Overclock.net › Forums › Graphics Cards › NVIDIA › 259MB Hardware Reserved after installing GTX 760
post #1 of 5
Hey guys,
recently I bought a new Gigabyte GTX 760 Windforce 3 rev2 video card (using the latest beta drivers from nvidia - 331.40) and few days ago I noticed that in the system properties for the ram it says:
Installed memory (RAM): 8.00GB (7.75GB usable) and in the Resource manager there are "259MB Hardware Reserved".
I have an Asus M5A99X EVO REV2.0 mb, AMD FX-8320 and 2 sticks of 4GB Adata ram. At the moment the ram sticks are on slot1 and slot3, but I've tried placing them to slot2 and slot4, as well as exchanging the sticks themselfs (memory in slot1 goes to slot3 and vice versa). I also tried with no virtual memory page, with windows managed page and with custom set, still no go. Restored my BIOS defaults few times and I'm running out of ideas, so I'm asking for some advices. Any help is greatly appreciated! Thank you!
I will attach a screenshot with few CPU-Zs, resource monitor and system properties.
swnny's rig
(8 items)
AMD FX-8320 ASUS M5A99X EVO Rev 2.0 Gigabyte GTX 760 Windforce 3 Rev 2.0 A-DATA DDR3 2 x 4GB kit
CoolingOSPowerCase
Cooler Master 212 EVO Windows 7 x64 Seasonic G Series 650w Fractal Design Core 3000
swnny's rig
(8 items)
CoolingOSPowerCase
post #2 of 5
http://support.microsoft.com/kb/978610
Does your motherboard support memory remapping aka memory hoisting?
http://www.dansdata.com/askdan00015.htm
Once again...
i7 920 [4.28GHz, HT] Asus P6T + Broadcom NetXtreme II VisionTek HD5850 [900/1200] + Galaxy GT240 2x4GB G.Skill Ripjaw X [1632 MHz]
Hard DriveOSMonitorKeyboard
Intel X25-M 160GB + 3xRAID0 500GB 7200.12 Window 7 Pro 64 Acer H243H + Samsung 226BW XARMOR-U9BL
PowerCaseMouseMouse Pad
Antec Truepower New 750W Li Lian PC-V2100 [10x120mm fans] Logitech G9 X-Trac Pro
Once again...
post #3 of 5
There is Memory Hole Remapping, which I have no idea what it does. Tried with both enabled and disabled states, but it's the same.
swnny's rig
(8 items)
CoolingOSPowerCase
swnny's rig
(8 items)
CoolingOSPowerCase
post #4 of 5
That's it. It is a workaround of legacy memory design. Some hardware require memory addresses in the 3.5-4GB range... this trick moves them out of that range.
Once again...
Once again...
post #5 of 5
By default this setting is set to ENABLED in my bios configuration. I disabled it and the hardware reserved memory was bigger - 771MB. Enabled it back again and now hardware reserved memory is 250MB... I will have to choose the lesser between the two evils. smile.gif
swnny's rig
(8 items)
CoolingOSPowerCase
swnny's rig
(8 items)
CoolingOSPowerCase
  Back to Forum: NVIDIA
