Overclock.net › Forums › Intel › Intel CPUs › 1
1
post #1 of 5
Edited by iluvkfc - 7/5/14 at 11:00am
post #2 of 5
Originally Posted by iluvkfc View Post
Hello,
First of all, my relevant system spec:
Intel i5 2500k
Gigabyte Z68X-UD3H-B3
Cooler Master Hyper 212+ cooler
MSI Radeon 7990
XFX 650W PSU
In some games (BF3 MP 64-player and Crysis 3 (Welcome to the Jungle)), my CPU is maxed at near 100% on all cores and both GPUs are sitting at 50-70% use, and framerate is less than desirable (around 35-40 or so). I wish to increase it by overclocking. So far, all I did was put 4.3 GHz and it was unstable on Prime95 or IBT so I put offset voltage at +0.02V and now it runs flawlessly, with around 1.320-1.332 Vcore on load (bigger load = lower vcore). Temps, however, worry me, as they are already at near 70C for Prime95 blend and around 75C on some cores for IBT maximum stress level.
I don't think temps should be that high, what could cause this?
Anyway, this increased FPS to about 45 on those areas which caused problems before, but I still want to push it further, aiming for 4.7 GHz. So I just went and put offset voltage at +0.1V (load Vcore is around 1.416V) and decided to run Prime95 and IBT. It is, however, unstable (Prime crashes after less than a minute, IBT can only complete standard stress level). In both cases, it causes a BSOD with error code 0x101. I adjusted QPI/VTT to 1.1V (increase of 0.05V) and CPU PLL to either 1.7V or 1.9V (change of +/- 0.1V respectively), but that didn't help. For the short while that it ran, temps exceeded 70C on Prime95 and 80C on IBT, so I do not plan on using IBT as a stress testing tool anymore, since that's way too high. However, I still need to achieve stability in Prime95.
How do I get my CPU stable? Surely 1.4V should be enough for 4.7, unless I have a terrible chip, or not doing something right with the other voltages. Either way, what's the max voltage I should go for?
The reason I'm asking is that I've seen people with the same CPU and cooler get way better results than me, OC and temp-wise. Also, this motherboard overclocks weirdly (massive voltage drops if using set voltage), so it might be the cause of instability.
Probably just a bad chip. My 2700K takes 1.42V for 4.8GHz, and won't do 5GHz stable with less than 1.5V
Max & Sandy
(17 items)
Secondary
(15 items)
XP Machine
(9 items)
i7 2700K @ 4.6GHz 1.4V Gigabyte GA-Z77X-UD3H MSI 980Ti Gaming Edition Corsair Vengeance 16GB
Hard DriveCoolingCoolingCooling
Crucial M550 1TB XSPC Raystorm EK FC 980Ti TF5 XSPC D5 Bay Res
CoolingCoolingCoolingCooling
Swiftech MCP655-B XSPC EX360 XSPC EX240 5x Sythe Gentle Typhoon AP-15
CoolingOSMonitorPower
Primochill Primoflex Advanced LRT Windows 7 Ultimate Yamakasi Catleap Q270 Cooler Master V1000
NZXT Switch 810
Phenom II X6 1090T ASUS Sabertooth 990FX HIS 6850 HIS 6850
G Skill Ares 32GB OCZ Vertex 4 256GB WD Black 1TB WD Green 1TB
Hard DriveOptical DriveOptical DriveCooling
Seagate Barracuda 1TB ASUS Sony Optiarc Corsair H80
OSPowerCase
Windows 7 Ultimate Corsair TX750 Cooler Master Storm Scout
Core 2 Duo @ 2.8GHz Some Intel PoS XFX GeForce 9600GSO 2x 2GB Kingston 800MHz
Hard DriveOptical DriveOSPower
Seagate 750GB Plextor Windows XP SP3 Cooler Master SIlent Pro 600
Dell Inspiron
Max & Sandy
(17 items)
Secondary
(15 items)
XP Machine
(9 items)
NZXT Switch 810
OSPowerCase
Dell Inspiron
post #3 of 5
Damnit I knew it was going to come to that... worst 2500k possible? Or maybe people with bad chips just don't brag much about it and mine is part of a silent majority? Idk I assumed all of them would be capable of such OC with reasonable volts, seeing the posts here and on other forums. Anyway, thanks for the input.
post #4 of 5
Well, you have to keep in mind that a lot of people own "K" series CPU's, but don't overclock. I've seen chips that were as bad as or worse than yours.
Max & Sandy
(17 items)
Secondary
(15 items)
XP Machine
(9 items)
NZXT Switch 810
OSPowerCase
Dell Inspiron
Max & Sandy
(17 items)
Secondary
(15 items)
XP Machine
(9 items)
NZXT Switch 810
OSPowerCase
Dell Inspiron
post #5 of 5
if it's any help I've got an unusually crappy q9550. I can't get it past 3.4ghz. it's the CPU lottery.
New gaming rig
(15 items)
4770k some mid range asrock. extreme 4 maybe? 2x gigabyte windforce 7950 2 x 8 corsair balistix sport
crucial ct960 LG blu-ray used venamous x win 8.1 pro
Crossover 30Q5 PRO 30" 2560X1600  cheapest piece of crud I could find antec HCG 750 some thermaltake microcenter blue-light-special...
MouseMouse PadAudio
came with the cheapass keyboard who cares? some $30 no name 2+sub speakers I bought at mic...
New gaming rig
(15 items)
MouseMouse PadAudio
  Back to Forum: Intel CPUs
