Overclock.net › Forums › Graphics Cards › NVIDIA › 760gtx upgrade
760gtx upgrade
post #1 of 4
Well I didn't know I'd like BF4 so much but I do... Now I'm bugged that I can't run it full max. I assume my GPU is holding me back. If I sli with another 760gtx would that let me max out bf4? Trying to find cheapest solution. If I upgrade to better card I assume I will need a better GPU?
In my situation what would you do?
post #2 of 4
id stick with one 760 , i have one 760 and i get full ultra but i have the bottom 3 options set to off, because they effect the fps the most.
post #3 of 4
if you have the GTX 760 4gb and you sli them you can get away with your PSU without no overclocks and max all games
PowerHouse
(28 items)
My Media Server
Clearance Abuse
(21 items)
Ryzen 1700 @ 3.61ghz (1.2vcore) Asus Crosshair VI Hero Gigabyte GTX 980ti G1 @1480/2000  R9 290
HOF DDR4 4000mhz (3200 16-16-16-36 1T 1.4) Kingston Hyper X 240Gb 3K  Sandisk Ultra II 480gb  Crucial MX300 750gb
Hard DriveHard DriveCoolingCooling
Intel 600p 240gb  WD Velociraptor (Win7 bench drive) Custom Loop  SP 120 (x4)
CoolingOSMonitorMonitor
Swiftech Helix  Windows 10 Professional  Benq XL2411T 144hz screen Acer AL1916W
Coolermaster Quickfire TK MX brown w/ ABS Clear... EVGA 750watts G2 Thermaltake Core P3  RAZER Imperator BF3 edition
Mouse PadAudioAudioAudio
RAZER goliathus World of tanks edition Creative gigaworks T40 Series II E10K DAC DT 990 Pros
AudioOtherOtherOther
Antlion Modmic  Xbox 360 controller windows Deepcool RGB kit NZXT GRID+
i5 3570 Asus P8Z77M-Pro Asus HD2400 G.Skill 4gb 1333
Toshiba 80gb (OS) 2 X 2TB Seagate Barracuda Coolermaster Evo 212 2X Xigamatek white LED fans
OSMonitorKeyboardPower
Linux 3.2.0 \ Open media vault Dell 19 inch Dell OEM poop Coolermaster GS 650M
NZXT S340 (white)
6700k Z170X Gaming 7 Msi GTX 970  Vengeance red LED 3000mhz DDR4
Samsung Evo 250gb WD 1TB Blue WD Raptors 150 GB RAID 0  Noctua NF-P14S (x2)
Intel Liquid Cooling (SP120 X2) Win 10  HP 1730 Acer XB2410H
MAD CATZ STRIKE 3  Antec HCG 900 NZXT Phantom 630 Cougar 900
Razer Creative T10  Audio Technica PG1  Asus U7
Other
NZXT Hue
PowerHouse
(28 items)
My Media Server
Clearance Abuse
(21 items)
NZXT S340 (white)
Other
NZXT Hue
post #4 of 4
You have a couple of options. SLI is not a bad option, but you have to decide how you want to mess with things. You should be able to sell your card for about $200 fairly quickly, and depending on how you do that, you could use the funds left over plus the extra you were going to spend on another card and go used 780. They can be had for 400-450 here in the marketplace and similar.
Overall, maybe a little more work, but probably the way I would go personally. Would use less power and play very smoothly.
I just have a hard time recommending anyone to pay for a 2gb SLI option. Try to get some longevity out of it all, you know?
3770k Z77x-UD5H v1.1 GTX 560ti 1050/2100/1100 Crucial Ballistix 32g 1.35v
256g 840 Pro/ 250 Evo x2 Raid 0 / 2TB F4 Samsung BD +/- RW Win 7 x64 Ultimate LG IPS237L-BN
PowerCase
Corsair AX850 Lian Li PC-K62
PowerCase
  Back to Forum: NVIDIA
