Overclock.net › Forums › AMD › AMD CPUs › 8370E 8320E what?
8370E 8320E what?
post #1 of 6
I am looking to upgrade my cpu. I have an 8320 and can't get past 4.8 Ghz. and it requires 1.57v. under load to do that.
I was thinking about the 9590(it's on sale now). But now I see there is an 8320E and an 8370E. What exactly are the 8320E and 8370E versions anyway. What makes them so different or special? Please help. redface.gif
What about the 8370?
Edited by hucklebuck - 10/22/14 at 6:59pm
Movin' on Up
(23 items)
AMD FX-8320 ASUS SABERTOOTH 990FX R2.0 MSI R7950-3GD5/OC BE Samsung 8GB DDR3-1600 (PC3-12800)
Hard DriveOptical DriveCoolingCooling
SAMSUNG SSD 840 Liteon IHAS 524 DVD writer  XSPC Raystorm CPU Waterblock (2) EK-PSC Adapter 90° G1/4 Black Nickel
CoolingCoolingCoolingCooling
EK Radeon HD 7950 VGA Liquid Cooling Block Alphacool NexXxoS XT45 Full Copper 360mm Radiator Swiftech MCP655 XSPC Single Bay Reservoir 5.25"
(6) Swiftech Helix 120MM 9-Blade Z-Bearing Fan ... (10) XSPC G1/4" to 1/2" ID, 3/4" OD Compression... PrimoFlex Advanced LRT Tubing - 1/2in. ID X 3/4... (2) EK-PSC Adapter 45° G1/4 Nickel
OSMonitorKeyboardPower
Windows 7 64bit Samsung SyncMaster P2370HD  Logitech K300 Rosewill Tachyon-650
CaseMouseMouse Pad
CoolerMaster HAF Stacker 935 Logitech Allsop
Movin' on Up
(23 items)
CaseMouseMouse Pad
post #2 of 6
They are the same thing as the other fx 8 cores. They are just clocked with lower frequencies and voltages. I would stick with 4.8 and enjoy it.
Queso Fresco
(15 items)
Ryzen 5 1600 MSI B350 Bazooka ASUS Turbo GTX 1060  T-Force DDR4 3000 16gb
Hard DriveHard DriveCoolingOS
Samsung 840 250gb Intel 320 160gb SilverStone Heligon HE01 Windows 10
Achieva Shimian  Monoprice MX Black SeaSonic X-750 Corsair 350D
Mouse
Logitech G403
Queso Fresco
(15 items)
Mouse
Logitech G403
post #3 of 6
There is reason to believe that these E cheaps are very low leakage based on results ive seen from them.
Ryzen!
(9 items)
Steamroller
(9 items)
AMD Ryzen 5 1600 AsRock AB350M Pro4 MSI RX 480 Armor 4GB OC Corsair Vengeance LPX 8GB
CoolingOSPowerCase
Bequiet! Dark Rock 3 Windows 10 Home EVGA Modular 500W Power Supply RAIJINTEK STYX
Mouse
Razer Abyssus
CPUMotherboardRAMHard Drive
Intel E5800 Wolfdale Asus P5Q-EM G.Skill 2x2GB PC2-6400 Western Digital RE3 500GB Drives RAID1
CoolingOSPowerCase
Scythe "SHURIKEN" Rev.B Windows Vista 64 Corsair CX400 PSU Lian Li PC-V351
Ryzen!
(9 items)
Steamroller
(9 items)
CoolingOSPowerCase
Mouse
Razer Abyssus
CoolingOSPowerCase
post #4 of 6
get the FX 8370E if you dont mind having the same CPU with lower vcore and temps.
post #5 of 6
I had an opportunity that allowed me to switch from an 8350 to an 8370E cheaply.
So far I am absolutely satisfied. My 8350 worked great at stock or low OCs but would not OC to where I wanted it. With the 8370E I am hitting higher core speeds with less vCore. At the same time I am running 2133mhz ram, before I could not go past 1800.
It is the same design but it seem the manufacturing process has improved. If you can sell your chip for a decent price it may be worthwhile.
Moneypit
(11 items)
FX-8370E ASUS Sabertooth MSI 7950 G SKILL Sniper
Hard DriveHard DriveHard DriveCooling
Agility 2 Agility 3 Western Digital Black  Custom Loop
OSPowerCase
Win 7 Pro Corsair 750W NZXT
Moneypit
(11 items)
OSPowerCase
post #6 of 6
What Ben said.
Or you can look at the 9370, which is now really low in price. Sadly the one place that was selling them for like $190 (OEM chip) has raised their price. Oh well.
The 8320E and 8370E are both allegedly low-leakage chips that can run at X ghz with a lower vcore than can your typical 8350 or 8320.
The 9370 and 9590 have the advantage of binning, which means they won a higher prize in the silicon lottery than your typical 8350.
Either way, you'd probably see an improvement.
  Back to Forum: AMD CPUs
