Overclock.net › Forums › Components › Other Peripherals › $1400 Thermal Paste
$1400 Thermal Paste
post #1 of 6
http://www.newegg.com/Product/Product.aspx?Item=9SIA3TW1DJ0649
$1400 thermal paste from Newegg.
Good bang for buck? :)
Undelwalt (2017)
(29 items)
Celapaleis (2013)
(16 items)
7600k @ 5.197/1.392 1.392v z170 Asus Hero EVGA 1080ti SC Black (2100/6250) x2 8gb GSkill Trident Z 3600 @ 3804 15-15-15-32-2T
Hard DriveHard DriveHard DriveCooling
Samsung 950 Pro 512gb (Undelwalt) WD Red 2tb (Pack Yak II) Seagate Expansion Drive 5tb (Phoenix Down II) 3x560mm HardwareLabs Nemesis GTX
CoolingCoolingCoolingCooling
XPSC Raystorm Pro Watercool Heatkiller 1080ti Full Cover Waterblock EK XTOP Revo Dual D5 (Serial, PWM, v4) EK ZMT (1/2 - 3/4 ID OD)
14xEK ACF (Compression Fittings) EK x4 250 (v2) Distilled Water + PT Nuke (Copper Sulphate) 24x140mm Silent Wings 3
OSMonitorKeyboardPower
Windows 10 Pro 64bit Catleap 27 Inch 2560x1440 IPS 60hz Display Coolermaster Storm Trigger (Brown Switches) EVGA P2 1000w
CaseMouseMouse PadAudio
Corsair Air 540 Logitech G Pro Tek Syndicate "Raze the World" Desk Mat O2 + Odac by Mayflower Electronics (Rev A)
AudioAudioAudioAudio
Sennheiser HD 800 2xKrk Rokit 6 G2 Blue Yeti (Grey) Rode PSA-1 Arm
Other
Aquaero 6 LT + Aluminum Heatsink
i5 6600k Delid @ 4.848/4.848 Asus z170 Hero MSI GTX 980ti @ 1499/4082 1.25v/134% Power 2 x 8gb Gskills Ripjaws V 3131 16-16-16-32
Samsung Pro Series 840 256gb (Celapaleis) 1 TB Samsung Drive (Pack Yak) Samsung Pro Series 850 256gb (Celapaleis Reprise) Phoenix Down (External Backup)
CoolingCoolingOSMonitor
Noctua D14 Kraken x61 Push-Pull for GPU Windows 10 Pro Catleap 2560x1440 @ 60hz
CM Storm Trigger Brown Switches EVGA Supernova 1000w P2 Corsair 540 Air Razer Abyssus
Mouse PadAudioAudioAudio
Steelseries QcK Mini Blue Yeti Microphone Objective Dac + Amp Sescom AB Switch
Krk Rokit 6 G2 x2 Radioshack Ground Loop Isolator (For Rokits) Wooaudio Aluminum Headphone Stand Sennheiser HD 800
AudioOther
Logitech c920 Webcam NZXT Sentry Mix 2 Fan Controller
Undelwalt (2017)
(29 items)
Celapaleis (2013)
(16 items)
Other
AudioOther
post #2 of 6
Originally Posted by Darkwizzie View Post
It's a 1kg tub.
$1.40 per gram.
Standard tubes of JP-DX1, IC 7, and similar TIMs are around $4 per gram.
So yeah, good bang for buck...if you need about ten thousand applications worth.
Primary
(15 items)
Secondary
In progress
(10 items)
5820K @ 4.3/3.6GHz core/uncore, 1.225/1.2v Gigabyte X99 SOC Champion (F22n) 2x Sapphire R9 290X Tri-X OC New Edition (10036... 4x4GiB Crucial @ 2667, 12-11-12-27-T1, 1.37v
Plextor M6e 128GB (fw 1.05) M.2 (PCI-E 2.0 2x) 2x Crucial M4 256GB 4x WD Scorpio Black 500GB Cooler Master Nepton 280L
Windows 7 Professional x64 SP1 BenQ BL3200PT Filco Majestouch Tenkeyless (MX Brown) Corsair RM1000x
CaseMouseAudio
Fractal Design Define R4 Logitech G402 Realtek ALC1150 + M-Audio AV40
X5670 @ 4.4/3.2GHz core/uncore, 1.36 vcore, 1.2... Gigabyte X58A-UD5 r2.0 w/FF3mod10 BIOS Reference R9 290X w/Stilt's MLU 1000e / 1375m E... 2x Samsung MV-3V4G3D/US @ 2000, 10-11-11-30-T1,...
1x Crucial BLT4G3D1608ET3LX0 @ 2000, 10-11-11-3... OCZ (Toshiba) Trion 150 120GB Hyundai Sapphire 120GB 3x Hitachi Deskstar 7k1000.C 1TB
CoolingOSPowerCase
Noctua NH-D14 Windows 7 Pro x64 SP1 Antec TP-750 Fractal Design R5
Audio
ASUS Xonar DS
i7-6800K @ 4.3/3.5GHz core/uncore, 1.36/1.2v ASRock X99 OC Formula (P3.10) GTX 780 (temporary) 4x4GiB Crucial DDR4-2400 @ 11-13-12-28-T2, 1.33v
Hard DriveHard DriveCoolingOS
Intel 600p 256GB NVMe 2x HGST Travelstar 7k1000 1TB Corsair H55 (temporary) Windows Server 2016 Datacenter
PowerCase
Seasonic SS-860XP2 Corsair Carbide Air 540
Primary
(15 items)
Secondary
In progress
(10 items)
CaseMouseAudio
CoolingOSPowerCase
Audio
ASUS Xonar DS
PowerCase
post #3 of 6
Well you are saving on it cause it costs $15.00 for 3g and that tub is 1000g for $1,400.00
post #4 of 6
Originally Posted by Blameless View Post
It's a 1kg tub.
$1.40 per gram.
I didn't see that part, lol.
Look at the description though... Nanotechnology!!!
Undelwalt (2017)
(29 items)
Celapaleis (2013)
(16 items)
Other
AudioOther
Undelwalt (2017)
(29 items)
Celapaleis (2013)
(16 items)
Other
AudioOther
post #5 of 6
If you think it in a long term...you will never need to buy a thermal paste again. Never again for that incident of OH NO! I have to wait for tomorrow because I forgot to buy a paste.
post #6 of 6
Yeah, I dunno anyone other than an OEM who would think of buying this.
  Back to Forum: Other Peripherals
