Overclock.net › Forums › AMD › AMD CPUs › 3800+ oc
3800+ oc
post #1 of 10
I have an AMD Athlon64 X2 3800+ (S939)
ADA3800DAA5BV
LDBHE 0606APAW
Z888159B60461
right now i have it at
FSB=245
Multi=10
Mem=166(divider) runs at about 204MHz
HTT Multi= 5
HTT=1225
i cool it with a newly added tuniq tower 120!
I have heard of plenty of ppl who have pushed ther X2 3800+ to 3Ghz... i would like to try to do the same or at least go as high as my steppings allow(or wher ever else limits me). so any input from all of u expert oc's would deff be welcome... thanks.
The "SLA8Z"
e2160 SLA8Z @ stock for now... ASUS P5N32-E SLI 8800GT SuperClocked 4GB Crucial Tracers
WD 250GB & 750GB SAMSUNG DVD burner W/ LightScribe Window XP W/SP2 Sceptre X9WG-NagaV 19'-Wide & old Emachines 15'
Microsoft Ergonomic Keyboard W/ Num Pad Antec TRUEPOWER II-550W COOLER MASTER Centurion 5 Wireless Microsoft
Mouse Pad
~Free~ Nvidia Pad
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
post #2 of 10
you should lower your htt multi to 4 or 3 to allow you to go higher with the fsb , always try to keep your htt under 1000
My System
E5200 asrock P43DE palit gts250 2gb ddr2 800
Hard DriveOSMonitorPower
320gb xp media center 32" fsp 450 w
My System
post #3 of 10
yea. I'd acutally be amazed and jealous if a 3800+ got 3Ghz! Mine can only max out at 2.9Ghz
The Naked Scooter
Intel Core i7 920 4Ghz@1.24V Asus P6T Deluxe eVGA GTX 285 12GB Patriot DDR3-1600 8-8-8-24@1.65V
2x640GB WD in RAID 0+1TB Seagate 7200.11 HP LightScribe DVD Burner Windows 7 Ultimate x64 22" Samsung 720p HDTV
Logitech G15 1000W Antec TruePower Quattro CoolerMaster ATCS 840 Logitech G9x
The Naked Scooter
post #4 of 10
i would still be happy with 2.9 but i have found miy oc stable
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
post #5 of 10
Keep pushing the FSB ,, ,, eventually youll hit the mobo's limit ,
Remember ,, memory can also stand in your way ,,, soo reduce memory frequency,, as u go up ,, on fsb ,, gl,,
Intel Core 2 Q6600 GO @ 3760 Mhz@1.504v 0.0 vdrop ASUS P5K @ 1880 Mhz FSB @1.7v Pencil Voltmod 470x8 EVGA 8800 GT SC @740/1850/1085 Mhz@1.1v G.SKILL PC8000 8GB 2GBx4@ 940 Mhz@2.10v@5-5-4-12
Tt iCage SATA WDC 320GB & 120GB Barracuda 80GB Memorex External DVD RAM Windows 7 Ultimate x64 RTM 7600 24" Sony FW900@ 2304x1440@80hz/23"Dell W2300 HDTV
Razer Tarantula with Battle Light Tt ToughPower Modularized Cable Managment@700w Black Full Tt Big WaterSE Tt P500 Pump & TMG2 Rad Razer Lachesis
Mouse Pad
Razer 3M Precise Mousing Surface
Mouse Pad
post #6 of 10
ok so now i am running like this... http://valid.x86-secret.com/show_oc.php?id=153825 (my Vcore) is 1.45V. my problem is i am stable in memtest(17full passes) but in prime95 my system randomly reboots. first i was running a hht of somthing like 1250 and prime came up with an error so i set it to 250x4 so its running at 1000mhz which is perfect but instead of an error it rebooted with 1.425V vcore so i bumped it to 1.450V and it rebooted again. i dunno what to do now.... do i just need to bump up the vcore some more!? or what else could it be!?
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
post #7 of 10
ok so this is kinda a bump....
my oc is still as stated above, but my problem is that if i try to increase my fsb at all my ram will then become unstable and i cant figure out how to make it any more stable. if i go down to the next divider, it runs too slow and i dunno if it is really worth running my ram at somthing like 180mhz or slower just so my cpu can run one or two tenths of a gig faster.
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
post #8 of 10
Well if it allows you to get a higher overclock, its worth running the RAM slower. Have you tried loosening timings and giving it more VDimm so you can OC the RAM more?
The Naked Scooter
The Naked Scooter
post #9 of 10
im trying for 3.0 on mine right now got 2.9 somewhat stable with only 8.5 hour prime test its deffinately your ram. what brand ? model?
AMD Athlon 64 X2 3800+ GA-K8N-SLI GV-NX79G256DP-RH OCZ4331024PFDC-K
ST3320620AS Sony Xp SP2 Samsung SyncMaster 920BW 19" Widescreen
Anti-RSI Ultra 500W X-Connect Alogic LogiTech
Mouse Pad
N/A
Mouse Pad
N/A
post #10 of 10
http://www.adata.com.tw/adata_en/pro...uctNo=AD1400EU
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
The "SLA8Z"
Mouse Pad
~Free~ Nvidia Pad
  Back to Forum: AMD CPUs
