769Vm 27-Inch Screen IPS Monitor
MonitorMonitorMonitorMonitor
AOC i2769Vm 27-Inch Screen IPS Monitor BENQ GW2250 +1 Monitor Easymountlcd Triple Monitor Stand (002-0019) Homemade Extension and vesa mount for +1 Monitor
Top - CM Storm QuickFire TK (Red) Bottom - CM ... EVGA SuperNOVA 850 G2 - 80 Plus Gold Corsair Carbide Series 400R Cooler Master Storm Inferno
Mouse PadAudioAudioAudio
Top of the Desk TUF Onboard Audio Cyber Acoustics Platinum CA-3550 Logitech H390 Headset
OtherOtherOtherOther
ASUS Wi-Fi PCI Express Adapter/400 upto 800 Mbp... Tripp Lite Isobar Supressor CyberPower CP1500PFCLCD 900 Watt Pure Sinewave UPS Logitech Extreme 3D Pro Joystick
Other
upHere (3.5 inch Bay)Multi Function Card Reader...
Work Rig
(22 items)
OSOSMonitorMonitor
Other
  Back to Forum: AMD - General
