Overclock.net › Forums › Intel › Intel CPUs › 4470k stock crash/bsod
post #1 of 9
So I recently got a new mb and 4770k. I wanted to test things out at stock to see where I was at and I was getting bsod/crashing/85+c temps with occt, prime 95 and ibt. I tried to cut the voltages back, oc to 4.2 with 1.3v, still nothing but the same. I do not think I am doing anything different than others have to oc to this level and am pretty disappointed that I didn't win the lottery but seem to have gotten a subpar process in general. Any suggestions would help a lot. mad.gif
Short and square
(21 items)
4770k asus maximus hero evga 780 6 gb sc acx evga 780 6 gb sc acx
RAMHard DriveHard DriveCooling
kingston hyperx fury 16gb samsung 840 250gb western digital black h100i
OSMonitorMonitorKeyboard
Windows 7 x64 PB278Q S27C750P Lots of them
PowerCaseMouseAudio
evga supernova 1000 p2 corsair 540 Too many audioengine d1
AudioAudioAudio
Schiit Magni/Modi combo audioengine grado sr325is
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
post #2 of 9
It shouldn't be crashing at stock, have you tried reseating the heatsink?
Also, try using manual voltage instead of offset or adaptive, it keeps haswell from overvolting itself during benchmarks.
Bruce
(20 items)
4670k Asus Z87 Pro HIS 7950 IceQ X2 2x2gb + 2x4gb DDR3 1333
Seagate 1TB 7200RPM OCZ Agility 4 128GB PNY 240GB LG Blu Ray Burner
CoolingOSMonitorKeyboard
Hyper 212+ with extra fan Windows 10 Education x64 Shimian QH270 @110hz Medieval Dell OEM Keyboard
PowerCaseMouseAudio
Corsair TX750 V1 Antec 300 Black Illusion  Logitech G400s Xonar ST
AudioOtherOtherOther
Fostex T50rp with BMF mod Archer T9E Wifi adapter 2x Yate Loon D12SL-12D 120x38mm fans Thermalright TY-143 fan
Bruce
(20 items)
PowerCaseMouseAudio
post #3 of 9
I did try that. same results.
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
post #4 of 9
I have it set on normal, changed the vcore to 1.25, set the vdroop to 100%. Got a pic before it failed on me again.
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
post #5 of 9
What speed is your ram currently clocked to?
Gaming Computer
(19 items)
Intel Core 2 Quad Q6600 Asustek P5Q-PRO Nvidia 9800 GTX+ Kingston DDR2 8gb
Western Digital 1 TB Pioneer Noctua NH-U9B Windows 7 Ultimate 64-bit
Dell Monitor Logitech G110 Antec 750W Thermaltake Aluminium Old Case
MouseMouse PadAudio
Logitech G500 Gaming Mouse Generic Mousepad Soundblaster 5.1 VX
Gaming Computer
(19 items)
MouseMouse PadAudio
post #6 of 9
I had it set to default. And then Noe just bsod after bsod. System_service_exception
Memtest ran fine. Reset the CMOS and and kept getting it. Reinstalling windows. Not my night.
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
post #7 of 9
Alright even after reinstalling windows i was gettign bsod while watching youtube...I decided to swap out my ram and I think I might have found the jerkface in the situation. Would bad ram equal a bad overclock? Bad stability? High temps and high volts for medicore overclocking? Sorry, really new at this.
prior I had the ram set to default or xmp for my corsair dominator platinum at 1866. Now I have corsair lp 1600mhz set to their xmp profile.
update: just ran OCCT at 4.2 ghz, 1.25v and got another bsod.
Edited by draterrojam - 4/9/14 at 11:27pm
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
post #8 of 9
hmm your getting system service exception? this could be a driver issue honestly..you installed all the chipset drivers etc??including rapid storage tech???
anyways I would attempt to reinstall all chipset drivers etc including rapid storage tech and all...this is a most.
I would then go into bios and enable c states and make sure c1e is disabled and speedstep and eist are enabled.
I would also manually input the ram speed and timings and voltage...I would also increase SA system agent voltage to close to 1.2v or offset of +0.150-0.200
also last time you cleaned you HDD's??? or did a format/clear erase on them??? ive seen some SSD's on new chipsets retain old drivers without a clean format on them.
hope this helps at all. good luck
similar issue http://www.sevenforums.com/bsod-help-support/274012-blue-screen-errors-ntfs-file-system-system-service-exception-4.html
Edited by Clexzor - 4/11/14 at 6:02am
GamingRig
(16 items)
H-Server
(12 items)
CPURAMHard DriveOptical Drive
Intel i7-4770 8gb 2400 Gskill Samsung 840 Pro 120Gb Samsung 840 120gb
Optical DriveOSMonitorKeyboard
2TB Seagate External Win 8 64-Bit Qnix 2560x1440 120hz Corsair Mech k90
PowerCaseMouseMouse Pad
Corsair AX860 Plat. Lian Li MATX Razer Deathadder 2013 Razer Ironclad
i5-2550k (Stock) MSI Z77 G55 ATI 5xxx 1Gb Corsair 8gb
Hard DriveHard DriveHard DriveCooling
Seagate 500Gb Seagate 2Tb Seagate 2Tb Stock
OSMonitorPowerCase
Windows Home Server 2011 LG 1920x1080 600w Corsair Green Asus
GamingRig
(16 items)
H-Server
(12 items)
OSMonitorPowerCase
post #9 of 9
Thank you for getting back to me. I had it with the system and I know it might of been over kill but I got a brand new board and chip and RMA'd the others. I tried everything you said about installing the drivers and reinstalling them even cleaning the display drivers completely and all that jazz, even manually entering the timings for the ram. The only thing I didn't do was the changing of the volts. Needless to say I hope this one works out. I just finished setting it up, new 4770k and an asus maximus hero. We shall see how it goes. Thank you again for posting though, I sincerely appreciate it.
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
Short and square
(21 items)
PowerCaseMouseAudio
AudioAudioAudio
  Back to Forum: Intel CPUs
