650D
post #1 of 2
Do any of you guys know without any cutting or modding, any way to ad extra fans to the 650d mid tower case. I thought there was a intake spot for 120 mm fan on bottom but I was wrong, what about 5.25 bay, is there an adapter from corsair to mount more 120 mm fans ? Any suggestions welcomed!thumb.gif
Test Bench
6700k ASUS ROG STRIX Z270G Nvidia GTX 1060 Corsair Vengeance LPX 16GB DDR4 DRAM 3000MHz
Hard DriveCoolingOSMonitor
MyDigital BPX CoolerMaster Master Liquid 240 windows 10 x64 pro Viewsonic xg2703-gs
Logiech G413 Corsair rm650x Test Bench Logitech G403
Audio
Logitech G533
Test Bench
Audio
Logitech G533
post #2 of 2
Corsair offers a mesh side panel insert that replaces the plexi window and allows you to either mount another 200mm fan or up to four 120mm fans.
Lots of people have added a 120mm fan to their 5.25 bays. Check the 650D Thread for lots of pictures and inspiration.
Some people in that thread have cut a hole in the bottom of the case to add another fan as well.
  Back to Forum: Computer Cases
