Overclock.net › Forums › Cooling › Water Cooling › 9370 high temp
9370 high temp
post #1 of 3
Hi, everyone. Got lately fx9370 but even with liquid cooll i have high temp at 64 on full load bf4.. I m using customs loop thermatek big water with apogee hd waterblock and black ice dual rad with push and pull fans on it. Should it be lower temps with this setup ..or is there something wrong with setup? Have to crank fan full to lower temp but very noisy.. Someone got an idea?
post #2 of 3
Try to reseat the cpu block. Use a good thermal paste like the Gelid GC-Extreme, highly recommend it.
Use a rice/small pea size dot in the middle and then carefully place the cpu block on top, tightening mounts in a cross pattern. What I do is to tighten two of them loosely, then the other two loose, then slowly tighten them more and more.
The up/downgrade
(14 items)
|Intel 6800K @ 4ghz| |Asus ROG Strix X99| |Gainward GTX 1070| |4x4gb Corsair XMS 3200mhz CL15|
Hard DriveOSMonitorKeyboard
|840 Pro 256gb| |OCZ Vertex 2 120gb| |WD Red 2tb| |Windows 10 Pro x64| |27" QNIX QX2710 @ 2560x1440 100hz| |Logitech G810 Orion Spectrum RGB|
PowerCaseMouseAudio
|EVGA SuperNOVA 1000 G2| |Antec 1200 Orange mod| |Logitech G502 Proteus Spectrum RGB|  |JBL L890 speakers|
AudioAudio
|Emotiva XDA-2 receiver| |2x Advanced Acoustic MAA-705 @ 200w 8ohm|
The up/downgrade
(14 items)
PowerCaseMouseAudio
AudioAudio
post #3 of 3
Might be a "bowed" block. If that's the case RMA time
My AMD pwnage
(18 items)
FX 8350 Asrock 990FX Extreme 9 Sapphire 7950@ 1080/1370 Replacing RAM soon
Kingston HyperX 3K 120GB SSD 500GB WD Blue Generic iHAS120 ATAPI DVD-RW Cooler Master Eisberg 120L Prestige
OSOSMonitorKeyboard
Win 8.1 Enterprise x64 Trial version Linux Mint 15 MATE in Virtualbox Sony E540 CRT 21" Logitech G510
PowerCaseMouseMouse Pad
TT ToughPower 775W TT Dokker Razer Deathadder Rocketfish
AudioOther
Asus Xonar D2 Fan controller for FM121s
My AMD pwnage
(18 items)
OSOSMonitorKeyboard
AudioOther
  Back to Forum: Water Cooling
