Overclock.net › Forums › Case Mods & Cases › Builds & Case Mods › Case Mods › 540 air questions
540 air questions
post #1 of 3
Hello, long time lurker
I was thinking about getting a 540 air and have a few questions and also a first time future modder.
1- What is the case made of ?
2- I want to put a 200mm exhaust fan on the psu side of chamber, good way to do this ?
3- Main chamber, I won't be using the HDD's on the bottom, should I use wood, sheet metal etc to cover this ?
would like to make room for a fan or 2 in that spot as well.
4- The vertical bays, this is whats holding me back. Any suggestions on sprucing this area up ?
will put a optical drive and fan controller in there.
post #2 of 3
the case is made of black steel
I tend to watch linus videos on Corsair Cases cause he shows them well..
2- no need for that.
3- Yes you can hide that using a PSU cover. which you can do you self by bending a piece of aluminum sheet and spraying it black.
For your last question. i have to own the case to be able to help you biggrin.gif
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
intel i7 3770K Gigabyte Z77 UD3R Sapphire Radeon r9 290x Sapphire Radeon r9 290x
Corsair Vengeance 8GB seagate barracuda 7200 RPM 1 TB PNY 120GB SSD PNY 240GB SSD
CoolingCoolingCoolingCooling
ek supermacy full nickel Mayhem Pastel white  Mayhem blue non stain dye ek FC r9 290x
ek fc r9 290x  swiftech mcp655 Koolance COV-RP450  EK-CoolStream RAD XT 240mm
CoolingCoolingCoolingMonitor
Swiftech MCR320 360MM  Primochil ghost rigid compression fittings Primochill PETG Tubes X-star
Nixeus moda v2 EVGA SuperNova GS850 NZXT H440 Logitech G400
Mouse PadAudio
Razer Goliathus Asus Xonar DGX
intel i5 4430 Asrock z78 pro 4 Sapphire 7870 XT G.Skill Aries 8GB
Hard DriveCoolingOSMonitor
A LOT OF THEM Corsair H80 Windows 7 ultimate Samsung
Cooler Master Quickfire TK Corsair 650XT Thermale take armor revo 4 Cooler master storm xornet
Mouse PadAudio
Steelseries CKQ Steelseries Flux luxury edition
Intel i7 3770k GigaByte GA-Z77x-UD3H sapphire R9 290X Corsair Vengeance 8GB
Hard DriveOptical DriveCoolingCooling
western digital caviar blue Samsung HF-132B Corsair Sp120 Corsair AF AF120 LED
Alphacool ST30 AlphaCool XT45 EK supremacy Clean CSQ Full Nickel PrimoChill Advanced LTR tubing
CoolingCoolingCoolingOS
Swiftech MCP50X Alphacool Cape Corp 100ml Koolance VID-290X Windows 7 Ultimate
MonitorMonitorKeyboardPower
X-Star Dp2710 @ 92HZ BenQ E2400HD Cooler Master Quickfire Ultimate seasonic M12II 750W
CaseMouseMouse PadAudio
Corsair Carbide 500R logitech G400 Cooler Master SteelSeries Syberia V2
Other
NZXT LED strip
BEAST
(26 items)
The Wifey's Rig
(14 items)
The Black Pearl
(25 items)
Mouse PadAudio
Mouse PadAudio
Other
NZXT LED strip
post #3 of 3
I have this case, It is very nice. The only Mod I have done was to paint the mesh panels fluorescent orange. Although I am now going to be getting a HAF Stacker to replace it, just because I want more room and flexibility (because If I am gonna take the time to make a custom water cooling loop, I'm gonna go completely nuts with it).
Don't get me wrong though, its a nice case, just a bit small, the back area has plenty of room for modding, but still will quickly become cramped unless you are really good with wire management. Also you cannot use a dual bay reservoir in this case because the bays are separated by a single metal panel.
Friggin excellent airflow though. If you don't mind the work and have the tools, you could easily modify the crap out of it, I had the thought of putting FrozenQ reservoirs ontop of the case, above the backside of the motherboard; partly because mounting a res. is hard in this case if you want to make sure your res. is above your pump.
  Back to Forum: Case Mods
